01-25-2024, 08:11 AM | #1 |
Rep 418
Wireless Charging Heat - is BMW charger the problem or the phones?
As many have complained here, the wireless charger in BMW is a glorified microwave and just cooks the phones. I experienced that over a long drive and decided to add the Apple MagSafe Fast Charger. Its an induction (fast) charger similar to the one in BMW with a USB C wire. The idea was to not have to plug in the phone but just drop it in the center armrest so the phone could charge and be able to lift the phone out one handed while driving.
In my usage however, I realized that my phone (iPhone 12) gets as hot with the Apple MagSafe charger as it does with the BMW charger. This is when the phone is connected to the car (CarPlay mostly). I then connected the phone via the lightening port using a cable to the center console and the heating problems went away. My conclusion is that this is a phone problem when charged with a fast induction charger and is being actively used. Perhaps induction charging somehow utilizes the main processor that creates additional heat vs using the cable? Not sure if this is limited only to iPhones and Pixels as I have read that Samsung phones charge just fine in BMW. Additionally, is it possible that slow chargers work fine (however I am not sure if they will be able to add charge to the phone when being actively used with CarPlay)? Feel free to chime in with your experience. Last edited by starlights; 01-25-2024 at 08:43 AM.. |
01-25-2024, 09:26 AM | #4 |
31
Rep 48
My iPhone gets so hot it auto-shuts to cool down off which breaks car play navigation while driving, so I can no longer rely on it for navigation. I have an iPhone 15 Pro, and with all of these complaints, they should have tested this feature or added some type of cooling built into the charging pad. But if the issue persisted with magsafe charger, I'd say the root cause is the phone, it cannot handle CarPlay + Wireless charging.
01-25-2024, 09:41 AM | #5 |
Rep 180
Is this a side effect of car play or Android auto? I stopped using car play some years ago in my 21 40i, preferring iDrive. I also stopped using the charger. Now, in my 50e, the phone has not overheated but it also doesn't really charge. I'm going to start paying more attention to how it works.
2024 50e Ametrin / Coffee Merino
01-25-2024, 09:48 AM | #6 |
Rep 8,828
Drives: eVeRyOnE mAD!
starlights
wireless induction charging always causes heat. actually, charging batteries always results in heat (wireless > wired); it’s unavoidable and the nature of charging batteries. some charging devices and phones are better than others, but that has to do with their heat sinking capabilities |
01-25-2024, 09:53 AM | #7 | |
Rep 418
Raikkonen340.00 |
01-25-2024, 10:19 AM | #9 | |
Rep 8,828
01-25-2024, 10:20 AM | #10 |
Rep 8,828
you mean a phone case? yeah, but no smoking gun as the cases used had different specs
the manual lists both and case specs that the tray is designed for. anything outside those specs one can expect issues with wireless charging. that said, it’s a very inefficient 5W charger that does a poor job even if the phone and/or case are within spec I typically have a case (Mous, Element); not a contributing factor in my use case |
dwwStL164.50 |
01-25-2024, 10:25 AM | #11 | |
Rep 418
in response to mscot's question - I have - and my phone (iPhone 12 mini) overheated in both cases. |
01-25-2024, 10:38 AM | #12 | |
Rep 8,828
my iPhone 12 Pro overheated in the BMW wireless charger which is why I went the external MagSafe charger route one week into ownership. I’ve used it on occasion since, and it’s 30:70 in overheating my iPhone 14 Pro. |
01-25-2024, 12:02 PM | #13 |
Rep 1,117
Samsung S22+ with a little case on it. Never any issues charging on the wireless mat. Usually streaming Bluetooth from it. Works fine in our Expedition as well.
My wife has some sort of iphone and it doesn't seem to wireless charge in either car, and our random smattering of standalone wireless chargers are only so so with it. My take, it's the phones. |
01-25-2024, 12:13 PM | #14 |
Rep 877
My iPhone 15 Pro Max (sans case) gets a little warm on the X5 wireless charger, but it's running CarPlay, streaming music, nav, Motus, etc. It does charge during all of this, but rather slowly. To be fair though, the phone gets warm on the wireless charger in my home even when it's not doing anything.
I'm actually fine with that because I treat it more like a battery level maintainer than a charger--I don't want the car topping off the battery in my phone several times a day because that's the fastest way to degrade the battery.
M3 - X5 - 911 - Miata - Raptor - Edge
01-25-2024, 12:52 PM | #15 |
Rep 8,828
01-25-2024, 01:01 PM | #17 |
Rep 3,723
My experience with Iphone 12 pro (wife's previous phone), Iphone 13 pro (my current phone), Iphone 15 pro (wife's current phone), Pixel 5 (wife's work home), Pixel fold (my work phone), they all get pretty warm in the BMW charger even if they are all idle. These are 5 different phones across 2 big manufacturers. Add to that with all other wireless charging pads we have around home or car, none get to the same warm level under same workload (idle). I am not sure phones are the issues.
Now one can argue the charging pad is in the kind of enclose location with minimal air flow. It is not impossible, but this points to the implementation of the wireless charger, the chosen location is bad.
2022 G05 B58/PHEV
+ a few very old BMWs |
01-25-2024, 01:16 PM | #18 |
Rep 180
Some manufactures have started venting AC into the phone compartment to manage phone heat.
01-25-2024, 01:26 PM | #20 |
Rep 1,117
So one other thing to keep in mind, most phones have VERY POOR thermal management. Phones aren't like a PC with fans to keep everything cool, etc. they have some internal heatsinks, but they have very poor methods of dissipating heat, they don't have fins, fans, etc.
Wireless charging does create heat. So does computing, someone's wireless communications, etc. So if your phone is heating up while it's on the charger, streaming music, doing nav, and wirelessly talking to the car... WELL DUH. That's basically a max case usage, about the only thing you could do more than that is play a very taxing game on it while live streaming it, lol. There are a select few gaming phones out there that actually do take into consideration thermal management. Your average iPhone doesn't have any real significant design for cooling, so it isn't surprising that it would heat up when you're putting it through strenuous use and charging it, its making a lot of heat and has no way to dissipate that heat. |
starlights166.00 sac0249.50 |
01-25-2024, 03:10 PM | #21 |
Rep 540
Dont really have a problem with the Samsung S23Ultra. I think the issue is of the phone cases are to thick it requires more power to charge which in turn causes extra heat.
01-25-2024, 03:14 PM | #22 |
Rep 3,723
I charge my iPhone 13pro on office desk, on this cheap wireless charging stand. Usually playing YouTube music, for 8+ hours a day, 4-5 days a week, no problem at all. Don’t even get a bit of warm.
2022 G05 B58/PHEV
