ZPOST
  TireRack
      11-06-2023, 04:45 PM   #177
Z4Kevo
Z4Kevo's Avatar
85
Drives: 2007 M Coupe
Originally Posted by bimmernut9002 View Post
I decided to temporarily mount the PEMP unit without bonding the 2 pieces together, just to try it out for a while. The right side had pulled away from the bed during early stages of printing and will need to be reprinted. I think it looks pretty good and is very solid given that each side securely mounts to the PEMP and they each attach with screws to the dash. I wonder how it will hold up when the weather gets warm?
How is your unit working out so far?
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather
Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android
      11-06-2023, 04:52 PM   #178
bimmernut9002
Drives: 2007 Z4 3.0si
Doing great! Solid and nice looking. Have already had several compliments. I think the real test of this PLA build will be the heat of the summer months. But until then, the car won’t get much use over the next several months of cold up here in NNJ
Z4Kevo84.50
      11-06-2023, 05:27 PM   #179
Z4Kevo
Z4Kevo's Avatar
85
      11-12-2023, 06:06 PM   #180
rsutoratosu
Drives: Z4 3.0i
These ali express seller are at it again. Theres a nice 12.3" larger than 10.25. I saw the ads from multiple sellers, they photoshop that unit on the e85, I ask them how it mounts and they finally said "does not work" despite it shows it being e85/86 or listed for e85/86. Just becareful with buying these units.
There was one guy that says it'll install but sent me e89 instructions
View post on imgur.com
-Roranji
Z4Kevo84.50
      01-07-2024, 08:52 PM   #181
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
I bought Z4Kevo spare PEMP screen and he was awesome including a few of his 3D printed trays. I ended up gluing the 2 piece tray together, used some plastic weld to even out edges, sanded the whole thing a few times and then plasti-dipped it. It came out to my satisfaction. The PEMP unit is truly plug and play, and I use it w Apple CarPlay. Couldn’t be happier considering the factory nav, a huge and welcome upgrade!
2007 BMW ///M Coupe
Appreciate 4
3798j11567.50
Z4Kevo84.50
      01-13-2024, 01:38 PM   #182
rsutoratosu
Drives: Z4 3.0i
Great fit!
-Roranji
Rekla106.00
      02-07-2024, 06:10 AM   #183
kooljitsu
kooljitsu's Avatar
Drives: BMW Z4 2.0i 2006
Rekla , how did you plug the radio so that you can have image from the original nav screen?
Best regards
      02-09-2024, 05:48 AM   #184
kooljitsu
kooljitsu's Avatar
Basically, I´ve been going through the available options, and the closest option I get for the Android systems are the ones that come with LVDS to CCC systems.
But CCC has a 10 pin connection, and the connection I have in my car is actually a 18 pin - as below picture.
Is there any chance to get the wires from CCC (10 pin) and map them to my 18 pin socket? Maybe buying a female 18 connector and changing the cable that comes with the Android radio...
Thank you in advance.
      02-17-2024, 07:39 PM   #185
tominizer
tominizer's Avatar
99
Drives: 2007 Z4M Roadster
This is pretty awesome. It really updates the car. One question. Does the baseplate in the design have to be that bulky at the front and side edges ?? This is not a criticism but more of a design and aesthetics question.
      02-26-2024, 12:48 PM   #186
feket663
Drives: BMW Z4 3.0i
My solution. I found stl file for a 7 inch android head unit console. My buddy 3D printed it. My audio system is a 10 speaker HI-FI, but non DSP. I connected android head units RCA output to CD changer input of original head unit. Works very well for me, the volume can adjust on steering wheel (original head units volume). Future plans: I bought wired, 7 switch steering wheel control from aliexpress, and I will install the non existing cruise control's place on steering column. And I will buy an USB-IBUS adapter, and I will see the car's parameters (with IBUS application).
Z4Kevo84.50
      02-26-2024, 02:51 PM   #187
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Do you happen to have the location of that stl file you found? I have a printer and wouldn't mind giving it a shot.
      02-26-2024, 10:49 PM   #188
feket663
Drives: BMW Z4 3.0i
https://cults3d.com/en/3d-model/vari...-radio-upgrade
Our03z41718.50
      02-28-2024, 05:03 PM   #189
Z4Kevo
Z4Kevo's Avatar
85
Originally Posted by tominizer View Post
...Does the baseplate in the design have to be that bulky at the front and side edges ??
Yes and maybe no.
The unit will only sit down into the dash so far before it interferes with things, so you end up having to transition from the dash to the base of the screen somehow and this was the most elegant way i could find without endlessly designing and redesigning the dash mount into oblivion.
Plus, since we are talking about a 3d part printed in layers you need a bit more material (or different material altogether...Nylon, ABS, TPU) to develop an acceptable amount of strength in the part itself. Unlike injection molded plastics you can't go too thin or it will be incredibly fragile and flimsy.
I made simple tradeoffs, that in the end, could likely be overcome if you had the will and skill to do so...both of which for me were in short supply.
      02-28-2024, 05:27 PM   #190
Our03z4
Thanks buddy! Do you know if your friend printed in PLA or ABS material?
      02-29-2024, 05:51 AM   #191
feket663
Drives: BMW Z4 3.0i
PLA isn't optimal for this purpose. Mine printed from ABS.
      02-29-2024, 07:33 AM   #192
Our03z4
Yep, just wanted to be sure.
      02-29-2024, 08:28 AM   #193
Z4Kevo
Z4Kevo's Avatar
85
I used PETG...and also tested with PLA+. So far it has reacted fine to the elements, but you can see it take on a slightly different shape (relative to the dash curve) as the south TX temps go up and down.
      05-01-2024, 08:35 AM   #194
Z4Kevo
Z4Kevo's Avatar
85
So far so good as the temps and humidity begin to climb...will update along the way!
      05-03-2024, 12:50 AM   #195
ANILE8
ANILE8's Avatar
180
Drives: Z4 M Coupé - Carbon Black
Originally Posted by CJW2OO4 View Post
I’m waiting on my friend to print me a piece. I’m sorry I am not well versed in 3d printing. Was the large single piece design not strong enough to support the nav screen?
Hello, did this stl file work with your Mekede?
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
      05-03-2024, 04:14 PM   #196
CJW2OO4
CJW2OO4's Avatar
Drives: E86M,M2,F13 E86&E85M,E86,2E46
I never got around to getting it printed
zpost
