      03-15-2020, 10:23 AM   #23
RO-CK
Drives: G07 / G20 / F22
Originally Posted by mjbillmeier View Post
What is the retrofit you are talking about? I just got a set of RDE077 from RGSport and am putting them on OEM 740m wheels. Was hoping these would be ‘plug and play’v
In my case, they were not plug and play, you have to code as per my instructions above...
Regards
r33_RGSport12971.00
      03-24-2020, 11:19 PM   #24
Nigel1500
Australia
28
Drives: BMW X5 (G05) 30d M-Sport
Hello Ben,
PM sent.
      03-25-2020, 10:44 AM   #25
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by Nigel1500 View Post
Hello Ben,
PM sent.
Replied.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      05-27-2021, 05:31 AM   #26
westan01
Malaysia
Drives: BMW X5 G05 45e
Greetings! g05 VO coding TPMS instruction needed for D.I.Y
Originally Posted by RO-CK View Post
Hello,
Just wanted to update this classified to confirm that the TPMS retrofit for the G05 series is totally doable, I've just completed this on my G05. You just need to get the TPMS sensors from Ben and VO Code 2VB (The process is exactly the same as the F series, the only thing that changes are the modules names)
So kudos to Ben, I've dealt with him before and highly recommend him
Cheers
Appreciate if you could share G05 VO coding instruction. I'm a new learner to get it done. Thanking in advance!
regards.
      06-11-2021, 05:14 AM   #27
Brett Nosse
Drives: X5 M50i Pure 2002 JCW Cooper
Hi is the price individual or a set? And do they show temps?
Thanks
r33_RGSport12971.00
      06-11-2021, 07:50 AM   #28
r33_RGSport
Thanks
Price for the set.
If your car is coded to show the temp, it will show the temp.
      06-16-2021, 09:38 AM   #29
Brett Nosse
Ok thanks. So does anything else need doing ie remove the tyres and fit them
r33_RGSport12971.00
      06-16-2021, 09:45 AM   #30
r33_RGSport
Just resync the new TPMS by resetting the tire pressure in the iDrive menu.
      09-14-2021, 05:21 PM   #31
Brett Nosse
hi guys, an Aussie car here that only has the ABS flat tyre monitor.
I have just got the sensors from Ben, and in bimmer code asked to show tyre pressure and temps, but its not showing the pressures still shows the ABS version. any tips?
Thanks Brett
      09-14-2021, 05:22 PM   #32
r33_RGSport
Thanks Brett
You need to VO code.
Bimmercode on FA coding.
      03-16-2022, 03:50 PM   #33
kerim
Drives: BMW
regards.
Thanks Brett
Im in Australia too and just installed these. Works perfect.
Added 2VB to VO then VO coded hu_mgu, kombi and bdc_body
After that, you can use bimmercode to code to show temperature and pressure
Thanks Ben for amazing service and product
      04-08-2022, 03:42 PM   #34
dananelson1
dananelson1's Avatar
226
Drives: 22 X5 45e, 13 X5xdrive50i SOLD
Hey Ben/ r33_RGSport
Just put an order in for these, just confirming these are install ready for any of the G05 series. Also, the standard shipping; is that UPS ground or USPS?
Cheers,
Dana
Originally Posted by r33_RGSport View Post
ph: 626-217-2161 | Email Us
TPMS Tire Pressure Monitoring Sensor
Click here to purchase
Beru/Huf TPMS for BMW G05 X5 | G06 X6 xDrive40i / xDrive50i / M50i
Gunmetal Valve Stem
Matte Black Valve Stem
** Picture is for reference only, actual product may vary.
CONDITION: BRAND NEW
ITEM LOCATION: SOUTHERN CALIFORNIA
r33_RGSport12971.00
      01-29-2024, 07:31 PM   #35
bym007
Drives: G30 540i
Hey kerim, fellow G30 540i in AW here from Melbourne. Tried to PM you, but unable to.
Currently drives a 2017 540i in Alpine White
Past Flames - gone but not forgotten
2017 540i in Black Sapphire Metallic
2012 Acura TSX Luxi Navi in Albaster Metalllic
2005 530i in Olivine Green Metallic
