      12-18-2019, 03:03 PM   #45
edofloat
edofloat's Avatar
453
Drives: Outback or 992
Originally Posted by zmm12345 View Post
Have you been able to verify that anti dazzle works? I coded anti dazzle back on, and the dashboard now shows the brights going on pretty often. However, i cant seem to tell them difference on the road, as opposed to when i flash my brights manually. I am wondering if the visual part and sensor is working, but I missed something causing it to not actually work.
I went from 03/2019.30 to 11/2019.40 and they still work and it is very obvious too. I will say that they are a bit more conservative as they don’t come on as quickly as before and seem a bit less active in some situations. It is easy at lower speeds to see them active and light up sidewalks or ditches as you approach traffic or traffic approaches you. It is also obvious that is creating tunnels around cars when you follow them as well. Sounds like you may have missed something.
      12-18-2019, 03:19 PM   #46
zmm12345
Drives: x7 and 330i
Thank you
I will try to code it again and see if that helps
      12-18-2019, 08:34 PM   #47
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
I went from 03/2019.30 to 11/2019.40 and they still work and it is very obvious too. I will say that they are a bit more conservative as they don't come on as quickly as before and seem a bit less active in some situations. It is easy at lower speeds to see them active and light up sidewalks or ditches as you approach traffic or traffic approaches you. It is also obvious that is creating tunnels around cars when you follow them as well. Sounds like you may have missed something.
Thank you
The "obviousness" of anti-dazzle in operation depends on the driving environment and driver attention. For example, 2 lane roads with trees on each side are likely to provide some of the most obviously observed behaviours. A well lit intra-city freeway, less so. Recoding won't hurt, however.
      12-22-2019, 08:05 AM   #48
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Originally Posted by randybobandy View Post
Not sure if it was already mentioned on here, since it's quite the thread...but for your Spotify people, you have it as it's own source when selection your media source. There's another option called "connected audio" or something like that...not sure if anyone knows what that is.
I am off my infuriating weeklong CarPlay re-trial — CarPlay is shit and dangerous, nothing improved, done with it. CarPlay now turned off in car and on phone again, just using iDrive and BT with an iPhone.
But to the comment, I also do have Spotify and Connected Audio new options in the Media/Personalize settings, but have no idea what if anything either does :
      12-22-2019, 08:09 AM   #49
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Originally Posted by ifr View Post
What about auto lane change? You gotta notice the difference in that
My comments on ALC improvements in software 11/2019.xx here for completeness: https://www.bimmerpost.com/forums/sh...php?p=25598726
It is much improved. Thanks for staying on me to re-try :-).
      12-22-2019, 08:25 AM   #50
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
To re-baseline the camera R/F view vs R/D gear selection discussion, what we now have appears to be:
- whether view change works properly depends on camera selection being in A (auto)
- on AU 11/2019.34, camera A is remembered and thus camera view switching works correctly
- on CA 11/2019.40, camera A is NOT remembered and thus camera view switching is broken
Wondering where to go from here ...
      12-22-2019, 08:40 AM   #51
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
I have to mess around with iDrive as my default over CarPlay. I just get pissed at the message handling, but I haven't really fiddled with it in a few months. The new audio sources are strange, I need to dig into that as well. I feel like one of the Hardy Boys when going through iDrive settings/options.
      12-22-2019, 10:21 AM   #52
homerrr
homerrr's Avatar
Drives: BMW G05
Finding the difference in the CAFD file is where, there's got to be an easy way to force A as default
      12-22-2019, 10:27 AM   #53
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Yap. Haven't been successful yet against my own working 03/2019.45 as a) I am a rank amateur at coding discovery so don't yet have an efficient process flow, b) it's time consuming and no time, and c) there are a fair number of FDL parameters differences between the two widely separated versions and if there is a value, it is buried in that.
Would love to get someone's working 11/2019.xx FA, SVT, and all NCD files to compare or happy to provide mine. Asked this a few times without success yet.
homerrr133.50
      12-22-2019, 03:32 PM   #54
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
What do you have set for
8081\\C_XV3D_COUNTRYVARIANT_NEXTMODE
If 01 then change to 00
LexxM31698.50
      12-22-2019, 03:54 PM   #55
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Hm, interesting. Mine is 01 (aka USA). Coding machine and car are not near each other right now, but will try changing to 00 (aka allgemein aka "general") and see what happens.
If this works, why do you think BMW is punishing USA with bugs? Is that for spite? And follow on question please ... besides my personal public attitudes towards BMW Canada, why do think BMW is punishing all of Canada by lumping our camera coding with "those Americans"? :-)
I'll ask more serious questions privately.
ifr1198.00
      12-23-2019, 10:42 AM   #56
TK421BMW
114
Drives: BMW 328, X5, Z4
Just had 11.2019.40 put on mine and now the pathway lights don't turn on when I get close. I thought there was a setting for that, but I don't see it anywhere anymore.
____________________
Current:
2019 g05 X5 xDrive40i
2020 f30 440 xDrive Convertible
2004 e85 Z4 3.0
      12-23-2019, 10:57 AM   #57
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Unfortunately, did not help. And I was incorrect, my 03/2019.45 8081 NCD also had this set to 01/USA. :-(
      12-23-2019, 10:12 PM   #58
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
While @ifr's suggestion didn't work (yet) for the normal R/D view switch and I've reverted coding back to stock "USA" setting for this, I got to testing more of the camera view functionality. And what do you know, the buggy functionality I was complaining about before regarding view selection when using the PDC activation button now appears to be fixed! That is, when you press PDC button, the camera view is now reliably in A mode and correctly follows D and R gear selection.
You lose some, you win some? But only in some countries? Weird.
      12-24-2019, 02:18 AM   #59
ifr
ifr's Avatar
United Kingdom
1198
That's going to need some more testing as it could depend on another activation switch. The code referenced above is specific to your scenario and the comments align with that, in a dodgy google translate at least
"If true, the restriction applies: The system must always show a view to the rear when reinserting"
You definitely don't want the USA behaviour for that setting. What else did you change to get it working? Was the car allowed to sleep between coding sessions?
I guess I could break mine to confirm it definitively when I get chance.
LexxM31698.50
      12-24-2019, 06:51 AM   #60
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
If you mean to get PDC button activation view switching working correctly, I believe it started working with update to 11/2019.40, not any coding. I just didn't look closely enough beforehand.
If you mean the "country nextmode" change from USA to general, then yes, the car was allowed to sleep between coding to general and testing of D/R switch — coded in the evening, tested next day. Didn't realize the deeper reset of sleep might be required in some cases, but I guess makes sense — learning something new every day, thank you.
From your private notes, I agree that USA is not the correct setting. I only reverted back temporarily to get back to baseline for now.
      12-24-2019, 07:05 AM   #61
ifr
ifr's Avatar
United Kingdom
1198
OK. I've not tested the setting as mine works fine, just seemed to fit the scenario.
I'll take a more detailed look over the hols if I get the time. Try to 'control' the behaviour at will through coding.
Sleep isn't normally needed, but its good practice to ensure the relevant ECU(s) have 'reset' before testing. Some coding doesn't take affect until that happens
LexxM31698.50
      01-12-2020, 10:40 PM   #62
mikenyc
Drives: 2016 i8 Giga, 2019 X5 40i
Wrong
Anyone seen that message after recent update , it asking me to purchase auto high beams option while I already had it for the past 12 months and it's part of my package.
96 520i, 99 330i, 00 325i, 03 X5 3.0i, 06 X3 3.0i, 07 530i, 09 X5 4.8i, 10 M6 Conv, 11 X5 50i,
11 535xi, 14 X5 50i, 14 328xi GT, 16 X6 50i,
16 i8, 2019 X5 40i, 18 328d xi, 21 X5 40i,
22 X6 40i
      01-13-2020, 07:16 AM   #63
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Do your auto-high beams perform as expected?
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      01-13-2020, 09:09 AM   #64
mikenyc
Worked just fine and as expected before software update since delivery back in January, I think I had old version something like 10.2018. They basically disabled my auto high beams with this update and as soon as I'm trying to activate this option with our usual button on a left side, I'm getting this error message.
22 X6 40i
      01-13-2020, 10:09 AM   #65
randybobandy
Rick James
305
That’s weird. I never saw that before. I tried to check CD’s website store to see if I could find it...nothing!
      01-13-2020, 12:12 PM   #66
W0ut
Belgium
244
Drives: BMW G05 X5 xdrive45e
My car got upgraded to 11/2019.40 today.
The drive recorder 'as a service' now works. Didn't order it on the car but bought the app on the connected website. With the 07/2019.55 it didn't work. now it does.
First impression is that the surround view is much improved. The indicator bars are much faster/sensitive than before.
