06-25-2020, 10:31 AM | #23 |
1053
Rep 1,952
Maybe take the car to the dealer and say you're having issues with CarPlay so they'll update your istep version to a newer one. That should put you on the same level as everyone else and probably be able to VO code w/o issues.
06-27-2020, 09:20 AM | #24 |
267
Rep 345
Drives: 2019 X5 40i M
Update
After spending more hours than I would like to admit, I think the issue actually is the most recent software. I have compared files and tried every setting imaginable and have even coded FLMs and KAFAS to full ECE spec - no luck. FYI, coding KAFAS to full ECE spec will cause problems with the early warning systems, unless you later FDL code all measurements to MPH.
I purchased the car as a CPO on 4/30. Although it was built on 11/18, the dealer installed software version 03/2020.40 when they did the CPO certification. I have confirmed that a car built on 8/18 was able to VO Code Anti-Dazzle so the age appears to be out. On the flip side, I have yet to identify a US car that has the most recent software where the Anti-Dazzle is working. As many have noted, some of our coding features no longer work after certain upgrades. I can only suspect that is what I am dealing with and why no one has been able to solve otherwise. Accordingly, folks with this software may not be able to activate Anti-Dazzle. If you have coded previously and update to this software, I have no idea what will happen. If someone has this software and has been successful activating it, please pm me and I will continue to evaluate. Otherwise, I am giving up for now and will just enjoy the effectiveness of the lights with the VLD activated. Thanks to all that helped me on this project, especially VTEGNR.
2019 X5 X40iM
06-27-2020, 01:22 PM | #25 | |
1053
Rep 1,952
I wonder if the issue could lie with the PSdZData file. Have you checked to make sure you have the most recent one? What's VLD? |
06-27-2020, 01:50 PM | #26 |
267
Rep 345
VLD is Variable Light Distribution. The following are located in BDC_Body3 in 1DF8. It resulted in my lights being much more active, even without Anti-Dazzle.:
C_AFS_ECO_LEVEL_3_ENA: enable [01] C_AFS_ENA: enable [01] C_BLC_PRE_ENA: enable [01] C_CLC_BLINK_ENA: enable [01] C_CLC_CURV_V2: ECE [23] C_CLC_CURV_V3: ECE [28] C_CLC_EXT_ENA: enable_roundabout [01] C_CLC_REV_ENA: enable [01] C_HBA_GFHBA_ENA_V_HI: standard [3C] LUT_AFS_CODRV_HOR: G05_Laser_ECE [00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00 00 03 03 00 00 00 00 00 00 00 00 00 00] LUT_AFS_DRV_HOR: G05_Laser_ECE [00 00 00 33 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00] LUT_FLC_FORWARDLIGHTING_Y: AFS [00 00 00] I will double check psdz but it was the most up to date on April 6 when I downloaded it from Shawn. Version v.4.22.41_PSdZData_Lite. What is the latest?
2019 X5 X40iM
06-29-2020, 10:20 AM | #27 |
Rep 2,609
See here (and follow on posts) for a Canadian member removing anti-dazzle 5AP decode with successful results on 03/2020.30: https://www.bimmerpost.com/forums/sh...php?p=26373670
Not quite Trojanlaw's 03/2020.40 and Canadian, but I can't see there being a minor version discrepancy and Canadian and US cars are identical in this presence of 5AP decode.
mandomedic12240.50 |
06-29-2020, 10:39 AM | #28 | |
Rep 2,609
However, I can tell you that 4.23.12 supports up and including 03/2020.41. Therefore, chances are really high that your 4.22.41 is too old to support 03/2020.40 that you have installed in your car. Good lesson for all of us: second check upon failed coding should always be to check the psdzdata version (first check is the coding itself, of course).
06-29-2020, 10:43 AM | #29 | |
1053
Rep 1,952
06-29-2020, 10:49 AM | #30 | ||
Rep 2,609
06-29-2020, 10:56 AM | #31 | |
1053
Rep 1,952
06-29-2020, 10:59 AM | #32 | ||
Rep 2,609
06-29-2020, 11:56 AM | #33 |
267
Rep 345
FYI I updated to 4.23.13 and no change.
I will keep searching for an answer.
2019 X5 X40iM
06-29-2020, 01:00 PM | #34 |
Rep 2,609
And just to double-check, you are sure that with your updated setup there are no ECUs now remaining that were coded with the wrong psdzdata from before?
06-29-2020, 05:29 PM | #35 |
267
Rep 345
Yes I did.
2019 X5 X40iM
06-29-2020, 05:45 PM | #36 |
Rep 2,609
Crap. Does that then just leave the very early build date and/or some kind of a weird defect as remaining theories?
Update: never mind the early build date, you seemed to have ruled that out earlier in the thread. Frustrating.
06-29-2020, 06:20 PM | #37 |
267
Rep 345
Still have the 03/2020.40 software theory but am checking that out further.
2019 X5 X40iM
06-29-2020, 08:33 PM | #38 | |
Rep 2,609
It's reported success on 03/2020.30, so not quite .40, but I really don't see something as big as this being a minor version change, even accidentally.
06-29-2020, 08:43 PM | #39 |
267
Rep 345
Did not see. Thank you.
2019 X5 X40iM
07-09-2020, 02:08 PM | #40 |
1198
Rep 1,587
I think you can now buy HBA retrospectively via Connected Drive Store (where allowed), and as such there was a technical campaign to import the KAFAS FSC in support of vehicles programmed to i-step 07/2019 and later.
Hypothesis is if you never purchased HBA/had in your FA at the time your i-step was upgraded then they would not have imported the FSC and your coding will not work. It's a possibility. Maybe worth checking your KAFAS FSC and compare with a known good. |
LexxM31698.50 |
07-09-2020, 02:49 PM | #41 | |
Rep 2,609
07-09-2020, 03:08 PM | #42 |
267
Rep 345
What is my KAFAS FSC? Sorry if this is a dumb question. Moreover, can I import it?
2019 X5 X40iM
07-09-2020, 03:24 PM | #43 |
267
Rep 345
That would not explain how a car produced prior to mine in the US was able get it working. That said, I would love to research this issue further. Please advise how to check.
Thanks
2019 X5 X40iM
07-09-2020, 06:08 PM | #44 |
1198
Rep 1,587
I'll check the code tomorrow.
My dealer messed up with the DSC VIP FSC as part of the 11/2019 upgrade and now I can't code that. Kind of hard explaining to them why it needs fixing, but the point is it can also be human error. The programming release notes explain the HBA/KAFAS issue |
