View Poll Results: What type of installation would you want? | |||
I'm good with powering through USB | 7 | 31.82% | |
Hardwire 12v into fuse | 12 | 54.55% | |
Mirror tap type power | 6 | 27.27% | |
Multiple Choice Poll. Voters: 22. You may not vote on this poll |
04-15-2021, 12:23 PM | #67 |
Rep 264
Last Saturday I picked up my new X6 from the dealer and drove it around for a couple of days. No tint on the front windows and noticed no dimming. Wednesday I brought it back to the dealer and asked them to tint the front driver and passenger windows to match the back windows. Picked up the X6 last night and can't see the dash Too dim lol.
I may need one of these gizmo's
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow |
04-15-2021, 12:26 PM | #68 | |
Rep 264
2019 M5 Competition
04-15-2021, 12:41 PM | #69 | |
Rep 217
04-15-2021, 07:15 PM | #70 |
Rep 8,815
How does the bezel around the digital cluster come out? does it just pull out starting from the bottom?
04-15-2021, 07:56 PM | #71 | |
Rep 217
All that being said there is no need to remove it for my stuff. I designed a tab that slides between it and the screen to hold the mount. |
04-15-2021, 08:14 PM | #73 |
Rep 217
04-21-2021, 03:41 PM | #74 |
Rep 217
Alright, latest revision of the board came in and at least initial programming looks to be good! I need to get the unit in my car swapped and then I can assemble the rest of the boards I have.
Here's a comparison of the size of the latest revision, green board is the last one and the blue board is the newest one. Also you can see the OLED screen I added for testing. Purely so i can see what is going on without needing a computer hooked up. The OLED is just under 1" to give you an idea of the size. |
04-22-2021, 08:13 AM | #75 |
Rep 76
As I've said before, really incredible. Cannot wait to see the final version.
One question. If I understand this whole process correctly, there is a light that will shine on the sensor. What is the life expectancy of it and what happens if/when it goes out?? Easily replaced? |
04-22-2021, 09:12 AM | #76 | |
Rep 217
nZtiZia4656.00 |
04-23-2021, 07:34 PM | #77 |
Rep 425
BTW - found a temp workaround. Kinda silly really, but ....
I attached an air-vent phone holder to the vents to the left of the dash - turned on the flashlight on my phone - voilà I am using on cloudy days or at dusk only on 15-20 min drives. Other than driving down the battery on your phone... no real drawbacks. |
04-23-2021, 07:38 PM | #78 | |
13276
Rep 19,805
leightos188.50 |
04-23-2021, 07:54 PM | #79 | |
Rep 217
No glare on screen from the flashlight? |
04-23-2021, 08:36 PM | #80 |
Rep 425
04-30-2021, 09:15 AM | #82 |
20
Rep 44
Tinted my new X6 and it can be a bit dim, especially when it is cloudy out and I have sunglasses on. I'm looking forward to seeing this in action.
Do you have to remove any trim to get this installed? I'm looking for it to be as simple as possible in terms of wiring and installation. Wiring is always a big concern for me because if something goes wrong, the dealer isn't going to be the one paying for it. |
04-30-2021, 09:25 AM | #83 |
Rep 8,700
Drives: eVeRyOnE mAD!
04-30-2021, 10:15 AM | #84 | |
Rep 217
As for trim, you don't have to really remove anything if you don't want to, just depends on how clean of a install you want. I've been scrambling the last 2 weeks to get our house ready to list. I have to be out all weekend for showings, so i'm taking the boards and all my tools and will be assembling the boards I have and getting the mounts and cases together. So... hopefully by end of weekend I should have some boards ready to go! |
Superman75020.00 phillydilles74.00 |
05-01-2021, 03:05 PM | #85 |
Rep 217
3 boards build, programmed and tested! Working on the new case design since the board is smaller, had to make a new case.
05-01-2021, 04:21 PM | #86 |
Rep 8,700
shotgun!
05-03-2021, 06:40 PM | #87 |
Rep 6
Display dimming along with idrive due to window tint
I found a temporary solution that worked for me right now. Purchased a small LED light this may sound odd but got on Amazon. It is a small astronaut on a flexible mount the flex is about 10” long. The little guy is mounted on the right side of the dash lip with Velcro and used a longer USB cable to connect to the flex cable and ran to the back cigarette lighter but using a adapter for that with USB ports to plug the cable into. Works excellent. Need to plug and unplug each time you start the car and leave the car so it does not affect the battery life in the car. Trying to take pictures to attach but not working well. . Let me know if you need any info or if the pics did not take I will retake with my phone not iPad next time.
05-03-2021, 06:57 PM | #88 |
Rep 6
Dim display and idrive dimming
Found a temp solution using a small LED light to mount on lip of dash display on right side. Their are two on the light sensors left side and right side. I chose the right so I could run a usb extension cable to plug in back console. Works great. Just need to plug in and unplug when leaving car.
