      01-31-2024, 07:43 AM   #1
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
iDrive 8.5??
With the LCI M4 announcement yesterday for MY2025 getting iDrive 8.5, when will BMW update the F95/F96 platform from iDrive 8.0 to 8.5 as all referenced platforms now have the MGU5 head unit. Maybe for MY25 which SOP is 3/24 is hopeful?
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD
      01-31-2024, 07:49 AM   #2
S68 X5MC
DD214
S68 X5MC's Avatar
Drives: 2024 X5M Competition
The LCI F95/6 has the 8.5 update. The pre-LCI should have an update available to upgrade yourself. If you can't, BMW will release it so users can load it themselves at a later time. Otherwise you'll have to go to the dealer and get the 8.5 loaded on your pre-LCI. One more way for them to make you pay for an hour to load it.
      01-31-2024, 07:51 AM   #3
Ibiza
Ibiza's Avatar
Originally Posted by S68 X5MC View Post
The LCI F95/6 has the 8.5 update. The pre-LCI should have an update available to upgrade yourself, but if not yet it'll be coming from what I've read. Otherwise you'll have to go to the dealer to get the 8.5 loaded on your pre-LCI.
Then the LCI M4 has the half-way iDrive 8.5 without quick select.
      01-31-2024, 07:55 AM   #4
S68 X5MC
DD214
S68 X5MC's Avatar
I think all M models have it removed. I'd never use it to be honest, I select a route before I drive and I can control music with the wheel. There's also voice that can be used for that stuff. It's just more junk for people to play with when they should be driving with the quick select.
      01-31-2024, 08:20 AM   #5
Ibiza
Ibiza's Avatar
Quick select is a compromise for losing the 8 haptic touch keys as the M’s with iDrive 7 had no issue and were the same as ghe series production cars.
