BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > DFFF -- Dont Fear the Fuel Filter
      04-11-2014, 06:02 PM   #89
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
Originally Posted by Socom View Post
Yes. Filters get better as they collect whatever is trying to pass through them.
Few people know that the particles stuck in the filter actually ripen and give off cleaning agents which, as a natural byproduct, improve the cetane rating of the diesel passing through it and fight CBU over time.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
      04-11-2014, 11:03 PM   #90
rogerdiaz
Drives: 2015 335i
So whats an appropriate interval? Service book says every 2nd oil change.
      04-12-2014, 08:00 PM   #91
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Then go by that.
      04-13-2014, 10:55 PM   #92
sergiy'd
Drives: 2011 bmw 335d
on my block the dealer keeps putting it off, I had 3rd oil change under my ownership and still NO replacement of fuel filter
called around there is no way of convincing them to do it, the tech makes a call and it does not matter if you tell them about the service journal 2nd oil change interval
"the Fob does not call for it"
      04-14-2014, 12:34 AM   #93
bdwyer
bdwyer's Avatar
Drives: '11 335d
I feel like I saw 30k somewhere... every other sounds good but ill be doing mine every 3rd as I do oil changes at the 8k mark and 16k sounds a bit short for these.
'11 335d Sport
CCNP, MCITP-EA
      04-24-2014, 09:05 PM   #94
rogerdiaz
Drives: 2015 335i
I can't find the reference but I got in my head the factory interval oil change for the diesel is 13,000 miles, while the gasoline is/used to be 15,000 miles.
So that means new fuel filter every 26k per factory service manual recc.
      04-25-2014, 05:43 AM   #95
335dFan
Jumping Jack Flash
335dFan's Avatar
Drives: 2021 X3 M40i
They changed mine at 25k miles based on the key fob. That was even before the second oil change at 27k. But the oil change delay was because they screwed up the computer.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      06-02-2014, 02:05 PM   #96
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
So even more confusion for this part. I'm being told that for my model year, the part # has changed to:
13-32-7-802-939
And that I'm looking at $250 for it.
EDIT: Turns out that includes the heater too. My bad.
      06-06-2014, 01:35 PM   #97
modobrew
31
Drives: 2011 335d M Sport
So is there any tool out there that works to vent/prime the HPFP for model years newer than 09? I have a 2011 and it appears the BT tool doesnt support models newer than 09. I'd like to change the FF myself, but I dont want to run the HPFP dry....
      06-06-2014, 02:33 PM   #98
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
FYI, I talked to the BT support people late last week; they said they've got the new software that supports 335d/2010+ and newer F3x cars out there in beta test and will be rolling it out within the next month.
I have a Windows phone; no BMWhat for me.
      06-10-2014, 06:55 AM   #99
modobrew
31
thanks for this bit of info. I had the dreaded SES light come on last Friday. Car is going into the shop tomorrow. P02CE, "Cylinder 2 Fuel Injector Offset Learning At Min Limit". Looks like carbon build up has bit me.
      06-10-2014, 07:04 AM   #100
TDIwyse
Drives: 2011 335d
I've used the Bavarian Technic tool to prime the fuel pump on my 2011 335d. Many times. From back on post 7 of this thread:
http://www.e90post.com/forums/showpo...15&postcount=7
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      10-11-2014, 05:25 PM   #101
GreekboyD
411
Ya. I've read/heard anywhere from 30-45 k miles but it's hard to get a concrete answer.
      08-26-2015, 05:47 AM   #102
temporaptor
temporaptor's Avatar
64
Drives: 11 335D MSport / 12 X5 35d
Changed the Fuel Filter on my buddies 335d.
thought I would contribute alittle.
      08-27-2015, 11:28 PM   #103
kg4kdn
Drives: 2011 335d
Originally Posted by Quasimodem View Post
see attached photo.
BMW loves those damn clamps. They are all over my K1200S motorcycle too
2011 335d:Mostly stock for now
2007 BMW K1200s: PCIII
      08-28-2015, 06:40 AM   #104
Mik325tds
Mik325tds's Avatar
Drives: 335d M-Sport
Glad to see people are actually using my instructions. For those of you having trouble seeing the actual job in Ediabas, here is the written post:
http://www.e90post.com/forums/showpo...2&postcount=90
      10-11-2015, 06:13 PM   #105
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
Just replaced the filter today.
After removing the under body panels (Jess refers to them as alien muff) I undid the bolt securing the filter to the frame. Clamped the outlet hose and put the filter nipple from the new one onto the old one to keep it from leaking everywhere. Pulled off the other end of the filter and plugged the end it with my finger. Quickly put the other filter in its place and started securing everything. Lost 10 or so drops of fuel.
Cranked the car for 2-3 seconds and shut it down and waited a minute. Repeated. And it started on the third attempt. At most it cranked for 7-8 seconds before purring like a kitten.
Total time about 2.5 hours - oil change at the same time and I was not in a rush since it's my first time with this fuel filter.
      10-12-2015, 01:02 PM   #106
BB_cuda
BB_cuda's Avatar
767
Drives: 2011 335D Msport, 2013 X5D
Mahle FF part number KL 579
I bought several things from IDparts.com back early this year including the fuel filter, air filter, and 2 oil filters. After reading the thread (particularly where Greek talks about Mann 519), I'm concerned if this Mahle part is proper. I'm Googling around but though I'd ask if anyone had used this part. thanks.
      10-12-2015, 02:29 PM   #107
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
I have a 2011 and the filter I used and took off were 519
      10-12-2015, 05:00 PM   #108
Yozh
Yozh's Avatar
870
Drives: 2011 335d M-Sport
Mahle and Mann part numbers could be different as long as they cross reference the same bmw part number you should be good.
      10-12-2015, 06:43 PM   #109
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
Bavarian Autosports sells a Mahle KL579D fuel filter for the 335d. I don't see the "D" on the photo you posted.
      10-12-2015, 07:01 PM   #110
BB_cuda
BB_cuda's Avatar
767
Quasi modem, the box is marked KL579D but filter marked is as you say. On rock auto, they show this part is for 2009-2010. I feel this is the same story as WK519 vs WK5001. I'm not going to chance it and go buy the WK519
