09-01-2022, 05:07 AM | #46 |
S0THPAW
8719
Rep 7,846
09-01-2022, 11:09 AM | #47 |
Rep 4,445
Anyone notice how the FIA President chases photos with pilots?
He cornered Sir Lewis after qually and yelled to Officer Max Emilian Verstappen post race. Strange referee. Is it true, Jos Verstappen zit met Covid-19 thuis op de bank?
09-01-2022, 03:01 PM | #50 |
Rep 3,705
09-01-2022, 04:51 PM | #51 |
60267
Rep 19,604
09-01-2022, 06:48 PM | #52 | |
63521
Rep 24,703
True , I heard it yesterday . Jos Verstappen got a COVID infection . Further he said : Damn ! Next weekend It's Zandvoort and now I must watch the race on TV ! Damn COVID ! I mean , I can know what it is ! I wish Jos a speedy recovery ...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 09-01-2022 at 07:17 PM.. |
09-01-2022, 09:56 PM | #53 |
Rep 4,445
I knew you would have the information. Bad timing.
///M Power-Belgium63521.00 NYG10802.00 |
09-01-2022, 10:01 PM | #54 |
Rep 4,445
Track information and setup
Circuit Park Zandvoort
Route length: 4.259 kilometers Number of curves: 14 (4 left, 10 right) Number of rounds: 72 Total distance: 306.648 km Pirelli tires: C1, C2, C3 Distance pole to first braking zone: 247 meters Pit lane length under speed limit: 235 meters (~14 seconds). At 210 meters it is the shortest pit lane on the calendar. At the prescribed speed of 60 km/h, it takes just 12.6 seconds to drive through. Lap record (race): 1m 11.097s (Hamilton, 2021) Top speed: 328 km/h Car setup There are technically demanding sequences that require mechanical grip. Like Turns 3, 11 and 12. Here you need traction from the slow corners. The many fast corners require downforce. A compromise of medium to high level of downforce with larger wings than last time at Spa-Francorchamps. The cars must not be too low for the laps in the dunes because the asphalt isn't flat. For example, there is a nasty bump in the area around turn 6 (Rob-Slotemaker-Bocht). Pirelli supplies the hardest mixtures (C1-C2-C3). At a minimum, teams must inflate the front tire to 23.5 psi. A minimum of 21.5 psi is required for the rear. Most will use to a one-stop strategy. There aren't long straights in Zandvoort. In order to increase the chance of overtaking manoeuvres, the FIA wants to try out in free practice on Friday this year whether the DRS can already be released in the banked target curve so that pursuers can catch opponents over a longer distance. Last year FIA did did not take this risk of a longer DRS zone. The DRS zone only began on the home stretch.
09-02-2022, 02:17 AM | #55 |
60267
Rep 19,604
Max was knighted by the Minister of Sport Connie Helder in Amsterdam.
https://www.gpblog.com/en/news/13110...s-touched.html |
09-02-2022, 05:07 AM | #56 |
63521
Rep 24,703
Yeah , It's really bad timing . I know it already 2 days ..Too bad for Jos ! Jos Verstappen : I don't want to put MAX in danger ! The Dutch article => https://f1journaal.be/jos-verstappen...evaar-brengen/
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-02-2022, 05:12 AM | #57 | |
63521
Rep 24,703
09-02-2022, 05:16 AM | #58 |
60267
Rep 19,604
09-02-2022, 05:24 AM | #59 | |
63521
Rep 24,703
SPA was low downforce and extremely fast at the long straights ! Zandvoort is completely otherwise .Zandvoort is a high downforce track . By the Zandvoort high dowforce setup , Ferrari and Mercedes will be faster than at SPA . One thing is for sure : MAX is ready for the fight !
09-02-2022, 05:42 AM | #60 |
#buildnotbought
10877
Rep 4,895
Oops, broken gearbox for Max.
Being FP1 I expect this is an old gearbox, not one that was prepped for race.
09-02-2022, 05:58 AM | #61 |
60267
Rep 19,604
09-02-2022, 08:42 AM | #64 |
Rep 2,640
They used a very worn out practice gearbox (every team uses a spare gearbox for practice only, then switch to main gearbox for quali+race)
So no penalty, and he should be out and about in FP2. I think Mercedes may be able to snatch some points from Ferrari this race, I think they might be able to end up P3-P4, maybe P2-P3 if Perez isn't looking good for race pace, but realistically P3-P4 for Mercedes.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
NYG10802.00 |
09-02-2022, 08:47 AM | #65 | |
Rep 3,705
Robin_NL send me some stroopwafels. |
M5Rick60267.00 ///M Power-Belgium63521.00 |
09-02-2022, 10:19 AM | #66 | |
Rep 2,640
But considering Max only had 7 laps in FP1 vs other teams 30+, I think FP3 and qualifying will be different. Both Mercedes and Ferrari looks strong on this circuit but it's a high downforce track so it's to be expected.
