04-03-2020, 10:50 AM | #23 | |
83
Rep 343
04-03-2020, 10:51 AM | #24 | |
83
Rep 343
04-03-2020, 01:09 PM | #25 |
Rep 4,337
I had a very similar issue that was especially prevalent when turning the wheel as in backing out of or into a parking space but also just before coming to a complete stop at a red light/stop sign. Turned out to be the fluid in my transfer case. Once changed, the problem never came back. This was on my X3, BMW diagnosed it and changed the fluid. The shop foreman drove the car, I rode as a passenger and we did lock to lock turning circles in his parking lot, I think he knew what it was once he felt it for himself.
04-03-2020, 01:38 PM | #26 | |
83
Rep 343
What exactly was wrong with the fluid that caused this? |
04-03-2020, 02:40 PM | #27 |
Rep 4,337
I don't know the root cause of the fluid issue and was surprised when the shop foreman said he thought that was the reason for the vibration/shudder. The car was under warranty so it didn't matter to me what he did, I knew that in the end the warranty would cover whatever the solution turned out to be. To go a bit deeper in this story, the same service center first disconnected the electrical cable that connects to the transfer case and then took it out for a drive and the vibration was gone so they replaced the transfer case. That worked for about a week! When the vibration returned, I brought it back and they changed the fluid after talking with someone over the phone, don't know who they called. The fluid change did the trick, its been vibration free now for 40K miles. So, was it the viscosity? Fluid makeup? Brand of fluid? Dunno, sorry.
04-05-2020, 09:16 AM | #28 |
Rick James
305
Rep 784
I had the same issue and pointed it out to my service people when I took it in for oil and all...I guess there's nothing BMW is acknowledging...yet, but I would definitely go get it documented. I guess my service department has seen a slew of similar complaints with the X5/X6/X7...no "official fix", but trying to protect myself down the road if it becomes a bigger issue.
04-05-2020, 10:03 AM | #29 |
Rep 9
I disabled the transfer box(VTG) today through the official diagnostic program (ISTA). The vibration is gone! As soon as I switched the transfer box(VTG) back to normal mode, the vibration reappeared. I think you need to change the oil in the transfer case(VTG) and check the oil level.
04-05-2020, 10:07 AM | #30 | |
Rep 668
04-05-2020, 11:56 AM | #31 |
Rep 2,072
04-05-2020, 06:00 PM | #32 |
Rep 9
I experienced similar vibrations to the ones described here on a non-BMW SUV several years ago. A transfer case swap definitely fixed the issue.
The posts of Marty in NY and m.tym seem to go on the same direction. It would be great to see if somebody on a sDrive G05 feels those vibrations too. If on the sDrive the vibrations are not present at all, you got the answer guys. |
04-05-2020, 10:41 PM | #33 | |
Rep 60
Drives: 2020 X5 MSport, 2018 330i
XDrive....especially previously mentioned in lock to lock scenarios....binding....4-wheels fighting each other. Should it happen...no..does it...yes. Not sure how the fluid would fix it....possibly a different weight. I'm no scientist. All my X5s have been Sdrive. Don't need the extra 2 in South Florida. My best friend is a BMW Master Tech....he told me about BMW having issues with drive shaft balancing causing this vibration people are speaking of here. Happening under acceleration and heavier "load" such as hard acceleration on an uphill on-ramp, a shudder and a helicopter like noise. This was a couple years back when he told me about a couple F15s he noticed this problem in. I never experienced this personally but he's got 10+ years with multiple BMW dealers and a BMW racing team. I believe him. Anybody else heard of this?
-C
04-06-2020, 08:25 AM | #34 | |
Rep 4,337
The G01 X3 forum also complained about vibrations felt at the steering wheel when going through 50-55mph and once the car reached an ave mileage of 5,000. Dealers tried everything they knew but could not resolve it on those cars that had it...not all G01's experienced it. Though AFAIK, root cause was not reported, the closest cause was leading to a design misalignment somewhere in the rear drivetrain (differential, differential welded mounting points and output shafts). One dealer, I think in Florida, loosened all the bolts securing the rear drivetrain components, let the components resettle and tightened them back up. They many also have drilled new mounting holes but I can't seem to recall off hand for sure. That seemed to have resolved that owners vibrations. In the meantime, dealers were replacing plenty of left and right output shafts which gave the owner a temporary fix till they hit another 5,000 miles at which point the vibration returned. Plenty of wheels were being balanced, alignments done, all sorts of thing but nothing seemed to resolve the issue. Some owners got BMW to buy their car back. Just go to the G01 forum and search for "steering wheel vibration". The thread seemed to die but at last count, issues were reported on both the M40i and the 30i, mostly 2018 models but also on some 2019's. My issue was different than X5_CC's, more like karateboi87, as I posted already. However, for those with the X drive (transfer case), its a simple test to disable the transfer case and test drive the car. If S Drive owners are having this vibration issue, it's a different story as they don't have a transfer case so then one starts thinking about drive line components and their couplings, not wheels and tires because you can drive through rotational vibrations caused by an out of balance issue but such is not the case with acceleration issues. |
04-06-2020, 10:43 AM | #35 | |
83
Rep 343
And yes I have XDrive, as I assume the vast majority of owners here do (except those in Florida, Texas, SoCal, etc). |
07-14-2020, 09:40 AM | #36 |
Rep 5
BMW X6 G06 vibration 2nd gear
I got my brand new X6 30d just a week ago and I notice the same vibration when accelerating in 2nd gear as some of others described in this thread. In 1st or 3rd gear very smooth, only in 2nd and only when accelerating at 3/4 or stronger throttle. Has anyone got some fresh information on this? Is it "normal" or is there a fix to this?
07-14-2020, 10:02 PM | #37 |
Rep 441
Drives: BMW
I have a 20 sdrive and i feel vibrations thru the STEERING WHEEL and not the car. It feels like a shudder that shoots to the steering wheel.
Yes it only happens when i accelerate(i want to say around 30-40mph, never purposely tried to duplicate the issue) and has never happened on slowing down whether braking or cruising. It only lasts for half a second, maybe one second if that. |
07-17-2020, 06:23 AM | #38 | ||
Rep 208
yachtmaster780.00 |
09-01-2020, 07:07 PM | #39 |
Rep 296
Drives: M3 Competition (G80)
The first time I noticed it was during a launch run. I was very noticeable as you could feel it going from smooth to the vibration. Almost felt like something was wrong. I have launched it 3 other times and never noticed it.
I have an M50i Xdrive. Not sure if anyone else is feeling it when they do a launch. I will now be feeling for it under no launch acceleration. I do not have any of the vibrations at low speeds or turning, as mentioned by other posts. |
01-12-2023, 08:34 PM | #40 |
Rep 104
Just recently been having the same issue as some of you guys have experienced.
I feel the car shakes ever so slightly when moving off - especially between the 10-30mph range, around the 3/4k rpm. I have a oil service and vehicle check service coming up soon, did the transfer case oil change fixed the issue for most? |
okarch4.00 |
01-13-2023, 08:27 AM | #41 |
Rep 773
My 2019 had the vibration when accelerating through ~28-32mph. Last month the dealer replaced the transfer case fluid with what I understand is an alternate spec. fluid BMW recommended. For the first week or so there was no change but now I think there's a noticeable improvement.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) Last edited by gofast182; 01-13-2023 at 10:09 AM.. |
01-15-2023, 01:41 PM | #42 |
Rep 2
I have 2019 BMW X5 50i. I bought it at about 42k ans had summer 22' Continentals. Closer to winter time I bought Pirelli Scorpion. Same 22' since it was pain in the #ss to find winter rims.
I started feeling the same Vibration/Shuttering NOT right away. First I thought I got some kind of dirt in my wheels. But after I noticed it startes on warm engine. Seems Like it's messing with me. It replicates the problem On 2nd or 3rd gear...Specifically when accelerating. Since this post was created 2 years ago or so I assume it will be cheaper/wiser to do thw following: 1. Alignment 2. Transfer case fluid exchange 3. Maybe some type of Calibration but dealers are stupid.. We will spend at least $300 for God knows what technician for "could not replicate the problem" I will try to explain it to BMW or will complain to BMW headquarters... This is ruining the whole "Ultimate driving machine experience".. For those who's reading it in 2023.. You are not alone |
02-25-2023, 05:38 PM | #44 |
Rep 104
Quick update.
So had a major service done at an indy last week and told them to change the transmission oil. The shudder has now gone completely! So if anyone is having any issues as such, maybe try this option. I think it was just under £150 for parts/labour!
BMW X5 30d M Sport
