03-10-2021, 11:25 PM | #353 | ||
12971
Rep 18,716
Tomorrow, I'm gonna check the gapping between the sway bar link to the lower arm. I will cross check with the data that QF8 gave me. If there is consistency on the gap, then I'll see if there is a part that we all can obtain easily and fix this issue for good.
03-10-2021, 11:26 PM | #354 | |
12971
Rep 18,716
That shim part number is internal use only. I can't find it in BMW parts catalog.
03-11-2021, 12:36 AM | #355 | |
Rep 186
And BMW don't know how to fix it |
03-11-2021, 12:41 AM | #356 |
Rep 192
BMW put out a fix just over a week ago.. 1st March
They install a washer in the lower sway bar link attachment to remove the play. Last edited by QF8; 03-11-2021 at 12:50 AM.. |
03-11-2021, 11:59 AM | #358 | |||
3102
Rep 1,823
r33_RGSport12971.00 |
03-11-2021, 08:06 PM | #360 |
3102
Rep 1,823
1/8 of an inch or so. Car gets squirly and needs an alignment. You'll know when it's ready.
03-12-2021, 01:42 PM | #361 | |
Rep 457
same for me, a-just-about-noticeable-drop after about 750 miles since install, variety of 30 / 50 / 70 mph roads, some smooth, some bumpy, some twisty. i did smile when i took the car to the shop to have the head lights and tail lights tinted, and mentioned the springs had been replaced ... the shop mechanic said "wow, how big was the gap BEFORE the new springs"!!
X5MC 2020 MBB
03-12-2021, 04:25 PM | #362 | |
Rep 1,221
QF8221.00 r33_RGSport12971.00 |
03-12-2021, 05:45 PM | #363 |
Rep 192
03-12-2021, 09:40 PM | #364 | ||||
12971
Rep 18,716
Did the 100Nm torque, but driver side still clicking. So I tried to use 1mm shim, and it didn't fit. Finally found some 0.2mm shim, then torqued it 100Nm. Noise is gone. Someone gotta start a lawsuit against BMW on this. I am confident that the issue is at the lower arm. It is a stamped process and welded rib cage. So, the gapping to where the sway bar link is sitting not always the same per car. But, other than that, it comes out very good with 25mm all around and my painted front reflector in Marina Bay Blue.
03-12-2021, 10:17 PM | #365 |
Rep 192
Nice Work
r33_RGSport12971.00 ed41367.50 |
03-13-2021, 12:04 AM | #366 |
Rep 732
Looks a ton better, thanks for sharing!
My local dealer said the knocking issues w/ the stock rear swaybar needs to be rectified by ordering a new swaybar & related parts. Two weeks for delivery and they'll call me back in. This is despite giving them the info QF8 shared with me : I also shared my plans to install my MSS springs this Monday, and they agreed to work on my knocking noises whenever the parts come in. Either they're taking an obtuse, roundabout way to fix this issue or perhaps there's a new fix? I'm betting on the former... I'll share updates or how it ends when the car goes back
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's Last edited by ed4; 03-13-2021 at 12:09 AM.. |
r33_RGSport12971.00 QF8221.00 |
03-13-2021, 12:09 AM | #367 | |
Rep 732
I'll have Keith give this a shot when I go in for my MSS installation this Monday. If we have success, I'll figure something out with the dealer with inbound parts or worse-comes-to-worse, I'll go through the motions by going back for their alleged fix. In the case of the latter, I hope they don't screw things up
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
03-13-2021, 08:14 AM | #368 |
Rep 254
Nice. What size shim opening did you use ?
03-13-2021, 09:54 AM | #369 |
Rep 8,815
I wonder if its limited to those that had it when the car was stock only. My car is a 3/2020 build and never had the noise before MSS. So far 300miles in with MSS no noise yet either.
03-13-2021, 10:02 AM | #370 |
Rep 3,507
Same here I just passed 500 miles with MSS. No noise before or after.
2022 M8 Comp Convertible
03-13-2021, 01:38 PM | #371 |
12971
Rep 18,716
@QF8 shop installed 1mm shim.
I can't get 1mm shim in there, but I managed to put 2x 0.2mm shim in there. It seems like the gapping are not consistent. Because, some can be solved by adding more torque, QF8 uses 1mm shim, I used 0.4mm shim.
03-13-2021, 06:46 PM | #372 |
617
Rep 361
No noise for me either.
Before or after MSS |
03-15-2021, 06:19 PM | #373 |
3102
Rep 1,823
r33_RGSport can you please share a link to the shim - I'd like to get this info over to my installers. Thanks in advance!
03-15-2021, 06:28 PM | #374 | |
12971
Rep 18,716
The one that I used was from some extra shims laying around from Wilwood brake kit.
xmanpro3101.50 |
