02-01-2022, 07:52 AM | #551 |
Self-Deprecating Narcissist
7266
Rep 6,561
Link to TSB?
02-01-2022, 08:50 AM | #552 |
12971
Rep 18,716
It is only for F95 X5M and F96 X6M.
Doesn't apply to G05 X5 and G06 X6. I don't have the link, but it is internal. Not an open campaign as I was told.
02-01-2022, 10:24 AM | #553 |
7266
Rep 6,561
I understand. My friend has an F95 and I was going to forward the TSB/SIB to him as this issue is what was holding him back from purchasing a set of MSS. He doesn't have the noise but doesn't want it either.
r33_RGSport12971.00 |
02-01-2022, 11:25 AM | #554 | |
12971
Rep 18,716
I believe a few US customers managed to get their local dealership to find the bulletin.
iconoclast7265.50 QF8221.00 |
02-01-2022, 05:50 PM | #555 |
Rep 192
My 2020 X6M had the knocking noise from brand new. It has absolutely nothing to do with springs. A good dealer will recognize and fix the issue if it does appear.
02-02-2022, 10:24 AM | #556 |
7266
Rep 6,561
Understood however dealers love to shift blame on everything but the root cause to avoid warranty work especially if there is an aftermarket component involved. Which is why having the SIB/TSB or having the issue resolved ahead of time is best. Generally speaking of course.
r33_RGSport12971.00 QF8221.00 |
02-02-2022, 05:29 PM | #557 |
Rep 192
It may be the knocking issue does not exist anymore as the factory would have rectified this for all vehicles produced after a certain date. The knocking issue was first reported over a year ago.
iconoclast7265.50 |
02-03-2022, 07:13 PM | #559 |
Rep 820
Drives: ...
Garage List 2015 Lamborghini Hu ... [10.00]
2018 BMW M3 [10.00] 1997 BMW E36 [0.00] 2022 BMW X5M [0.00] 2022 BMW 330i [0.00] 2023 Cadillac Escalade [0.00] 2023 Honda Civic Ty ... [10.00] |
For those that are using the KW HAS kit will the shims be required as well or this is only on the MSS kit?
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
02-03-2022, 07:15 PM | #560 | |
12971
Rep 18,716
It is BMW issue, not the aftermarket spring. As I mentioned above. It also making noise while stock.
02-04-2022, 07:34 AM | #561 |
7266
Rep 6,561
How come the kit for the M50i does not include the neoprene sleeves but it does for the X5M?
02-04-2022, 08:59 AM | #562 | |
12971
Rep 18,716
Neoprene sleeves are not always included AFAIK. Some have it, some don't. Even on the same application. I guess, depending whether they have it or not during packing.
02-04-2022, 09:58 AM | #563 |
7266
Rep 6,561
LOL, bizarre. If it is in the directions one would think it would be included in ALL the kits not just whichever they didn't forget to put it in.
02-04-2022, 10:29 AM | #564 | |
12971
Rep 18,716
I remember asking them a year ago with X3M kit. First batch was included, second batch wasn't included and they said that it is optional.
iconoclast7265.50 |
06-01-2022, 05:16 PM | #565 | ||
Rep 94
Drives: 22 BMW X5M Competition
Any thought? I thought if raising the truck a little but wanted to get some feedback before hand.
Current: 22 X5MC Matte Tanzanite Blue w/ Adelaide Gray
Past: “19 M5C Marina Bay Blue |
06-01-2022, 05:50 PM | #566 | |
12971
Rep 18,716
If it front, get it lifted and inspect if anything causing the binding. The top mount on front strut spins. So, spring should turn together with the shock.
QdaNoob67.00 |
06-01-2022, 05:59 PM | #567 | ||||
Rep 94
I wish the shops around here had the know-how. I appreciate the reply. I'll do it in the morning and see if it's moves.
06-02-2022, 10:40 AM | #568 |
7266
Rep 6,561
06-04-2022, 04:57 PM | #569 | ||||||||||
Rep 94
I put on my lift and found the boot jammed down. No noise now, hope that was it.
iconoclast7265.50 r33_RGSport12971.00 |
06-05-2022, 02:52 PM | #570 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
I can't see this as a significant source of noise, but good thing you reconnected it to the bumpstop to keep the shaft clean.
I think there are two sources of creaking in this setup. First the lower perch you have steel on aluminum interface that is exposed to grit, ideally there would be a Teflon shim. Second, you have the helper springs which is a binding design, where the coils are in contact with each other as it compresses. A little lithium grease spray in each location resolves most of the noise for me. I'm sure r33_RGSport Ben has better insight.
r33_RGSport12971.00 QdaNoob67.00 |
06-05-2022, 04:10 PM | #571 | |
Rep 105
06-06-2022, 08:09 AM | #572 | |
12971
Rep 18,716
Because once you lift it up, they must've falls off and clears the noise.
QdaNoob67.00 |
