10-08-2022, 04:03 AM | #1 |
Rep 272
X5 45e jerk on acceleration in ELECTRIC
Hello community!
Has anybody experienced their X5 45e jerk on acceleration from standstill on electric? Context - I have a 2021 X5 45e with 28k km on it. I had my gearbox changed about 15k km ago in December 2021 because of rough down shifting from 4th to 3rd gear, which was caused by metallic powder (or whatever it’s called. Basically the gearbox was eating itself). Right after that was swapped I started to experienced jerkiness on acceleration from standstill. It happened rarely and the BMW dealer couldn’t find anything suggesting to come back when it gets worse. It became warmer outside and i couldn’t experienced that problem - it was extremely rare. Now when it’s cold again, I started to experience this problem again - almost every morning, when the gearbox is still cold, I stop on a traffic light which is about 700m away from my home and the car may jerk very hard when I GENTLY press on the accelerator. It feels sometimes like somebody smashed me in the rear. I went back to BMW (another dealer this time) and complained about the problem (as usual :\). I said them the gearbox was changed and now I have another problem. They couldnt experience the problem, said there are no errors and the oil level is fine. They promised to contact bmw factory and ask what they can do. So I wonder if anybody experienced that. This really drives me crazy… |
10-08-2022, 10:30 PM | #2 |
Rep 18
I have experienced similar jerks in electronic mode on my 2022 45e. If I take off brake paddle wait half a second and easy on the gas the jerk would go away.
Curious to know if someone else is experiencing the same. |
10-09-2022, 12:01 AM | #3 |
Rep 272
You don’t use auto hold, do you? In my case it happens regardless of whether that’s enabled or not. Moreover, it happens only when the gearbox or whatever is causing this issue is still cold (I start the car, drive 700 meters and boom. Sometimes it happens and sometimes it doesn’t. Now it’s almost 2 out of 3 morning starts)
10-09-2022, 12:37 AM | #4 |
///M ♥ Recycled Dinosaurs
3197
Rep 1,775
Drives: BMW M4, BMW X5 45e
Something about your driving style and the environment in which your drive appears to be causing premature transmission wear.
If you're not gentle with cars when their fluids are not warmed up to operating temperature, this can happen over time. Or lightning struck twice and you're just unlucky. Only BMW can help with this so if they don't, I can only suggest selling the car.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
10-09-2022, 07:15 AM | #5 | |
Rep 272
The goal of this thread was to know if anybody else had had the same kind of problem |
kgelfen3602215.50 |
10-09-2022, 10:01 AM | #6 |
179
Rep 301
I don't think it's possible to not have smooth acceleration in Electric only mode. Even if you step on it, the 45e starts slow and smooth then seamlessly switches to Hybrid mode.
Sorry about what is happening to you car. I hope you find a solution. Last edited by RJC; 10-09-2022 at 10:07 AM.. |
10-09-2022, 09:38 PM | #7 |
Rep 8,696
Drives: eVeRyOnE mAD!
I often feel a hesitation/delay around 25mph, but it goes away as I continue to accelerate. it's not an issue when going straight but only if I'm at those speeds while turning
fan2593.50 |
10-09-2022, 09:43 PM | #8 | |
Rep 537
Some of us have had limited test drive time with the 45e. This thread is the first indication/mention I've seen about issues with drivetrain. Thanks |
10-09-2022, 09:51 PM | #9 | |
Rep 8,696
first you've seen? these might be interesting reads to you: Drivetrain Malfunction 2021 X5 45e - A Horrifying Experience https://g05.bimmerpost.com/forums/sh....php?t=1807656 45e Drivetrain Malfunction -- Reduced Engine Performance https://g05.bimmerpost.com/forums/sh....php?t=1892863 My 45e is dead and BMWNA is buying back, need to order a new one. What is fastest? https://g05.bimmerpost.com/forums/sh....php?t=1959761 |
10-09-2022, 11:43 PM | #10 |
Rep 272
I can’t say I feel that. In my case everything is smooth and stable except that bloody jerk problem that happens only once in the mornings
10-10-2022, 12:23 AM | #11 | |
3197
Rep 1,775
While the peculiarity is that here it is a 45e, something these transmissions do as they age (like 40-50k miles) is have a jerky first shift in the morning when cold - like the engine revs but the transmissions not engaged and then suddenly it engages. You may get it earlier depending how the transmission's been experiencing wear. It's surprising that it's happening on a hybrid though. I don't have any issues with my 45e. Because the transmission is still engaged and the electric motor's torque is not perfectly flat, there is a speed range in the middle on the way to 60 where if you're flooring in electric-only mode, the car feels like it's running out of peak power before a gear shift and then it's able to catch its breath and power up further into higher speeds beautifully. The performance from 65 mph to 80 mph-ish in electric-only mode can be very variable based on slope of road, temperature, prior load on battery and motor, etc. I just about never use it exclusively above 50 mph other than "just because".
10-10-2022, 12:33 AM | #12 | |
Rep 272
And btw I’m still on 11/2021 sw. on my request to update the software in a hope that the problem is fixed the previous dealer answered with a denial |
10-10-2022, 07:06 AM | #13 | ||
3197
Rep 1,775
It's possible your new transmission has problems if none of these do anything for you. Getting BMW to acknowledge that may be difficult - your best recourse in the end may be to just trade it in for a brand new car if you exhaust all other options. Also it may be worth noting that warranty replacements for engines and transmissions may be "remanufactured" parts. It is possible the quality of that work or the quality of the transmission replacement job at the dealer may have been subpar. Some other questions: 1. If you start your car in sport mode, with gearshift to the left so the engine is running at standstill, and you let the car warm up before you set off, do you notice the issue? 2. If you drive smoothly (highway) for extended durations (half an hour) before parking for the day, do you notice any difference the next morning? 3. What are the ambient temperatures where you are in the morning? 4. Is your general driving city-based with stop and go? Or include highways with extended cruising?
10-10-2022, 09:57 AM | #14 | |
Rep 272
2) doesn’t make a difference. I drive about 50-60km in the evenings in purely electric sometimes, but the car may still do the same in the morning. 3) about 5 C 4) city + 5-7 km highway and then city again. |
10-12-2022, 01:51 AM | #15 | |
Rep 272
1) first morning - started the engine right from the parking lot, drove to the first traffic light (about 700m) with the engine running. The engine kept running while I was waiting for the green light. No jerk observed during acceleration from standstill. Then I switched back to electric. Stopped on a second traffic light, felt mild jerk on acceleration from standstill. 2) second morning - didn’t start the engine, but drove to the first traffic light (about 700m) in the electric mode. Engaged the engine and started to drive when the light turned green - no jerk observed. Switched back to electric, stopped on the next traffic light. Again! Felt mild jerk on acceleration from standstill. What’s also interesting is that when the car is cold and I stop the car, I can feel like a gear change even though the car has already been stopped. That can be observed only for the first a couple of kms. Once that disappears, there is no jerk in electric mode either :\ |
10-12-2022, 08:37 AM | #16 | ||
3197
Rep 1,775
The problem appears to be with the engagement and disengagement of the electric motor into the driveline when cold. The electric motor is supposedly integrated with the transmission - in your replacement, do you know if the electric motor also got changed out with the transmission? Acceleration from standstill in electric when cold causes a jerk (as in vehicle starts moving). One more thing to try is while stopped, when you would normally expect the jerk, keep pressing the brake and press the accelerator until you can feel the electric motor trying to pull the car against the brakes (a tensing in the chassis). While you do this and the vehicle is still stopped by the brakes, do you feel a jerk at any point? If not, while the accelerator is still pressed, release the brake (this will cause sudden acceleration - be warned!) - do you get a jerk then? Also, dumb thing to check but you have auto hold turned off right?
10-17-2022, 12:01 PM | #17 | |
Rep 272
I got an answer from bmw - they will code the car (update software) and change gearbox oil on Thursday. Let’s see |
kjx3197.00 |
10-17-2022, 02:01 PM | #18 |
Rep 6,805
Since the throttle on most modern BMWs is by wire...if you're pressing the brakes does the engine actually start to run faster? I know that running around in a snow-covered parking lot, you can floor the accelerator, and the engine essentially stays near idle as it senses the wheels slipping, so the computer is controlling the throttle...I'd expect it would do the same when you had the brakes pressed...there'd be no reason to increase engine RPMs.
10-17-2022, 02:33 PM | #19 | |
Rep 272
10-23-2022, 11:05 AM | #20 |
Rep 272
So I had my car serviced last Thursday - they refilled oil to the right level (this is still unclear to me as it was said that the oil level was correct before), updated software and performed an adaptive drive which took 42km. The gearbox behaves good. I haven’t noticed any jerks so far.
10-26-2022, 02:19 AM | #21 |
Rep 272
it didn’t help in the end. The car didn’t jerk for a couple of days and started to do that again today morning :\ reported back to dealer. They will contact bmw factory for further instructions
10-26-2022, 11:39 AM | #22 |
Rep 3,681
My 45e has only 3K miles so far. I don't think I have stand still jerking, but I sure can detect less than smooth shifting from 1st to 2nd, and sometime from 2nd to 3rd, using EV mode, and relatively gentle on paddle. I don't remember if this is the case when I picked up tho. I will keep monitoring
2022 G05 B58/PHEV
+ a few very old BMWs |
