05-17-2023, 07:32 PM | #1 |
Rep 576
Does the 50e have remote start?
Does the 50e have remote start? I see that it's included on the Premium Package for the 40i, but the 50e doesn't say the same in the included options.
05-17-2023, 08:05 PM | #3 | |
Rep 8,826
Drives: eVeRyOnE mAD!
1) MyBMW app (Android, iPhone, Apple Watch) 2) MyBMW skill (Amazon Alexa or Echo devices) 3) iDrive (i often use this when running a quick errand) **optimizes electric range if plugged in advantages over traditional Remote Start include: 1) no idling engine (which is illegal in some countries) 2) can be done in enclosed spaces (no fear of CO poisoning) 3) runs for 30 mins vs RS's 15 min 4) quieter than an idling engine |
05-17-2023, 09:56 PM | #5 |
13630
Rep 20,267
It does not turn the engine on, it stops.
05-17-2023, 10:23 PM | #7 |
13630
Rep 20,267
Prior to the LCI there was battery control which you could set to keep a % of charge in it for preconditioning but I think I read they got rid of that in the LCI.
05-18-2023, 06:40 AM | #8 | |
Rep 549
So now, you need to set battery hold when there is charge and it will stay at the set level. But it won't add battery charge any longer, which is unfortunate. |
05-18-2023, 06:50 AM | #9 | |
Rep 8,826
• BATTERY CONTROL: pre-LCI charges the battery to a target level (30-100%) and holds it there • BATTERY HOLD: LCI holds the current battery level at the time of activation |
FastMarkA563.50 |
05-18-2023, 08:40 AM | #10 | |
Rep 209
Please correct me I am wrong. |
05-18-2023, 08:49 AM | #11 | |
13630
Rep 20,267
nZtiZia4739.00 |
05-18-2023, 09:13 AM | #12 | |
Rep 549
In my 45e, if the battery is at 30% and I set it to 80%, the ICE will charge the battery to 80% if it has enough time. Of course, there's a MPG penalty, but to that I say...my car, my choice. In the 50e (and I think iDrive 8 in general), if the battery is at 30% and one hits battery hold, it will maintain 30%...but it won't get you up to 80% if desired. |
05-18-2023, 09:33 AM | #13 | |
Rep 8,826
on the 50e, the vehicle holds whatever charge level the battery is at the time BATTERY HOLD is activated. for example, if the battery level is at 50% when activated, the vehicle uses regeneration/ICE** to keep it at 50%. if it was at 30% when activated, it’ll hold at 30%. it does not increase it above or even go below that level. on the 45e, we can choose the battery level we want between 30-100%. using the same 50% level example, the vehicle charges it to 50% if the battery level is lower than 50% at the time BATTERY CONTROL is activated, or if the battery level is higher than 50%, the vehicle lets the battery drain until it reaches 50%. once the target level is reached, the vehicle holds that charge level. **regeneration alone isn’t enough to consistently hold the battery level on the 50e which still uses the ICE the same way as the 45e by using the electric motor as a generator, but it just maintains the level, not increases the charge above it. |
05-18-2023, 05:34 PM | #14 |
157
Rep 304
The battery hold just prevents battery usage. It also is a separate mode that is not usable with the other modes. Sport mode will charge the battery 2 to 5% based on traffic speed changes. In Sport mode the engine never shutsoff unlike the 45e.
05-18-2023, 05:43 PM | #15 | |
Rep 8,826
• the vehicle switches between the ICE and electric drivetrain if the situation avails. (the threshold to stay in electric is low such that when exceeding 5-10% power, the ICE kicks in, thus in most instances, the ICE is the main drivetrain.) • eAssist is an integrated feature of the hybrid drivetrain that always assists the ICE. • the HV battery provides power to many electronic components in the vehicle continuously through the DC-DC converter. |
05-19-2023, 07:29 AM | #16 |
157
Rep 304
OMG I am sorry for being imprecise.
Yes the battery is always used. But without battery hold its charge decreases. Battery hold prevents any usage from decreasing state of charge. |
05-19-2023, 08:25 AM | #17 |
Rep 8,826
05-19-2023, 11:56 AM | #19 | |
Rep 549
I don't know why I like to do that, but I just do. Or if you like to sneak up on pedestrians, it's best done with the battery not ICE. |
05-19-2023, 12:26 PM | #20 | |
Rep 8,826
anticipation of preconditioning wasn’t the main reason but came about for U.S. owners since we didn’t have eZones when the 45e was released (now we do in three California cities) |
05-21-2023, 08:13 AM | #21 |
157
Rep 304
After 800 miles, I now use Battery Hold for nearly all driving. It is kinda like Hybrid mode but keeps battery charged. It switches between electric amd ICE, and shuts off engine when stopped - usually. I haven’t charged and still have 37 miles range.
915M88.00 |
05-21-2023, 08:27 AM | #22 | |
Rep 8,826
this is a perfect example of how BMW actually listened to our feedback when changing the logic from Battery Control on the 45e to Battery Hold on the 50e, but I still think taking the ‘Control’ part away from users was a mistake.jad03060 |
