05-18-2023, 11:32 AM | #1 |
MGySgt
647
Rep 1,263
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
Post Your Highest 45e Starting eRange thus far!
I was welcomed to 39 eMiles of range today! My second runner up eRange was 36 miles which was registered back in April.
1) MY 2021 / US model 2) 21" Wheels 3) Northern VA (US) 4) Temp at time of post" 64* F Edit: Well, by the time I headed out to get some lunch,...my eRange was showing 40 Miles!,....@ 74*/F per in-dash temp!
JMD
05-18-2023, 11:35 AM | #2 |
Rep 8,892
Drives: eVeRyOnE mAD!
MY21 U.S. M Sport with 20” wheels
highest was last summer 43 miles southeastern Va temp was in the 90s (F) |
05-18-2023, 01:31 PM | #4 |
Rep 1,092
Took this just this morning and clocked in at 44mi when I took it off the charger.
- MY 2023 / US / M-Sport - 22” forged wheels - SoCal (Santa Monica) - temp when I took the pic: 67 degrees F Last edited by rundeyvoo; 05-18-2023 at 01:48 PM.. |
cptcolo103.50 |
05-18-2023, 02:48 PM | #6 |
Rep 1,092
There are varying factors and having your HVAC on or off would contribute to that. As well as driving style, speed, outside temps, and the weight load you’re carrying. I use my AC pretty frequently though.
05-18-2023, 04:06 PM | #7 |
Rep 3,761
This is the moment you start the car from fully charge before driving. It has everything to do with your last trip, but current trip. If you came home by driving 20 miles down hill back last night, the range will be very high when fully charge. It does NOT mean your current trip will do 44 miles.
2022 G05 B58/PHEV
+ a few very old BMWs |
nZtiZia4770.50 Flying Ace4992.00 |
05-18-2023, 04:18 PM | #8 | |
Rep 418
Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 2017 JKU Sahara - Beach jeep 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
05-18-2023, 04:18 PM | #9 | |
MGySgt
647
Rep 1,263
JMD
05-18-2023, 05:58 PM | #10 | |
Rep 8,892
05-18-2023, 06:16 PM | #11 |
Rep 6,946
The drive before my last charge was partly on stop and go city streets, then, primarily on divided highways. Temp was in the 60's which probably tempered the need for heat or cooling as it was sunny...after recharging, mine read 42-miles...one of the higher readings I've seen. Next trips will all be in the city, so it will likely go back to low 30's.
05-18-2023, 06:43 PM | #12 |
Rep 3,761
Yes, definitely. Just 2 weeks ago, I was testing my 45e for EV acceleration, so I keep pushing paddle to the max before kick down. I got 18 miles on that charge. When I charge the battery back, it shows 15 miles. I was like WTF is going on, almost call BMW. But then actual daily driving, we are back to 30s.
2022 G05 B58/PHEV
nZtiZia4770.50 |
05-18-2023, 07:33 PM | #13 |
11593
Rep 11,147
Not sure if I would go by the starting range. Fully charge it and drive it around in Individual Electric until you run out of juice.
Then post that number. |
05-18-2023, 09:34 PM | #14 |
Rep 6,946
The estimate is based on the last 18-miles of use which assumes your next miles will be exactly the same. That doesn't happen very often. Unless you realize that, expecting it to represent your future reality is futile. Once you realize that, you can make your own estimate that may be closer to reality based on how you drove (the only thing the vehicle knows), and how you plan those future miles will be. Keep in mind that it's a rolling average, so as you drive a mile, the oldest one in the estimate gets thrown away from the calculation. So, yes, the estimated range to empty can seem really weird...like staying at the same value for more than a few miles, or increase, or radically drop faster than the distance you've traveled.
05-18-2023, 11:28 PM | #15 |
Rep 418
For those if you who care about this, what difference does it make if you go 27 or 35 miles on battery power? Don't you just keep going after that with no discernable difference?
Where we live the first half mile from the house gains about 70ft, then the next 5.5 miles loses about 500ft. Whatever the number is at the start, it'll usually be 6-7 greater by the time you've traveled those six miles. Pure fiction. Power was consumed during that drive, not stored. Mark |
05-19-2023, 12:09 AM | #16 |
Rep 156
On the forum for my EV the equivalent of the number we are discussing is called the “guess-o-meter.”
As others have said it is a prediction based on the recent past. The same thing happens on some level with the combined/gas range that’s displayed—it is an estimate not a guarantee. A more useful comparison would be folks sharing their electric efficiency since factory. |
05-19-2023, 12:09 AM | #17 |
Rep 6,946
FWIW, the estimated range to empty on an ICE isn't any better than with a PHEV or an EV...it's based on the energy expended, and what reserve is left based on your current use. They all buffer and average those calculations (look at instantaneous readouts if available), but are still just estimates. It's not worth worrying about. The EPA ratings are a help to compare apples to apples, but it, again, is an estimate, just based on a consistent methodology for all comers so a comparison is valid, but it isn't your real world result.
05-19-2023, 12:23 AM | #18 | |
Rep 3,761
But having that said the EV mile in thr “since factory” trip computer can be reset by dealer. Mine got reset from about 3000 miles to zero after instrument cluster was replaced. So I lost my real stats. So that since factory screen isn’t very accurate either. |
05-19-2023, 06:46 AM | #19 |
Rep 8,892
one would think the stats since factory shouldn’t be resettable, eh? that’s data you can’t get back!
05-19-2023, 12:57 PM | #20 | |
MGySgt
647
Rep 1,263
However, just for the record, I wasn't asking folks to prove their eRange in Miles as shown in the gauge cluster to be right or wrong. The post was meant for folks to just post their "Highest 45e eMiles" as shown in the gauge cluster be it yesterday, present day, or tomorrow. Now, if folks were able to achieve the range shown in the display, no matter if it's 23 miles or 63 miles of eRange,...Great,...and if not (...no matter the reason),...then it is what is,...or is not! That's all.
JMD
05-19-2023, 03:17 PM | #22 |
2023 X5 45e Owner
104
Rep 136
47 miles (US version 2023 X5 45e with 20" 740m wheels). This was after cruising down from mountains at a moderate speed ~60mph the day before.
