      03-13-2021, 05:42 PM   #1
stockli81
Drives: 2021 X5 M50i
Glass Cleaner
What does everyone use to clean windshield/windows? Ive been using 3M foam glass cleaner with microfiber towel but the towels seem to leave fibers all over the glass. Small enough where you cannot see until the sun is shining through, then it looks like swirls marks.
      03-13-2021, 06:04 PM   #2
luckylingy
luckylingy's Avatar
3234
Drives: X3M
Sonar glass cleaner (applied with microfiber foam pad) and dried with CarPro glass-specialized towels. Finally found a combination that consistently works. No swirls, streaks or fibers left behind.
      03-13-2021, 10:39 PM   #3
r0b0tz
Drives: 428i Convertible, X5 45e, FX37
Meguiar's Perfect Clarity Glass Towels
I struggled with the microfiber lint too. I think these Meguiar’s towel are great and don’t have the same lint problem.
I think most people likely overdo the glass cleaner. I spray it on one side of the folded towel, clean, flip, then dry/shine.
Sometimes I use them on the hard glossy dash plastics too.
https://www.amazon.com/MEGUIARS-X190...%2C234&sr=8-26
      03-15-2021, 02:23 PM   #4
GREENPUS
Drives: 2019 BMW M5C
I've never had any issues with microfiber lint and I buy the cheap packs at Walmart. I use them once and either throw it away or wash in washing machine with NO fabric softener. And I never wash them with other clothes. Just the microfiber towels. Most times I use Invisible Glass cleaner with a paper towel and then polish with Microfiber towel.
My bikes all have fairings with plastic windshields and I use Plexus Plastic Cleaner with a microfiber. Does wonders on glass but expensive.
2019 M5 Competition
2021 X6 xDrive40i M Sport
2018 Toyota RAV4 AWD
2008 Corolla S Souped Up - The Black Widow
      03-15-2021, 10:20 PM   #5
Shawzy44
Shawzy44's Avatar
158
Drives: 2019 BMW X5 40iX
I use The Rag Rag Company Glass & Window Towel - Green (16x24) and Griot's Garage Window Cleaner. Amazing results.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
2019 BMW 440iX M Performance Cabriolet
      03-18-2021, 09:04 AM   #6
Grumpy311
Drives: X5, 328i
I think the key is to look for lint free towels. As far as the cleaning solution, I would just make sure to get it on nothing but the class. I don't think it's good for rubber/plastics. I just use regular window cleaner, sometimes rain X.
      03-18-2021, 09:49 PM   #7
Mo2002
Mo2002's Avatar
224
Drives: 2021 X5M
I use this
https://www.carpro-us.com/microfiber...e-glass-cloth/
      03-19-2021, 09:46 AM   #8
bimmerwerks
Drives: G05xdrive40I
Well first do not clean in circular motion....
Go left and right and once you clean, don't go over the same area over and over.
Glas coating also helps on this issue and sometimes cleaning with alcohol works good too.
What I do is if it is immediate after car wash I use window squeeze to get rid of water.
      03-19-2021, 05:58 PM   #9
VTENGR
1053
Drives: 2020 X5 M50i
Had the same issue with microfiber lint. Ended up buying some glass specific towels that have worked great.
[Diamond Glass] Microfiber Window... https://www.amazon.com/dp/B0747BH878...p_mob_ap_share
      03-29-2021, 08:20 AM   #10
Grumpy311
Drives: X5, 328i
Speaking of window cleaner. What is best practice for cleaning the inside of the windshield? There has to be an easier way.
      03-29-2021, 02:59 PM   #11
luckylingy
luckylingy's Avatar
3234
Drives: X3M
I use a lint-free microfiber foam pad to apply the glass cleaner, followed by a microfiber towel specifically designed for glass (latest one I use is from CarPro, which is more substantial than others I’ve used previously). If you’re not sure you’re completely drying the glass, use a horizontal motion inside and a vertical motion outside, so that you know whether any remaining are inside or out.
I’ve tried special triangular-shaped ‘wands’ to extend the applicator or drying towel into hard-to-reach corners, but they’re more trouble than they’re worth (short of an 8 Series rear window, I’d suppose).
Be sure to clean glass when it’s cool (never in direct sunlight).
      04-13-2021, 08:27 AM   #12
Busa Dave
Busa Dave's Avatar
72
Drives: 2021 X5 M
I use Invisible Glass. Just works perfectly and easy.
2021 Mineral White X5 M
      12-12-2022, 04:52 PM   #13
malvern_man
United Kingdom
520
Drives: X5 40i xDrive
I use Gyeon Glass with The Rag Company waffle weave glass towels.
      12-12-2022, 06:11 PM   #14
oldguy00
Drives: 2022 X5 xdrive40i
Originally Posted by oliver305 View Post
I use Vinegar to clean windows. It contains acid that effectively dissolves accumulated dirt. Plus, it has a natural antibacterial ingredient that disinfects surfaces. Wipe the window using a microfiber cloth.
I bet that does work well. If only the smell of vinegar didn't make me want to hurl!! lol
      12-23-2022, 03:05 PM   #15
GrussGott
GrussGott's Avatar
Drives: 2018 M4 Comp Indv
ha! yeah ... not sure about that one, or why I'd want to disinfect my window unless I park in that orgy parking lot again which I'm NOT ever doing again!
Step 1:
Wash with rest of the car and/or use a rinseless like McKee's N-914 or ONR or P&S absolute
Step 2:
Rag Co waffle or diamond weave, 50/50 distilled/de-i water:90%IPA. This will remove road film, grease, dirt etc (waffle/diamond weave won't leave broken fibers, i.e., "lint")
Step 3:
IF needed, clay that bitch, then IPA it again
Step 4:
Use a finisher like Invisible Glass. NOTE: IG is not a great cleaner/degreaser, it's better as a finisher.
Originally Posted by TurtleBoy View Post
He tries to draw people into inane arguments, some weird pastime of his.
