03-16-2024, 09:23 PM | #1 |
Rep 73
HELP!!! Instrument Cluster+HDU+System Time+Trip Odometer+BMW APP Malfunction
I tried to search for similar thread but none seems to be this severe. I've had instrument cluster shutting down on me before, but all were while driving and each time it would come back online after a minute or so. Until this week, everything seems to falling apart.
Yesterday, my instrument cluster would just not start upon entry. Along with HDU, and trip odometer on the center display. I waited for a few minutes and exit the car to lock and unlock several times and they eventually came back. Today it happened twice. First time I tried to fix it but it would not work. It was when I parked the car but was still in the car. I saw both displays turned off and tried to activate them right after, but only one turned on. The car could drive so I just drove off. After ten minutes or so they came back. But I noticed the drive mode did not change at all. I like to put my car in eco mode but even until the instrument cluster came back on showing my car is in eco, it feels like still under normal mode. After parking for 15 to 20 minutes, I got back into the car with the same problem once again. Tried to lock and unlock, restart the display, hard reset the display, but none would work. Even after drove off, instrument cluster never came back. It was until now that I noticed the clock was way off for unknown reason, I tried to change the auto time zone setting and the clock just turned blank, nothing, no time at all. Meanwhile, my traction control warning always echoed in the cabin every few seconds. It feels like the instrument cluster was trying to reboot but just couldn't. During this time, the circled button right next to hazard light kept switching between green and orange, I assume it's something wrong with the safety features as well. No speedometer, no head-up display, no time, no fuel gauge was how I got home with today. Plus, since earlier this week, my BMW app would not show my car on the frontpage. Instead, it's a sedan with white cover on it, just like some other threads. I'm not sure if all these are connected but sure to be something concerned about.
Drive a lot
03-16-2024, 09:40 PM | #3 |
Rep 73
Bluetooth audio and Apple Carplay were doing just fine during this entire drama.
Undate: Parked my car for a few hours and the instrument cluster came back. But it was giving me two errors: brake measuring not possible(if that's how it said), and battery management. Both error messages went away once I started the engine. But, the trip odometer was not how it's supposed to be. It should be showing your fuel consumption levels for the past 1000 miles right? Mine was giving me a flat line, numbers for "since factory" and "since individual" seems to be right but "since refueling" seems to be way off. Not sure if this has something to do with my hard reset. I tried to push and hold the volume button for both 30 and 60 seconds, instrument cluster never came back and there was no indication of reset succefull.
Drive a lot
03-17-2024, 01:39 AM | #4 |
Rep 8,700
Drives: eVeRyOnE mAD!
these glitches tend to favor an issue with the 12V battery (low voltage). have it checked out
03-17-2024, 11:42 AM | #5 |
Rep 73
low voltage issue even when the engine is running? how?
Drive a lot
03-17-2024, 12:53 PM | #7 |
Rep 90
You don’t say what year the car is but I would concur with verifying the battery. I would highly encourage everyone to have a battery charger (I have at least 4) and know how to use them. Put it on a charger and see if the problem goes away.
I’ve always considered a battery to be a regular maintenance item, first sign of trouble, replace it. Don’t wait for it to leave you stranded anywhere, it’s not worth trying to get a couple extra months out of it. My first experience with a weak battery causing strange issues was with my wife’s Volvo S60, radio acting strange, dealer couldn’t figure it out. A month or so later the battery crapped out and after replacing the battery the radio problems mysteriously disappeared.
2024 X5 X40i Tanzanite Blue / Tartufo Merino
Past Bimmers: 1600/2; E36 M3/4/5; 740; 328 Conv (wife's); 128 Conv (wife's) Past Beemers: K1200RS; R100 GSPD; K1200 LT; R1100 RT; R1150 GS Assorted Porsche's over the last 20+ years |
Ninja_H20.50 |
03-17-2024, 01:36 PM | #8 | |
Rep 73
Drive a lot
03-17-2024, 01:38 PM | #9 |
Rep 73
any recommended brand and model for charger?
Drive a lot
03-17-2024, 01:44 PM | #10 | |
Rep 90
I had a Toyota Sequoia that wouldn’t start a couple of times (fortunately was in my driveway both times), after the first time Interstate said the battery was fine just needed charging. 2nd time it did it (after only a couple weeks) I replaced the battery and never had a problem again.
Ninja_H20.50 |
03-17-2024, 01:49 PM | #11 |
Rep 90
For a trickle charger I really like the CTEK’s (Porsche sells them but slaps a Porsche label and charges 2x as much!).
The Deltran’s are also good trickle chargers (I used them when I rode motorcycles). As for higher output chargers my go-to is an old Sears 6A/10A charger, I suspect many chargers would suffice.
Ninja_H20.50 |
03-17-2024, 02:28 PM | #12 |
Robot
27
Rep 34
I use this as it one of the best. I got it used like new for 80.
https://www.amazon.com/gp/product/B07W3QT226/ |
Ninja_H20.50 |
03-17-2024, 11:39 PM | #13 |
Rep 73
Thanks for all the info. BTW, do you know why a battery could cause all the problems? Couldn't figure out why.
Drive a lot
03-17-2024, 11:56 PM | #14 |
Rep 73
I did my engine air filter tonight and noticed some oil inside the Rubber boot and Intake duct. is that something I should be concerned about? Left side was not noticeable but once I switched to right side, the amount of oil was significantly more and got me worried. I saw some articles saying it's normal for turbocharged engines, can someone explain?
Drive a lot
03-18-2024, 08:19 AM | #15 | |
Rep 90
A new battery might not fix your particular problems but after 119k miles I would consider it a (relatively cheap) maintenance item and I’ve experienced enough flaky issues on newer cars resolved by a new battery I just personally prefer to start there. If you have a friend with a DVM (digital voltage meter) you can check the voltage (both with the car off and while starting) and see how much it drops. Google to see the relative strength of the battery based off both the readings.
Ninja_H20.50 |
03-18-2024, 08:22 AM | #16 |
Rep 90
Porsche’s have done this for years, after parking in the garage the fan will kick on and off a few times while the car is cooling down.
Ninja_H20.50 |
03-18-2024, 09:02 AM | #17 | ||
Rep 8,700
do a search here and online and you’ll find how prevalent this issue is |
formerE36M3/4/569.00 Ninja_H20.50 |
03-18-2024, 11:23 AM | #18 |
Rep 90
Yes, fluctuations was a poor choice of words on my part. It's more reduced voltage.
nZtiZia4656.00 |
03-18-2024, 04:44 PM | #19 |
Rep 73
Speaking of software updates, I'm on 07/2020.32 and it's saying no new updates... was never able to receive updates since almost three years ago I believe? Was wondering if this has caused some backfire on me since I never took it to the dealership to deal with the system updates.
Drive a lot
03-18-2024, 07:39 PM | #20 | |
Rep 8,700
or it could also be a bad instrument cluster, head unit, etc, but checking the health status of the 12V is pretty easy, so either way, let the dealer sort it out. good luck and keep us posted |
Ninja_H20.50 |
03-18-2024, 07:50 PM | #21 |
Rep 3,681
I had similar issue happened in my 22 45e. After a few times of flickering on and off, screen just died. HUD was good, idrive was good, music kept playing, just instrument won't turn on. It was replaced under warranty in my case
2022 G05 B58/PHEV
+ a few very old BMWs |
03-19-2024, 10:39 AM | #22 | |
Rep 73
Drive a lot
