      03-20-2024, 09:07 AM   #1
RNorb
230
Drives: 2020 X5 40i, 2024 X1 28i
Production status changed from 112 to 111 MY25 M60i
I ordered a MY25 M60i in February which had an initial status of 111. It changed to 112 about 10 days ago. I checked today and its back to 111. Any ideas on what happened?
      03-20-2024, 02:02 PM   #2
TurtleBoy
TurtleBoy's Avatar
13269
Drives: 2019 X5 40i,2021 M340i
Supply issues would probably be the likely cause. Did you check to see if your production week changed?
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      03-21-2024, 04:45 PM   #3
RNorb
230
Turns out that when the production code changed from 111 to 112, the production week change from 17 to 15. Then for some unknown reason the production week changed back to 17 and the production code went back to 111. Is it correct that changes can be made with the build until production code 150?
      03-21-2024, 05:08 PM   #4
TurtleBoy
TurtleBoy's Avatar
13269
Yes, that is correct. The exception to that is if the build has an Individual item then there is a last change date which is usually shortly after the order is entered.
