05-08-2021, 06:52 PM | #1 |
Rep 611
Installed new wheels.
I just installed my new wheels. They are 20" Avante Garde M520-R with 20x9 et25 front and 20x10.5 et38 rear with 245/35 and 285/30 Yokohama Advan Sport A/S+ tires. Those are the size and offset that many have recommended on the forums. What do you think? I'm getting used to the look. I've never had wheels and tires this flush and aggressive before. Should I eventually lower the car?
You can click each pic for a more high res pic
05-09-2021, 09:27 PM | #3 |
4972
Rep 378
Drives: GMC Denali
If they don't rub, they fit. There isn't really a 100% answer. Do you like to look? It's your car, so if you like it, who cares what others think.
05-10-2021, 10:00 PM | #5 |
Rep 124
Drives: 2003 M5, 2015 Z4 35is
I'm going through the same thing. I ordered 20x9 and 20x0.5 on a 540i. I'm trying to decide on offset, going with 255/35 and 295/30.
Since I'm not lowering the car, I may stick with +30 or 32 up front and +42 or 44 in the rear. |
05-11-2021, 10:01 AM | #6 |
Rep 6,845
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Hmmm...something looks off and I can't put my finger on it. It almost looks like the fronts are bigger in size than the rears. In terms of lowering, I actually thought it already was lowered. I'm just not a fan of the wheel itself I think. Sorry!
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
05-11-2021, 10:49 AM | #7 |
Rep 2,388
I think it looks really nice and you shouldn't lower it if that's your choice. I would of went with a 295 30 rear tire.
Formerly Wyndi335I
2009 BMW 750li sold 14 BMW X5 04 BMW X5 11 BMW 335i convertible (sold, sellers market |
05-11-2021, 06:23 PM | #8 |
Car Enthusiast
480
Rep 1,132
05-11-2021, 07:04 PM | #9 |
Rep 462
OP - I have been having the exact same thoughts on my spec...
20x9 et25 - 255/35/20 20x10.5 et35 - 285/30/20
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
05-11-2021, 07:34 PM | #10 |
26
Rep 34
Drives: M550i
PAL516
05-11-2021, 07:52 PM | #11 |
26
Rep 34
Drives: M550i
Are those gun metal or gloss black?
PAL516
05-12-2021, 10:19 AM | #12 |
Rep 611
I originally had Continental Dws06+ 255/35 and 295/30 installed but they looked too meaty and stuck out too far. It might have just been that tire but it didn't look good at all. Switching to 245 and 285 looks way better and sportier. That's the recommended tire sizes also from Getyourwheels.com and the place that milled the wheels.
05-12-2021, 10:32 AM | #13 | |
Rep 611
05-12-2021, 11:56 AM | #14 | |
Rep 255
06-12-2021, 09:00 PM | #17 |
Rep 611
Would I be able to lower the car without rubbing with this spec?
06-13-2021, 09:40 AM | #18 |
Rep 803
It depends how much you lower it. It looks really nice the way it sits now. You could lower maybe 1-2 inches more, but I would roll the rear fender a little bit just in case.
06-13-2021, 10:28 AM | #19 |
4972
Rep 378
Drives: GMC Denali
06-13-2021, 10:31 AM | #20 | |
Rep 611
06-13-2021, 12:16 PM | #21 | ||
Rep 803
A good point was brought up about rear steer, you might have issues if you lower it more with rear steering. |
06-14-2021, 05:14 AM | #22 |
Rep 234
I share the feeling. Nearly same size/offset (10.5"ET40) on my car, and I think it's too agressive. That said, most people will not notice, and many like the agressive look. So, in the end, why not?
I would not lower the car, I think it's perfect like this. You could consider having the rear camber adjusted at max negative recommended value by BMW, but I don't know if it would make a big difference.
2018 M550i Sepia-Violet
