      04-26-2020, 06:36 PM   #89
Hideada
Hideada's Avatar
Japan
23
Drives: BMW X5(G05) 2019
2019 BMW X5  [0.00]
Originally Posted by zu11y View Post
hi guys. iv recently fitted the laser lights to mine which came with standard led.
plugged in and coded 5az and everythng is work. however i am getting high beam headlight failure warning.
has anyone come across this and what was the solution. thanks in advance
Do you see the VIN of your FLM43 and FLM44?
If it is "0000000", ECU FLASH is required.
If done correctly, the SWFK should be added and the high beam warning should disappear.
      04-26-2020, 06:41 PM   #90
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
Originally Posted by hodgson-p@hotmail.co.uk View Post
Did you manage to flash yours to get rid of it?
I had such a problem with the left and right lights, but the left side (FLM44) solved the problem.
The right side (FLM43) part was diverted from the LED, so the error on the right side did not disappear, but I think the error will disappear by changing to the regular product at a later date.
      05-02-2020, 05:31 AM   #91
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
The flash removed all errors.
Perfect.
retrofit is
It can be implemented with only simple swapping and coding.
happiness.
Appreciate 4
robby818265.00
Heimdall136.50
KRS_SN13529.50
      05-02-2020, 11:24 AM   #92
Phil
41
Drives: Bmw g05
Perfect.
retrofit is
happiness.
Finally I got mine in today.. look so much better just need to wait to be able to get a FSC code for HBA retrofit now stalks in just need a FSC to get it to work
      05-02-2020, 10:46 PM   #93
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
You look very cool
Great job.
By the way, doesn't HBA need an FSC code?
Remove the 5AP and 8S4 from the VO and add the 5AC
I think it will work if you code the other necessary modules.
I'm not sure, though, as it may work differently in different countries.
      06-11-2020, 01:01 PM   #94
yoodog
Drives: BMW 120d F20
hi We have Laser g05 lamps - mint condition (bmw dismounted test Car)
3580 euro form EU - EU shipping incl
      06-12-2020, 05:01 AM   #95
Arfy
Arfy's Avatar
Australia
22
Drives: BMW X5 30d
Originally Posted by AlexDragu View Post
Hello,
Does anyone know if we can retrofit laserlight? and what we need? i have led adaptive (i couldn t put laser light on my car because restriction on factory and it would be a delay of 2-3 month).
Thanks a lot!
I have laser lights and for the driving I do in country Australia i dont think they will show enough up front or the sides. Have not tried them in remote area as i cannot get there (restrictions) but where's i have tried them they are prob the brightest headlight i have seen on a car but not sire they will still cut it.
I am trying to work out a way to wire a good light bar into the manual high beam.
      07-06-2020, 05:23 PM   #96
Mozak
Drives: BMW X5 MY20
Laser coding
Hi All,
I just fitted the laser on MY20 G05. Can anyone of you who has completed this retrofit tell which ECUs to VO code and if the high beam warning error comes up what to do to clear it? New to coding but have VO coded. Overall, I need help in making it function.
Much appreciated.
      07-06-2020, 06:12 PM   #97
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
Originally Posted by Mozak View Post
Hi All,
Much appreciated.
All you need to do to turn off the high beam warning is the ECU FLASH on the left and right FLMs (43) (44).
Please follow this link to perform the FLASH.
https://www.bimmerfest.com/forums/sh...d.php?t=811347
After that, code each module and it will be fully operational.
      07-06-2020, 09:19 PM   #98
Mozak
Drives: BMW X5 MY20
Thanks for the quick response. Do you mean the only two ECUs to be VO coded and flashed are FLM43 and FLM44? Also, do these modules have dependencies?
      07-06-2020, 09:25 PM   #99
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
Flash is only allowed in both FLMs.
552 was deleted by VOcoding and 5AZ was added.
I was not confident about the module, so I code FLM, BDC_BODY, DKOMBI, HKFM, HU_MGU, IHKA, and KAFAS.
This includes things that are probably not needed.
https://g05.bimmerpost.com/forums/sh...2&postcount=52
      07-19-2020, 08:48 AM   #100
xavierflynn
Japan
Drives: BMW X5 35d mSport (G05)
Perfect.
retrofit is
happiness.
That’s cool. Where did you get your laser lights from? I am in Tokyo.
      07-19-2020, 05:50 PM   #101
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
When I ordered a new one from BMW JAPAN it was $16,000, too much money.
So I ordered it from Ebay.
They are sold as a set for about $4,000.
I'm in Kanagawa.
私は神奈川です。
      07-24-2020, 08:56 AM   #102
Aero7000
Aero7000's Avatar
246
Drives: M340i DravitGrau / Cognac
Are you sure you are getting units with laser beam generators, or only DRL's for 4 grand.
      07-27-2020, 11:30 PM   #103
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
I'm using a genuine BMW Laserlight component, so I believe it produces not only DRLs, but rays as well.
      07-28-2020, 07:01 AM   #104
Aero7000
Aero7000's Avatar
246
Interesting, I just look at price difference and AFAIK every laser head light has actual laser module that generates 3 laser beams converted in to one white beam by the lens.
The difference between 16 000 and 4000 make me suspect.
Wish you luck with you retrofit, Post some pictures if works.
      07-28-2020, 07:31 AM   #105
ND40oz
ND40oz's Avatar
406
Drives: M2 CS
It's the difference between buying them new from the parts department at full retail price and buying a set of takeoffs from a wrecked vehicle.
21 BMW X5 xDrive40i
20 BMW M2 CS
19 Mini Cooper S Countryman ALL4 6MT
      07-28-2020, 10:22 PM   #106
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
I've posted this before, but I was shooting a video.
Would you prefer a photo?
The difference in price seems to be the difference between buying legitimately from a dealer and purchasing parts, like the OEM, as others have said.
      07-29-2020, 06:49 AM   #107
Aero7000
Aero7000's Avatar
246
Thanks, looks much better with these DRL's.
Let us know if you notice difference driving with lasers in the dark.
      07-31-2020, 02:33 AM   #108
Mieleo
Drives: 2019 x5
Can you tell me how to code headlight after install it ?
Thank you!
      08-06-2020, 01:43 AM   #109
AlexDragu
17
Drives: G05
One question to those who make the change, when you ll do a software update for the care you need to recode again the lights? I will also do the change and i want to know that 🙈.
      08-07-2020, 03:27 AM   #110
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
Thank you!
Please refer to Post #52.
The rest of the time you will need to FLASH the ECU.
