11-08-2019, 07:29 AM | #23 | |
2448
Rep 1,953
The companies actually only delivered 87 and 91 . 89 was a 50-50 mix done at the station itself. Every now and again when we ran out of 87, it meant we were also out of 89 (which almost nobody bought) and we'd essentially sell 91 at the 87 price until we got some 87 delivered. This is perhaps not how every gas company does it, but the two I worked for here in Montreal sure did. |
11-08-2019, 09:07 AM | #24 | |
103
Rep 393
In the UK I have never heard of a petrol octane level lower than 95RON the highest rating being 102RON Octane is a hydrocarbon that is part of all fuel. Octane ratings/numbers are a measure of a fuel's ignition properties under compression. This is expressed as a reference to the same properties of a form of octane. There are several ways in which the octane rating can be measured and/or calculated. In the UK the Research Octane Number (RON) is the most commonly used value. Octane Rating is a measure of how the fuel burns in your engine. Too low an octane rating can cause knocking - also known as pinking, which over time can harm your engine. Knocking results when the fuel pre-ignites in the cylinder, ahead of spark plug ignition. Higher octane rated fuel controls this pre-ignition. |
11-08-2019, 09:15 AM | #25 | |
Rep 506
"Anti-Knock Index (AKI) or (R+M)/2 In most countries in Europe (also in Australia, Pakistan and New Zealand) the "headline" octane rating shown on the pump is the RON, but in Canada, the United States, Brazil, and some other countries, the headline number is the simple mean or average of the RON and the MON, called the Anti-Knock Index (AKI), and often written on pumps as (R+M)/2. It may also sometimes be called the Posted Octane Number (PON)." https://en.wikipedia.org/wiki/Octane...,_MON,_and_AKI |
ggalanis2448.00 |
08-13-2023, 06:17 AM | #26 |
Rep 146
08-13-2023, 06:45 AM | #27 |
13275
Rep 19,805
Shell pays them to recommend their fuel, quite common in the industry.
08-14-2023, 06:28 PM | #28 |
Rep 6,806
You should consider reviewing https://www.toptiergas.com/retailers/ to select your fuel source in the USA. That organization was formed by a fairly large group of vehicle manufacturers to help avoid long-term issues in their vehicles. That list changes over time as some vendors decide they don't want to participate for whatever reason.
08-15-2023, 02:25 PM | #29 |
Rep 15
I always do premium (93 octane) as 91 is rarely available, but for those that say it only costs 25 cents more a gallon then 87, you must be lucky. By me, it's a dollar a gallon more on average, sometimes more than that. So, about $20 more on a complete fillup. I believe the refineries in my area basically only do 87 so they have a longer transit for 93. It's certainly hundreds of dollars more a year doing 93 for me (not just a "few bucks"), but I'm not skimping on it regardless.
08-15-2023, 03:23 PM | #30 | |
Rep 186
08-15-2023, 03:34 PM | #31 | |
Rep 3,681
But then let’s be realistic, if we start to consider something fails, then knock sensor and using 87 are probably at the bottom of concern l. How about water pump fail, oil pump failure, injector fail, timing chain guide fail …. All of these can cause catastrophic engine failure. These were all at some point know BMW engine issues. Last edited by eelnoraa; 08-15-2023 at 03:45 PM.. |
08-15-2023, 09:17 PM | #32 | |
Rep 3,507
2022 M8 Comp Convertible
08-15-2023, 09:36 PM | #33 | |
Rep 3,681
When running lower octane, what usually happens is “ping”. You can hear. This is what knock sensor detects too. It is local unintended combustion in combustion stroke away from the spark. If you keep driving, sure some thing will break. |
08-15-2023, 09:57 PM | #34 | |
Rep 3,507
