03-30-2023, 10:34 PM | #1 |
Rep 4
Lost all power while driving
My 2020 m50i has sat for over 6 months. I replaced the battery and drove to the shop to get it registered. On the drive home while cruising at 70 the car shut off and everything g went black. No lights no engine nothing. I coasted to the shoulder and hooked up my noco so I could open the tailgate. Nothing I tested the terminals without the noco and got 12.7 volts but nothing in the car worked. Completely dead. I had no warning lights or messages before this happened. Any ideas? The truck has a little over 14k miles
03-31-2023, 01:40 AM | #4 |
18
Rep 46
Is it possible that it was the wrong size battery and the terminals shorted when you closed the lid?
I have also heard that the battery needs to be programmed/registered. Maybe it shut off for that reason? |
03-31-2023, 07:29 AM | #5 | |
Rep 4,338
I have the original battery and I was on my way back home from a 5K mile trip a few weeks ago and have about the same mileage on mine as you do and like you doing 70 on the highway when all of a sudden my dash and display went totally black. The car didn't skip a beat though and after about three seconds the dash and display came back on like nothing ever happened. These things freak me out, it's always been electronics on my BMW's that are flaky. So, how did your story end? |
03-31-2023, 07:38 AM | #6 |
Rep 7,489
Until we get more info...I'm inclined to think that the battery lost contact somehow.
If you didn't install the battery yourself...then there's a reference that is missing and you may just need to lift the stuff out of the way and double check all the connections. And not just the connections but the battery hold downs, too! (see pics below from my f06 6 series) The hold down's can be easily overlooked or improperly replaced which can allow the battery to move as the vehicle goes over bumps, around corners, and stop/start situations. This movement can loosen the pos/negative terminals or other connections. And some battery setups have multiple connections...there can be up to six positive connections and two negative connections...and one must make sure those connections are reinstalled correctly. Good luck...and post back any updates.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-31-2023 at 08:01 AM.. |
