      08-15-2023, 01:45 PM   #89
jpw172
Drives: 24' BMW X5 50e
Originally Posted by dm50e View Post
Also have 2024 50e with 21" Hankooks (staggered). Struggling with ridiculous amount of what seems to be road noise from the front left (just like jkramerxxx7 describes) and difficult to hear if you are in the passenger seat. — especially loud on mediocre to poor roads. Finally had dealer install vibration dampeners but initial drives do not seem to show any improvements. Very disheartening as otherwise the car is great. Drove similar 50e with Bridgestones (same size) and noise was no different. Has anyone figured out if it is the runflats or the tire size or both. Very expensive to switch wheels and tires out. Any insight is appreciated. Impression I am getting from the dealer is that this is the way the car is. As most 50e's are pre-sold, difficult to find a test drive of one with 20" tires to see if there is a difference.
I test drive a 50e before I bought mine, it had 20”, I believe conti’s or Mich were on them and did highway and city and didn’t have any noises. I can report back when I pick mine up…
      08-15-2023, 01:54 PM   #90
jpw172
Originally Posted by 915M View Post
I have not much road noise with 21" Hankook on asphalt.
But on the cement, there is road noise.
I feel like every car and tire I’ve had on cement has not been super quiet.
      08-15-2023, 03:52 PM   #91
dm50e
Drives: BMW 50e
The noise situation with the 2024 X5 50e (with 21" RF) is not in your imagination. We have had it since we picked the car up in late April. After the delivery, I test drove 2 other 50e's with 21" RFs from different tire mfgs. There was no difference. Service foreman and a BMW corporate rep. both drove the car and acknowledged the noise (much louder on the driver side especially on poor roads) but claimed that is the way the car is. Not an acceptable answer. After contacting BMW corporate several times, they finally agreed to put the vibration dampeners on at no charge. There was basically no difference. The service foreman did a temporary switch with 20" tires and claimed there was no reduction in the noise. At the outside chance I requested a buyback on the vehicle and was turned down. This is obviously a design defect since the brand of tires makes no difference. BMW corporate is hiding behind "all the 50e's are like this" - the doesn't make it right or acceptable. Unfortunately this is our 1st BMW in 35-40 years (should have stayed with MB and waited for their 450e Hybrid) and probably our last BMW due to the way corporate and the dealership has handled this. From General Sales Mgr we got the typical line "none of our other customers have complained about noise" My response was "would you like me to show you the posts online?" BMW Corporate, the dealership and the car have been a huge disappointment due to this issue. Will probably trade out on a MB 450e Hybrid and take the loss. Have already talked one friend into canceling his order due to the noise situation. It is truly unfortunate that BMW Corporate refuses to stand behind their product and make things right.
Appreciate 4
Raikkonen338.50
iTomH52.00
Baze10.50
      08-15-2023, 05:07 PM   #92
Bmwx5z
Drives: bmw
does anyone have audio recording or video of this noise issue? one of my main reasons to get an X5 is of its quietness.... if this is a major issue, its a deal breaker for me.
      08-15-2023, 05:14 PM   #93
carboy40
Drives: X5 50e
I also have a similar noise, like described above it’s like the resonance you get from going over a bridge paved with cement, but constant. Whenever I lean forward and put my head near the steering wheel the noise goes away, but in that normal driving position it’s quite pronounced.
      08-15-2023, 05:28 PM   #94
apw2607
Drives: 2024 X5 50e M-Sport
I have 21" wheels with the Dunlop RF on my 2018 X5 and its noisy driving over cement road surface. Asphalt is fine though.
I'll get the 50e next month. I also ordered the 21" wheels.
I expect it to be no different.
      08-15-2023, 05:49 PM   #95
RNorb
230
Drives: 2020 X5 40i, 2024 X1 28i
Same here...its a deal breaker. My 2020 X5 with acoustic glass is really quiet. I expect the same in a new 50e
      08-15-2023, 06:04 PM   #96
mojoJJ
mojoJJ's Avatar
Drives: 2024 X6 xDrive40i
Get better non run flat tires. It’ll make a lot of difference.
      08-15-2023, 06:05 PM   #97
mojoJJ
mojoJJ's Avatar
Acoustic glass cannot help with tire road noise. You need better non run flat tires. Get 20” wheels for better tire availability.
      08-15-2023, 06:39 PM   #98
Okpotato
Drives: 24 50e
I'd still get one, but make sure you drive the actual car you're buying before you sign the paperwork. Nearly every tire size and brand is mentioned in this thread, seems to be no pattern to it at all. Someone further up has an identical vehicle (model, wheels, tires) to mine and is apparently fine
I can rent an X5 or X6 for a day on Turo for $1-200. If the dealer gets nowhere I may get one that's on 19's and temporarily swap the rims and see what happens. Seems nuts but less risky than buying new tires.
      08-15-2023, 08:57 PM   #99
eelnoraa
Drives: G05 X5
Originally Posted by quad_drive View Post
The damper itself has a marking for 90hz-120hz. That's interesting. Since I have 20" wheels, my test case may not be the best.
For those with 21" and 22" wheels, if those are missing from your cars, maybe something to look into. I would just get them and put them on yourself instead wasting time and effort trying to convince BMW to put them on. Either way, I thinking it improved the car for little $$.
Very interesting finding. Can I ask if you happen to know their weight? Does it feel like a piece of lead that is coated with rubber? Reason I ask is I have way to make lead piece in very precise weight as shape. I think can easily make it
As to this piece changed driving behavior, I kind of doubt. In theory, where this piece get installed, it become unsprung weight. Typically, the less the better.
      08-15-2023, 09:49 PM   #100
iTomH
Drives: 2024 X5 50e
I have the 2024 X5 50e with 20" Continental run flats. I am totally disappointed with the road noise. I've driven Lexus vehicles for the past 25 years. My RX350 was extremely quiet. The only reason decided to buy my first BMW was because Lexus only offered a 4 cylinder engine in the 2024 RX350. I have been able to live with the multiple issues with the electronics and the less than stellar customer service at my dealership...but the road noise should be a major embarrassment to BMW.
Baze10.50
      08-15-2023, 09:56 PM   #101
Raikkonen
Raikkonen's Avatar
339
Drives: 2024 X5 M60i
Originally Posted by Heavyd View Post
Are there torque specs?
108Nm according to the BMW TIS
Baze10.50
      08-15-2023, 09:56 PM   #102
iTomH
Drives: 2024 X5 50e
I feel the same way. My X5 50e was my first BMW after driving Lexus products for many, many years. I didn't expect an $85K vehicle to sound like a bottom of the line Chevy product. BMW should be ashamed of what they are selling.
      08-15-2023, 11:24 PM   #103
GoldfishTX
550
Drives: G80 M3CX, X5 50e
Is it louder than the 23? Had a loaner today that was a 23 40i on 21 or 22 inch wheels and it was pretty quiet.
      08-16-2023, 09:05 AM   #104
Raikkonen
Raikkonen's Avatar
339
Just got my car a few weeks ago and it suffers from this same "resonance/droning" that everyone's complaining about.
I'm on 21' wheels w/ Hankooks.
A couple of observations:
The lease I just returned (2020) had acoustic glass and was SIGNIFICANTLY quieter than my lci. Although I ran non-RF's in the winter, I did run RF's in the summer (Pirelli). This car also had 21's.
My 2020 also had DHP, and my lci has full air suspension, so I expected there to be little difference in overall noise, and I couldn't have been more wrong.
My 2020 also had the acoustic dampers on the control arms, but my new car does not, so I'll at the very least order these and install them.
The true test from here will be my switchover to non-RF's for the winter, in combination with the dampers. It's unbelievable how intrusive this resonance is while driving, on all but the smoothest roads.
I'm amazed at the difference in overall interior noise between the two model years...
      08-16-2023, 11:18 AM   #105
Lionel Hutz
Lionel Hutz's Avatar
228
Drives: '24 X5 50e
Is the noise people are complaining about immediately apparent on a test drive? Any particular speeds or road conditions that trigger it?
I drove two 40i LCIs (no 50e available). One had totally unacceptable road noise and one was fine. I chalked up the road noise to the 22"s on the first one but am now wondering.
      08-16-2023, 11:41 AM   #106
915M
Drives: BMW X5 50e
I have 50e 21' with Hankook Ventus and it is quieter than Rx350.
Anyone with Hankook tire experience same thing?
      08-16-2023, 12:22 PM   #107
jpw172
I test drove the 2024 50e with 20” in Pittsburgh over rough roads and highway and had no noises and was at various speeds and road surfaces. RF tires generally have more noise and larger wheels also produce more noise base on tests so wondering if it’s a combination of these factors, although there are others with RF and greater than 21 who aren’t having the issue so who knows.
      08-16-2023, 12:30 PM   #108
jpw172
Originally Posted by jkramerXXX7 View Post
I can't imagine them being louder than my current Pirelli's but I'll find out in a few days. I decided to change after reviewers noted the Michelins to be exceptionally quiet for a run flat. I can always change back to Pirelli's if needed. Comparing a non run flat to a run flat is not exactly fair in regards to noise.
Did you get the Mich out on yet? If so any difference?
      08-16-2023, 12:31 PM   #109
arRod1981
arRod1981's Avatar
Drives: 2022 BMW X5 45e M-Sport
Whilst I don't have a 50e, I do have a '22 45e with the same tires you do, and it's incredibly quiet. The only time it's loud is when the roads are bad (construction zones, etc.).
      08-16-2023, 01:04 PM   #110
jpw172
Just a thought. Some tires are a directional tire, is anyone making sure the tires are installed correctly?
