10-13-2022, 01:07 PM | #24 |
Rep 223
Drives: X5 45e
Thanks for this! I started hearing the wind noise recently, and after taping over that gap, it went away. I’ll make an appointment with my dealer to have the seal replaced per the SIB.
10-14-2022, 08:17 AM | #25 |
Rep 291
After reading this, I went to check on my 23 45e.. I see that gap there too. It's crazy to me how this is still an issue after all these years being in production. It's a simple fix where the seal is cut half an inch too short.
I do hear some wind noises at highway speed. BMW needs to get on top of these little QC issue. |
12-21-2022, 09:34 AM | #26 | |
Rep 774
Edit: dealer replaced the seal several months ago, problem fixed.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) Last edited by gofast182; 05-23-2023 at 10:07 AM.. |
03-15-2023, 11:06 AM | #27 |
Rep 9
I have this same issue. Noticed increased wind noise in my MY22 about 2 months ago, and found the gap in the sunroof seal mentioned here. Manually sliding the seal from one side to the other changes the amount of noise in different parts of the cabin, so I’m confident this is the cause. Does anyone have a picture of what a properly installed seal looks like? I have a service appointment coming up and given the SIB doesn’t cover newer model years explicitly, I want to see if it’s an obvious difference that can be spotted by looking at other cars on the lot.
03-15-2023, 11:08 AM | #28 | |
Rep 195
03-15-2023, 11:48 AM | #29 |
Rep 6,835
FWIW, wind noise along with drag is one reason manufacturers want to consider cameras and video screens rather than those mirrors sitting out there that increase drag, add complexity because you may need to heat them, and, are harder to get a slippery surface.
The DOT in the USA so far, has rejected any use of cameras versus the required mirror, but that may eventually change. Just like it too them years to approve the anti-dazzle headlights that have been readily available in other parts of the world. |
03-15-2023, 12:49 PM | #30 | |
Rep 624
Can’t be bothered to have it fixed as this car is going soon as I’ll be getting an LCI. I must say though, it really irritated me for months until I discovered this thread and found the gap in the roof seal. |
03-15-2023, 02:52 PM | #31 | |
Rep 1,371
03-15-2023, 06:59 PM | #32 |
Rep 3,936
03-16-2023, 08:31 PM | #36 |
Rep 3,936
03-16-2023, 10:04 PM | #37 |
805
Rep 1,790
Here's more information for you all on wind noise troubleshooting and repair.
https://g07.bimmerpost.com/forums/sh...5&postcount=41 |
03-16-2023, 10:19 PM | #38 |
Rep 1,371
04-02-2023, 03:45 PM | #39 |
Rep 859
Wandered over here from the X7 side. My 2020 X7 does exactly what is described here. Is your picture how the seal looks on both sides? I can slide mine back and forth...it seems to be about a half in lch too small. I just ordered 54-10-7-493-155 and will replace it myself.
2023 iX M60
2023 i4 M50 2024 Wrangler 392 Last edited by Young04; 04-02-2023 at 05:15 PM.. |
04-02-2023, 09:44 PM | #40 | |
805
Rep 1,790
zanvos2.00 |
04-03-2023, 05:31 AM | #41 | |
Rep 859
2023 iX M60
2023 i4 M50 2024 Wrangler 392 |
04-03-2023, 02:58 PM | #42 |
17
Rep 39
05-22-2023, 06:05 PM | #43 |
Rep 104
I picked up my 2023 X5 45e back in September. It developed the wind noise about a month ago. Took it the dealer and they replaced Gasket, Glass Cover and Set Seal for Glass. The also used 6 x Screw Glass Panel. The sound is gone. The diagnosed the problem using painters tape.
01-08-2024, 05:46 AM | #44 |
Rep 230
Hey folks, had the same prob with mine, same hole in the rubber seal as 'maher's post.
Easy solution - take it to the dealer. As soon as I brought mine in, the service person said 'yeah we've seen a lot of those'. Mechanic took the car for a test drive just to rule out any other possible causes that would need to be addressed. Ordered replacement seal for roof for me, appt. on Jan 16th to install. The notes from the mechanic were: "Seals are too short. Sunroof seals have shrunk and need to be replaced". I didn't know these could shrink....but whatever, as long as they fix it. |
