02-05-2021, 03:50 PM | #89 |
Rep 6,806
I haven't tried it, but I'd be really surprised if when you have something plugged into the trailer electronics, that you could disable the trailer mode.
volodp198.00 Flying Ace4984.50 |
02-05-2021, 05:19 PM | #90 |
24
Rep 38
Also just an fyi. I put a cargo carrier on the hitch, no connections other than it mounted. When i tried to back up, it slammed on the brakes thinking there was something in the way. Hence trailer mode deactivating the systems.
02-05-2021, 07:28 PM | #91 | |
Rep 810
It a bit unintuitive, because why would you want to turn off trailer mode with a trailer connected??? I can understand where you're coming from, but even with a bike rack there are at least a couple of reasons I wouldn't disable trailer mode: 1. With extra load on the rear; even with 1-2 bikes, the cars dynamics are changed, and the stability control system needs to know about it so that it can compensate for any unexpected incidents on the road; and 2. The cars sensors and camera would sense/see the rack and maybe throw some warnings/alarms and unexpected behaviors (eg. like cross traffic alert, reverse parking sensors and associated emergency braking may kick in un-expectantly). My gut tells me play it safe and just leave it enabled. You only lose steering assistance in the overall Driving Assistance feature set in cruise control, distance control based cruise-control still works and is fine while towing. In fact, the last thing you want is driving assistance making a sudden driving correction while towing - things could turn bad really fast. Last edited by James_G0540i; 02-05-2021 at 07:36 PM.. |
02-05-2021, 11:35 PM | #92 | |
Rep 2,609
In fact, that's the last thing you want quite regardless of whether you're towing something or not. What difference does bad/buggy forward tracking make to towing?
02-23-2021, 05:18 PM | #93 | |
Rep 62
post a pic or two. I have a system on order and have no idea which one I get installed at BMW next week.
528I 1998 SOLD
528Xi 2009 SOLD 535Xi 2013 ----- Daily driver 2020 X5 G05 i40 -- Family car |
02-24-2021, 01:07 PM | #95 |
Rep 62
Thanks James!
What do we do about a bike carrier? (without a tube...)
528I 1998 SOLD
02-24-2021, 02:53 PM | #96 | |
Rep 810
Don't bike carriers use that square tube fitment? |
02-24-2021, 03:12 PM | #97 | |
Rep 62
528I 1998 SOLD
02-24-2021, 04:02 PM | #98 |
Rep 1,292
Are you not required to use safety chain in Australia? I don’t see any provisions for them on that design.
02-24-2021, 07:06 PM | #99 |
Rep 810
Yep, absolutely, that's what these are, and yes both are on the same side. This is definitely different to what I had for my F15 X5, which had one hole on each side of the towbar, but the D shackles fit, it does the job so I'm happy.
02-24-2021, 07:40 PM | #100 |
Rep 6,806
Nobody in the US carries a bike carrier that will fit on the gooseneck used elsewhere. You might be able to buy one and have it shipped, but this is not compatible with US style trailers or bike carriers and probably has a different plug for the trailer interface, likely a 13-pin plug (a nice connection, quarter-turn, waterproof, locking plug). That hitch is quite a bit more expensive than that offered in the USA. I’d heard, about a $3k option, but haven’t looked recently. They make a manual version that doesn’t motor the gooseneck, and that appears to be the one pictured that is less expensive, but still lots more than their US OEM one. In the USA, if you want one that is removeable, the stealth hitch would work, but getting the electrical interface makes that easily more than twice as expensive as the OEM version.
02-24-2021, 07:55 PM | #101 |
Rep 62
Well, I appreciate that info. Kind of unfortunate really. But it makes sense.
I bought the soon to be installed unit to pull a small boat, so that function will be well accommodated with this non-motorized unit. If I want to transport 3 or 4 bikes, I’ll buy a cheap cargo trailer. 😁
528I 1998 SOLD
07-12-2021, 09:11 PM | #102 |
Rep 92
Bit late to the party, but yes, the factory hitch changes several wiring harnesses in the vehicle and upgrades the cooling fan to 1000W (up from 650W on 30 & 40 vehicles. The M50d comes with the 1000W fan and heavier duty battery harness as standard, however, so makes it closer to 'factory' when fitting an after-market hitch.
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas! Previously 2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D |
