05-12-2021, 05:22 PM | #133 | |
Rep 589
05-12-2021, 10:10 PM | #134 |
Rep 8,864
Drives: eVeRyOnE mAD!
SlyBrackets offers a full 4-screw plate frame, which i used to mount mine including the Leveler. (the plate will angle downward a bit without the Leveler.)
Tch-Nrd124.50 IxnayEslaTay1.50 |
05-12-2021, 10:33 PM | #135 | |
Rep 589
05-17-2021, 08:55 PM | #136 | ||
Rep 7
2021 X5 xDrive40i M Sport Package
2018 X6 xDrive35i |
02-11-2022, 07:32 PM | #137 |
Rep 5
02-11-2022, 09:33 PM | #138 |
Rep 6,121
I still don't run a front plate but that's unfortunate
02-14-2022, 03:32 PM | #139 | |
Rep 508
Drives: 2022 X5 xdrive40i msport
Thanks for the post. I wanted to make sure you have no issues with any of the sensors ie: parking and assisted driving pro etc. with this plate holder. This is just one last check before I order |
02-14-2022, 08:46 PM | #140 | ||
Rep 8,864
02-15-2022, 01:38 AM | #141 |
Rep 508
03-02-2022, 04:08 PM | #142 |
23
Rep 39
Drives: 2022 BMW X5 xDrive40i
Thanks to everyone for their contributions to this thread. My 2022 X5 xDrive 40i with M Sport package with every optional package available went into production today, and I just ordered the Sly bracket with 4 screw holder and leveler so I'll have it when the car is delivered to the dealership.
Having this thread allowed me to make an informed choice. |
03-14-2022, 07:57 AM | #143 |
387
Rep 301
I used rare earth magnets to attach the front license plate on my Miata. I taped magnets to the backside from the front fascia and taped matching magnets to the license plate. Those magnets are so strong that you really have to be careful with them to not loose the tip of a finger and that license plate isn't going anywhere at any speed. Yet, there's no modification to the car at all and it looks perfectly placed on that car. Hopeful that a similar solution is available to me on the X5 M50i I just ordered.
https://www.amazingmagnets.com/default.aspx |
03-14-2022, 03:51 PM | #144 | |
Rep 463
03-14-2022, 04:06 PM | #145 | |
387
Rep 301
There was quite a comedy of mistakes when I first started working with these things. For example, I wanted to lay two of these magnets on a strip of tape before applying to the back of the fascia. Nope, as soon as I let go of the second magnet on the tape that was placed 3 inches from the other magnet, they snapped together so hard and fast that I was pretty happy my fingers weren't in the way. This is how I know that you can't get them back apart! Four magnets taped to the plate and four taped to the backside of the fascia has the license plate very firmly attached. I can lever it off using a lot of force and it leaves no mark on the fascia. |
njnets21245.00 |
03-21-2022, 07:22 AM | #146 | |
Rep 13
Have you checked if blocking the radiator with the license plate can cause any cooling issues? and if so, is it even possible to install the plate a little higher so that it sits above the lower grill? Thanks! |
04-18-2022, 03:30 PM | #147 |
Rep 508
This installation of slybracket doesn't block anything. Looks great too. I will show you some shots of my installation and what I did.
I put a felt pad on the back where it could possibly touch the front of the grill but it fits like a glove.. No issues at all with any sensor and it doesn't block airflow at all. It also has spacers or you can use your own washers to dial it in close.. I love it Last edited by 1Mors; 04-18-2022 at 05:43 PM.. |
nZtiZia4752.50 PittsDriver387.00 |
05-19-2022, 07:34 AM | #148 |
Rep 18
Has anyone used these. Was going to order for my g06. Says it works with msport and adaptive cruise.
https://carbonio.com/products/bmw-x6...se-plate-mount |
05-19-2022, 07:46 AM | #149 |
Rep 8,864
most have opted for the Sly Brackets but I've read a couple use the Carbonio though no photos
05-23-2022, 07:28 PM | #150 |
Rep 6,945
FWIW, read recently that CA has a pilot program where they are using a stick on plate to go on vehicles on the front, so no holes, and it peels off with no paint damage, assuming the paint was in good shape in the first place. If it works out, they may allow them for the rear as well.
05-28-2022, 06:00 PM | #151 |
Rep 68
https://licenseplatewrap.com/
Reading through the site and other references, it looks like it's still a pilot program but available to a limited amount of people. Personally, if the DMV okayed it then who cares who makes it. Probably just needs to be properly reflective where they want. I'm sure there's a bunch of people on Pinterest already cranking them out. Plus, I seriously doubt the police are going to pull you over if it looks legit. If it matches the back and doesn't come back as a stolen plate or not matching the vehicle it's on. |
05-28-2022, 07:42 PM | #152 |
Rep 8,864
if placed on a vehicle in a state where it's not approved, it's rarity will surely get one pulled over and likely cited
08-02-2022, 07:33 PM | #153 |
Rep 589
I just installed the SlyBrackets today, but the plate is slightly tilted forward. I did bought the leveler, but couldn't follow the installation instruction. Can you show a picture without the license plate, so I can see how the leveler is supposed to work? Thanks
08-02-2022, 09:44 PM | #154 | |
Rep 8,864
