10-16-2020, 08:37 AM | #23 |
Rep 1,294
Only if you have the BMW OEM wiring harness and BMW combox. If you use the Stealth standard harness they cannot program the car.
10-16-2020, 10:16 AM | #24 |
Rep 27
10-16-2020, 08:27 PM | #25 |
170
Rep 301
No programming required, you just need the controller and harness (not available in North America, yet).
See the following post and video: https://www.bimmerpost.com/forums/sh...php?p=26762867 Update: I had my X5 programed. Works like a charm!
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet Last edited by Shawzy44; 01-11-2021 at 05:35 PM.. |
12-05-2020, 08:48 PM | #26 | |
Rep 83
Drives: G05 45e, Porsche Macan GTS
I didn't bother spraying sections that will be concealed, thus the "partial" paint job. I also marked the width that I determined was necessary to access the lock on the left side and the latch on the right side, versus just cutting where the instructions indicate. I would rather have a precise fit and less of a cut out area than to have a huge portion exposed. I am definitely making a smaller opening (width and depth) than what they suggest. This install was quite involved - it took me about 5 hours start to finish, but I was working completely alone and I have never tried taking apart a car like this before. A few minor issues (broke one small plastic tab, dropped a screw inside the battery compartment), but nothing really major.
'21 X5 45e
'18 Macan GTS '15 Ram 1500 EcoDiesel |
James_G0540i446.00 |
12-23-2020, 07:58 PM | #27 |
Rep 128
Drives: 21 M5 Comp, 21 X5 M50i
Has anybody asked a dealer for a quote to install a stealth hitch?
I'm assuming it can be installed on an X5 M50i ??? |
12-23-2020, 09:16 PM | #28 |
Rep 6,872
Long ago, with the original iteration of this (Invisihitch), I had my dealer install it on my GT. Cost about $400. At the time, if you were near the factory, they would install it for a lot less since they had lots of experience with it.
It's not particularly hard. The biggest risk is to break a tab off of the bumper cover. Then, it's buy a new one and have it painted as the tabs cannot be repaired. BUt, you have to be fairly heavy handed to do that. It's much easier if you've done it before. It's safer to have a second person to hold one end of the bumper cover while you're releasing the tabs so it doesn't twist. Now, should you want to also add in a wiring harness, that's a bit more involved. |
mikep1236.00 |
10-01-2021, 12:31 AM | #29 |
146
Rep 344
Anybody tried towing with a rack option only? It looks very solid I don't understand why you need to buy a tow accessory separate (not the harness).
10-01-2021, 01:56 AM | #30 | |
Rep 6,872
In expert mode of BimmerCode, you can flip the one switch needed to enable the towing camera view. I'm not sure that it also enables the stability control or disables the PDC...those might be separate software switches. |
05-12-2022, 05:16 PM | #31 | ||
Rep 4
How did you get it to work? Please share, Thanks very much, |
05-12-2022, 05:39 PM | #32 |
Rep 6,872
Newer X5's, at least in the USA, do not come prewired for the towing package like they used to. Some markets get that, so far, not the US. THe only way to get towing is to buy it from the factory with full functionality. Last time I looked, nobody had figured out the interface on the G05 to get the automatic switch into towing mode, but I haven't looked in a few months, so that may have happened. Lots of places make CANBUS enabled boxes to make the trailer's lights work. Mine was bought with the tow package, so I haven't looked further into this.
If you want to actually tow a trailer, you need a ball mount adapter. They come in various versions, extensions, drop/rise, and ball size. Like this: https://stealthhitches.com/products/ball-mount-u3s |
05-13-2022, 10:04 AM | #33 |
Rep 1,294
I had to have mine coded after combox install. The car will recognize the combox, but it still needs to be programmed to car. This was my experience. Dealer or someone with ista or contact codemybimmer.com.
06-06-2022, 10:30 AM | #34 | |
Rep 18
Total cost was about $2000. The Stealth combo package (2" box receiver; towing ball; wiring harness) was about $1,000; rest for labor to install. I believe the 45e made the aftermarket installation substantially more complex if you want the wiring, which I did want. And I believe there is some loss of functionality. I was just interested in making sure that if I towed a light trailer of some kind I had lights and blinkers, etc. I have the M Sport option. I don't know if the OEM brakes for towing are an improvement on that or not. |
06-06-2022, 10:40 AM | #35 | |
Rep 18
For the Stealth hitch in particular, the towing ball assembly is incredibly solid--and replaces the receiver so that the tow ball assembly mounts directly to the center block. |
06-06-2022, 12:26 PM | #36 |
Rep 3,699
Looking at stealth hitch installation, it replaces the stock aluminum piece with a steel piece wit the center block. This steel piece must be very solid. But factory must have used the Al there for some reason. it looks like arear crumble piece to me. With the stealth hitch, does it compromise the crumble zone (should crumble upon impact) ?
04-16-2023, 06:46 AM | #37 |
2812
Rep 1,859
Drives: 23' X7 40i M Sport
Just installed my stealth hitch and using it for the first time with a bike rack. Is it normal to have some play / wiggle in the rack once installed? I would have thought it was rock solid but there is definitely some slight give left to right that I’m concerned about.
04-16-2023, 10:40 AM | #38 | |
Rep 869
I use Kuat racks that have the feature and the rack is so tight that it feels like part of the car itself.
M3 - X5 - 911 - Miata - Raptor - Edge
04-16-2023, 11:34 AM | #39 |
2812
Rep 1,859
I actually got the Kuat NV 2.0, but should have clarified that the wiggle can be found in the receiver without anything attached to it. So not exactly clear that it had anything to do with the bike rack. It’s very very slight but just felt there should be no play at all.
04-16-2023, 01:44 PM | #40 | |
Rep 869
04-16-2023, 03:14 PM | #41 |
2812
Rep 1,859
So bike rack aside (the Kuat is perfectly stable in the receiver itself), does your receiver not wiggle whatsoever when installed?
04-16-2023, 03:40 PM | #42 |
Rep 1,294
My 1Up does not wiggle or move. It has a ball wedge that tightens with a bolt.
04-16-2023, 09:43 PM | #43 |
Rep 6,872
Make sure that you've pushed the locking pin in and it's not just holding on with the spring-loaded part. There could be a little play between the receiver and its socket in the frame bolted to the vehicle.
For those that may not know, the internal guts of the stealth hitch can take a variety of square receiver or ball attachments. They all come out of the bottom of the bumper, thus putting it closer to the ground and with a bit of a lever when a load is applied. https://stealthhitches.com/products/...receiver-hitch https://stealthhitches.com/products/ball-mount-u5l Last edited by jad03060; 04-16-2023 at 09:59 PM.. |
04-17-2023, 08:15 AM | #44 | |
Rep 45
