      05-10-2020, 11:18 PM   #1233
goofytek
35
Drives: BMW 2020 X5 40i M-Sport
Originally Posted by rmorin1249 View Post
OBDLink LX. Android OnePlus phone
Thanks for your reply. Still waiting to see if anyone else that has an MX+ adapter and not a MX or LX on how their coding went.
Ftpohyeah285.00
      05-11-2020, 05:27 AM   #1234
jeet
Australia
26
Drives: BMW X5 (G05)
I have MX+ adapter with iOS and never had any issues.
      05-11-2020, 01:04 PM   #1235
Ftpohyeah
Ftpohyeah's Avatar
Drives: BMW
2022 X3 M Competition  [0.00]
2024 BMW  [10.00]
Originally Posted by LexxM3 View Post
Originally Posted by mitch57 View Post
Originally Posted by GTF View Post
Just finished 56 pages of this thread...had one question that remains unanswered (or my scrambled brain missed)...
Will Bimmercode allow tail lights to be turned on as DLR's?
There are occasions when I notice outside lighting becomes low, but not enough to turn on auto headlights. Tail lights always on would be a benefit.
I'm not sure about the X5 but on the X7 there's an option to enable Day Time Running Lights. On the X7 when you select this option you get both front and rear DLRs. This option is available on the X7 without coding.
On the G05 X5 (and I strongly suspect identically on G07 X7) whether rear DRLs and their controls are available or not without coding is governed by region and ISTEP version (later versions provide more control).
I am not certain whether below is complete, but the following is worth a shot and can now be coded in Bimmercode expert mode (or will be possible shortly in case I've once again confused what is currently in beta and what is in production Bimmercode):
HU_MGU/00003E52 ECU
- DAYDRIVING_LIGHT set to standard [02] to enable front DRL checkbox
- DAYDRIVING_LIGHT_REAR set to aktiv [01] to enable rear DRL checkbox
Whats the difference between rear DRL and parking lights?
??? I dunno. One has the word "parking" in it and the other the word "driving" — those seem like different and, in fact opposite, activities and related lighting functions :-P. In other words, I likely completely don't understand the question.
My apologies, wasnt specific enough.
Im asking what the rear DRLs look like compared to when having just the parking lights on.
For the US version the rear lights come on when parking lights are switched on. So does the front DRLs if its coded off in idrive.
      05-11-2020, 01:30 PM   #1236
mitch57
805
Drives: 2020 BMW X7 xDrive40i
On my 2020 X7 "DRL" and "Parking Lights" are two different light fixtures. Additionally, from iStep version 07/2019.59 forward there is an option in iDrive to "Enable/Disable" (turn on/off) the Daytime Running Lights. On my vehicle when you "Enable" DRLs it also turns on the tail lights as well as the front DRLs. NO CODING REQUIRED.
This is very easy to check. Enable Day Time Running lights in iDrive and make sure the car is parked and running while in the sun so the headlights don't come on. Put the vehicle in park, set the emergency brake, exit the vehicle and check to see if the rear tail lights are illuminated. Below are the steps to enable/disable DRLs on the X7 and I believe the X5 as well. In the US my only option is "Enable Daytime Driving Lights" with a check box next to it. Checking the box enables DRLs and unchecking the box disables DRLs for both the front and the rear. There is no separate option for the front and rear. It's all or nothing.
Via iDrive:
"CAR"
"Settings"
"Exterior lighting"
Depending on country specifications: "Daytime driving lights" or "Daytime driving lights, rear"
The setting is stored for the driver profile currently used.
      05-11-2020, 03:53 PM   #1237
goofytek
35
Sorry, I should be more clear. I'm checking if you're able up Tailgate code with your adapter or not. As I was able to do everything but Tailgate code with my MX. Thanks.
      05-11-2020, 04:06 PM   #1238
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
I had the same experience with my LX and Android phone, everything except the tailgate.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      05-11-2020, 04:07 PM   #1239
jeet
Australia
26
I have coded tailgate with MX+
      05-11-2020, 04:39 PM   #1240
rmorin1249
rmorin1249's Avatar
817
Let me clarify. I can partially code the tailgate but not the options that will allow closing without holding the inside button or with the fob. I'm using an Android phone. Maybe it would work with an iPhone. I'm going to return the adapter because it didn't allow any additional coding options over the Veepeak unit I purchased a year ago. I'll order a newer model if and when the additional tailgate coding options work with an Android phone.
      05-12-2020, 07:57 PM   #1241
Hernasty
Hernasty's Avatar
Drives: 2019 X5 40i MineralWhite/Black
So Bimmer Code "expert mode is not available for control units that contain safety related functions". Is this true and if so, WHY????
      05-12-2020, 08:21 PM   #1242
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Posts that contain their own answers within the post itself are so meta ...
smovva113.00
      05-13-2020, 12:51 AM   #1243
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Originally Posted by CaVenGG View Post
Did anyone figure out the coding about ambient light?
Originally Posted by Aimster82 View Post
Has anyone figured out how to change the ambient light color? I know you will have to replace one of the selections via code. EX: It will still say blue but when you click on it then it will be yellow/red whatever you program it to.
https://www.bimmerpost.com/forums/sh...php?p=26169693
      05-13-2020, 07:23 AM   #1244
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
This might be of interest: https://www.bimmerpost.com/forums/sh...php?p=26169693
Link isn't working
      05-13-2020, 08:35 AM   #1245
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Originally Posted by hkleyman View Post
Link isn't working
Well that's annoying. Fixed. https://www.bimmerpost.com/forums/sh...php?p=26169693
hkleyman135.00
      05-13-2020, 03:33 PM   #1246
BimmerVinyl
401
Drives: 2022 M240i
Anybody know if F95 digital dash (when it's in M mode) can be coded on G05 using expert mode?
      05-18-2020, 03:46 PM   #1247
swissguy
Drives: BMW X7 40i
Originally Posted by AlexDragu View Post
G20 Lane Change Assist-Done. Drive Assist View- Done. Remote Engine Start - Help - markad1 - 19-11-2019
BMW G20 320d xdrive. Build 11 2018. Driving Assist Pro package.
Big thank you to Simpaty who posted on other forums.
Lane Change Assist (select in idrive after coding)
SAS2
C_SWA_Vorhanden -> aktiv
HGU
Spurwechselassistent -> Aktiv
BDC (was the last available CAF under this ecu)
Drive Assist View (select in idrive after coding)
DKOMBI
CB_FZG_UMGEBUNG_FAS -> Aktiv
PIA_FZG_UMGEBUNG_FAS -> Aktiv
SICHT_ABSICHT_ENABLE -> Aktiv
I found this on a g20 forum
Did you do this with Bimmercode?
      05-18-2020, 03:57 PM   #1248
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
ADV can be done in bimmercode I believe.
Auto lane change assist requires access to SAS so can't be done in bimmercode.
      05-18-2020, 04:07 PM   #1249
swissguy
Drives: BMW X7 40i
Originally Posted by russelldav View Post
It's easy to code in expert mode
Could you provide the steps to code ADV in expert mode?
Thanks
      05-18-2020, 04:14 PM   #1250
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
Thanks
Go into the Instrument Cluster ECU (aka KOMBI), enable "Expert Mode" then change the following to Aktiv:
• CB_FZG_UMGEBUNG_FAS: aktiv (01)
• CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01)
• SICHT_ABSICHT_ENABLE: aktiv (01)
• PIA_FZG_UMGEBUNG_FAS: aktiv (01)
      05-18-2020, 04:19 PM   #1251
swissguy
Drives: BMW X7 40i
Thank you very much
      05-25-2020, 06:27 PM   #1252
MSX
Drives: X5
Wow this is a long thread, is it possible to create a pinned post for all the things possible
Im looking for help with the HBA, its currently default to on, can i change this default ?
      05-27-2020, 03:03 PM   #1253
sjak92
sjak92's Avatar
150
Drives: G05 30d MY24 + G20 M340i MY24
still no update for iOS
      05-31-2020, 06:42 AM   #1254
goofytek
35
I also returned my MX Adapter and got a MHD ENT Wifi Adapter which just came in. I was able to code the tailgate to close via remote now.
