      06-08-2020, 10:18 PM   #1321
alpha265
alpha265's Avatar
Drives: BMW X7
Originally Posted by mitch57 View Post
Originally Posted by alpha265 View Post
The alarm is not activated when you are inside your vehicle. The alarm is only activated when you leave and lock your car.
Ahhh! I see. I wonder what's causing that with the ENET adapter and not with Bluetooth adapters.
Have you asked Stephan from BimmerCode if he knows why this might be happening? Especially since this appears to only be a problem with this specific adapter.
It has nothing to do with the BimmerCode application since the coding was completed and the app was disconnected from the MHD when the alarm was triggered. It's very likely the unit is drawing higher than normal amount of current from the car's battery making the BMW alarm system believe the car is being tempered.
      06-08-2020, 10:45 PM   #1322
alpha265
alpha265's Avatar
Drives: BMW X7
FAQ from mhdtuning.com
Q: Can I leave the adapter connected?
A: Yes, but we recommend to unplug if the car is not used for longer than 7 days to prevent extra stress on the battery. Attention: On G Series cars with factory alarm system the adapter must be unplugged because the alarm will be activated after locking the car.
      06-08-2020, 11:40 PM   #1323
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
That is annoying. They obviously screwed up the power down design and made it into an FAQ as a fix. I will now likely return mine without opening, I wasn't looking for less convenience with a wifi adapter. If I wanted to plug and unplug all the time, I could just use the wired setup.
Ok, anyone try the modBMW OBD wifi adapter (https://modbmw.com/shop/wifi-enet/)? What did they screw up?
      06-09-2020, 12:05 AM   #1324
ikheetleon
Netherlands
219
Drives: BMW X5 45e 2020
With the f15 you could disable the voltage check on the obd port. Not sure if it can be done with the g05 as well.
      06-09-2020, 02:16 AM   #1325
mitch57
805
Drives: 2020 BMW X7 xDrive40i
What am I missing here? Do you guys who leave the adapter plugged in all the time re-code your vehicles every day or every other day?
I honestly don't see any reason to leave it plugged in all the time unless there's something I'm missing.
      06-09-2020, 02:21 AM   #1326
mitch57
805
I only asked thinking that BimmerCode might know since they most likely have tested all the ones they're recommending.
Or maybe, like me, they don't see it as an issue because most don't leave it plugged in after coding.
      06-09-2020, 03:48 AM   #1327
Frenetic
PANIC!
Frenetic's Avatar
482
Drives: 2020 X5 M50i
Well, Bimmercode app is actually pretty clear that neither of the two Veepak adapters are compatible with G-series cars (see pic), so best not to blame the app (for this). It gets pretty confusing which is why I have always recommended the OBDLink MX+ adapter as the simplest and most reliable for beginners ... but even they seemed to have screwed up with a firmware update recently (search for posts on the topic if interested).
The new thing you bought is an OBD to Ethernet cable. Did you also buy the Ethernet to Lightning interface? If not, you're going to have a little trouble shoving that big Ethernet RJ45 plug into your iPhone for Bimmercode *mobile app* to function with it . Anyway, the OBD to Ethernet cable should be fine, but you need the Lightning interface as well. This combo is very fast, but less reliable than the old-firmware OBDLink MX+ BT interface.
Not necessarily. This is what I saw in the app:
Nothing about compatibility.
I just never bothered to hit the “purchase adapter” button as I was searching directly off of that list.
      06-09-2020, 08:43 AM   #1328
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Yes, that's what you're missing. Yes, those that post answers to most questions here don't do this based on theories, they actually play with their cars all the time for that knowledge. And the interfaces are not just for coding, they're also for monitoring other drive parameters with software other than Bimmercode.
      06-09-2020, 08:52 AM   #1329
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Interesting. Disable the check with coding?
But anyway, a) I don't want to either disable part of or screw around with the security system in the car, b) as I've gotten older, I've reduced my tolerance of shit design — unless it's existential, I am not giving any respect or money to people or companies who hack together ("design") and peddle defective (by-design or by-manufacturing) products ... unless they appropriately ask me/customers for help and don't try to BS me/customers that their errors are somehow not errors.
      06-09-2020, 09:01 AM   #1330
ikheetleon
Netherlands
219
Yes, I wouldn't recommend it, but it was possible. Look at row 132 in the F15 cheatsheet: https://docs.google.com/spreadsheets...9s4/edit#gid=0
In FZD module you can code the OBD-Alarm option to nicht_active. Default is active.
LexxM31698.50
      06-09-2020, 09:21 AM   #1331
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Asked and got fast and honest answer from modBMW. Their product has the same problem: if left plugged in, draws enough current (150mA) to trigger G-series alarm ... so can't be left plugged in.
They also (correctly) point out the security issue of a POWERED ON OBD interface operating in an unattended car. However, BT adapters have solved the problem by powering down fully after car lock and one might very reasonably expect pairing security such as industry standard wifi WPA2 or 3 access passwords and encryption.
Alas, these wifi interfaces appear to be dirty hacks rather than usable products. Too bad, I was pretty excited by the idea of fast, reliable, secure, and convenient OBDII interface ... but one still doesn't appear to exist.
      06-09-2020, 12:39 PM   #1332
mitch57
805
I guess there thought is nobody leaves it plugged in once they've either finished coding or checked for "Check Engine" error codes and such. Obviously, there are some people, like you and a few others, that want to leave it plugged in all the time for easy monitoring convenience.
I did ask BimmerCode what his thoughts were on this issue. See below for what he had to say about the problem.
"the car monitors the traffic on the OBD port after it has been locked. This should only happen if there is actually a communication ongoing, but not if you just leave the adapter plugged in. I would still recommend to just unplug it after coding."
I'm guessing that the manufacturer will address and possibly develop a solution to the problem when/if they get enough complaints about it.
      06-09-2020, 12:49 PM   #1333
iknowdjz
Drives: BMW X5 2020
Hi,
Is there anyway to get turn signals in HUD on 2020 X5?
Thanks,
Z
      06-09-2020, 12:55 PM   #1334
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Originally Posted by iknowdjz View Post
Hi,
Thanks,
Z
Unfortunately no turn signals in any of the latest BMW HUDs.
      06-09-2020, 12:57 PM   #1335
iknowdjz
Drives: BMW X5 2020
Darn, had it coded on my 2016 5 series. Shame it’s gone. Thanks for the quick reply!
      06-09-2020, 12:59 PM   #1336
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
I am not going to hold my breath. Considering that both MHD's and modBMW's only comments publicly and semi-privately is "this is what it is" (rather than any indication that they consider it an issue) and considering that it now sounds to me a lot like an issue that cannot be addressed by a firmware update (it seems likely both used the same usual 1/2-assed chipset and the same usual 1/10th-assed reference hardware design for their products), this is unlikely to be fixed as it's too expensive to do so. Every h/w iteration costs almost as much as the previous one, hence, unlike software, you generally need to get h/w right the first time (unless your volumes are such that you can afford multiple h/w revisions to be in the field).
If I had nothing to do and thought there was actually enough of a market, I'd design and manufacture a decent interface myself, but that's not the case and the software/firmware behind these is not trivial if reliability and compatibility is the target (as, of course, it is). What I might consider, however, is an interposer (a "hardware power firewall", LOL) design between car OBD and these semi-broken interfaces to manage power flow between those (only very partially helps the security issues, however) ...
      06-09-2020, 01:04 PM   #1337
Frenetic
PANIC!
Frenetic's Avatar
482
Well I can confirm that this one works:
New 2M Ethernet to OBD Interface Cable E-SYS ICOM Coding F-series for BMW ENET
https://www.amazon.com/dp/B00MECEI14..._ZEU3EbW6AS1FC
It’s cheap, but you have to buy a lightning to RJ45 cable. I got the recommended one and it worked just fine.
Amatage Lighting to RJ45 Ethernet LAN Network Adapter for Phone/Pad, Phone Ethernet Adapter, 3.3ft/1m Cable, 10/100Mbps High Speed, System Required iOS 10.0 or Up https://www.amazon.com/dp/B07NW9HSL7..._3583EbVPFKWDM
Actually, this setup was cheaper than any of the wireless ones and it was extremely fast. I know some of the Bluetooth ones can be rather slow to code. This thing took a few seconds to code and update.
The only thing, though, is you have to turn on airplane mode, turn off WiFi and turn off Bluetooth, then connect the cable to your phone and wait until you see the Ethernet setting come up in the main settings. Once that is done, just plug it in, turn on BimmerCode, select the Enet Cable adapter and you’re good to go.
Oh, I didn’t spend much time, but I did turn off auto start/stop and switched the default mode to Sport. However, I wanted to add video in motion, but I couldn’t find that. Also, the brake force display was already set to the minimums.
      06-09-2020, 03:05 PM   #1338
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Drives: 2020 Mineral White 30d MSport
I was coding Sport plus on my 30d and found this "extra boost" option in Expert mode, does someone knows what exactly this option does? Has anyone tried coding it?
[IMG][/IMG]
      06-09-2020, 03:30 PM   #1339
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
[IMG][/IMG]
I don't think anyone knows yet and it doesn't seem to do anything that anyone (including me) has noticed on lone ICE engines so far. Best wishful-thinking-guess I heard to date is that it might be some kind of an obscure PHEV feature, like maybe a little electric boost to ICE operation under acceleration load. But no idea ...
      06-09-2020, 03:54 PM   #1340
sjak92
sjak92's Avatar
150
Drives: G05 30d MY24 + G20 M340i MY24
[IMG][/IMG]
Extra boost is a feature found on Hybrids, but like KERS in F1
      06-09-2020, 03:56 PM   #1341
sjak92
sjak92's Avatar
150
For anyone using iOS, I have had an email from BimmerCode that there is no set date planned for the update (which is already out on Android already)
      06-09-2020, 04:12 PM   #1342
Frenetic
PANIC!
Frenetic's Avatar
482
Do you know what the update covers and why they won't update iOS?
