02-04-2021, 03:16 PM | #1 |
Rep 2,644
Drives: 2019 BMW 540
Driver stuck in snow burns to death after repeatedly revving SUV's engine
https://www.yahoo.com/news/driver-st...144728601.html
I didn't know continuously revving a car can make it catch fire. First time I've heard of this. |
02-04-2021, 03:32 PM | #2 | |
Rep 273
Mosaud19983940.50 |
02-04-2021, 04:09 PM | #3 |
60061
Rep 19,541
The tranny wouldn't make the suv catch fire more like a fuel hose separating or melting from the heat but doesn't explain why he just sat in there locked in to be fried.
Mosaud19983940.50 |
02-04-2021, 04:20 PM | #4 |
Rep 5,728
Drives: 2019 M2 Competition
joooiiiiii438.50 Mosaud19983940.50 |
02-04-2021, 04:22 PM | #5 |
Rep 418
Mosaud19983940.50 |
02-04-2021, 06:30 PM | #6 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
Damn that sucks. My guess is that the heat fried something fuel or electrical related causing the fire, then the power locks wouldn't work and they couldn't get the door open. Wouldn't be the first time I've heard of that happening. First thought would be to break a window, but unless you've done it without a tool or a large rock it's harder than one would think, especially for someone in their 60's and from inside the car sitting down.
Mosaud19983940.50 |
02-04-2021, 06:33 PM | #7 |
Rep 536
Definitely some kind of fuel system related issue aggravated by operator error.
Mosaud19983940.50 |
02-04-2021, 06:53 PM | #8 |
Rep 1,168
I don't think car should catch fire no matter how much you rev the engine or abuse the transmission. Overheat, break, lock up - yeah, sure. But not ignite.
Mosaud19983940.50 bimmer pleaser V2515.00 |
02-04-2021, 07:10 PM | #9 |
C2H5OH
3915
Rep 2,144
More likely the trip down the embankment broke something. Maybe a plastic fuel vapor hose? Or maybe busted the oil filter adapter and oil was spraying on the hot exhaust?
https://d3lp4xedbqa8a5.cloudfront.ne...cx5-engine.jpg |
Mosaud19983940.50 |
02-04-2021, 07:13 PM | #10 |
3216
Rep 2,385
Sustained high revving can generate considerable heat in the components like the manifolds and exhaust, and if there's leaves or twigs in the area that can contact the exhaust and catch fire, then there's certainly likely to be enough flammable fluids in and around a car to catch fire.
Mosaud19983940.50 |
02-05-2021, 07:51 AM | #11 | |
Rep 1,168
02-05-2021, 08:32 AM | #12 |
3216
Rep 2,385
02-05-2021, 08:39 AM | #13 | |
Rep 5,577
That is why tire companies warn about spinning tires on ice. From ABS/brake fluid/rotor, through to engine connecting Rod to particularly CVT rubber/metal belt - I can see a few particular components that could fail creating impressive damage. And the post about leaves igniting. the heat could easily melt through snow and turn wet leaves in to kindling. |
Mosaud19983940.50 |
02-05-2021, 08:48 AM | #14 | |
Rep 536
They shouldn't catch fire, but sometimes design elements can cause unintended consequences. For instance the GM LS2 engine in the C6 Corvette had a braided steel fuel line that connected to the fuel rail under the engine cover. Not a problem. However the LS2 equipped Holden Monaro (GTO in the US) had a rubber fuel hose that under chronic hard acceleration could rub against the plastic engine cover and over time wear a hole in the hose. Fuel could then spray down on the exhaust headers and start a fire. One solution was the swap the rubber fuel line for the steel one like the Corvette, but most of us GTO owners would just remove the engine cover. However a few GTOs went up in flames pretty quick once the hose was compromised. |
Mosaud19983940.50 |
02-05-2021, 09:18 AM | #15 |
Rep 1,168
Exactly, and your example is a good one. Just like with that Mazda, if continuous revving caused some connector melting, or rocking back and forth caused overstretching of some hose, or breakage of some plastic connector, or even rubbing over a curb damaged a fuel line - those are all design flaws that shouldn't be there. Even the leaves that some insist on placing there - they shouldn't be able to get near hi-temp components. They shouldn't even clog the drain lines like in our BMWs, but I realize it's too much to ask...
Mosaud19983940.50 |
02-05-2021, 10:02 AM | #16 |
Rep 1,031
Drives: Like a bat out of hell.
Hmmm a new Mazda CX5 caught on fire just like that?
I've had dozens of SUVs and gotten stuck a few times and was able to rock the vehicle out without catching on fire. There has to be more to this story. I wonder if you get stuck in the snow often, why don't you just drive a tow truck. |
Mosaud19983940.50 |
02-05-2021, 10:41 AM | #17 |
C2H5OH
3915
Rep 2,144
I mean Lambos burn up just by downshifting aggressively ... LOL
02-05-2021, 11:08 AM | #18 |
Rep 2,644
02-05-2021, 11:29 AM | #19 |
Rep 1,031
Mosaud19983940.50 Noneya251.50 |
02-05-2021, 11:38 AM | #20 |
Rep 3,204
It's early in the year to be handing out Darwin awards, but it looks like we have a winner.
Mosaud19983940.50 |
02-05-2021, 01:04 PM | #21 |
Rep 740
It's quite possible he had a medical emergency, and died with his foot on the throttle.
Happens quite frequency, which is how cars end up going through houses, off bridges, etc. It would also explain why he didn't exit after the car caught fire. |
jmack548.50 |
02-05-2021, 02:37 PM | #22 |
Rep 1,031
I believe the mayor of our nearby town had a heart attack in his car and the car eventually ran into a pole but at a slow pace.
