02-15-2021, 01:01 PM | #1 |
Rep 202
Drives: 2023 BMW 760xi, 2024 BMW 530i
Hey Guys,
I have a 2021 X5 sDrive 40i (xline, Arctic Grey). When I purchased it, the car in the Instrument Cluster and Navigation screen was Jatoba Brown however I know it should match the color of my car. I went in and coded the proper color and changed the vehicle from xLine to Msport. I also changed the cluster to M Font from standard and that allowed me to add the M logo and other logos that are ordinary unavailable with stock cluster. Before and after photos are below with coding instructions. Enjoy. Also tested this on my 2020 5 Series and was successful. M Font and Logo -DKombi4 -Expert Mode -3001 KI_Parameter -AG_MPA_MSP_VIEW MPA_ANSICHT_260_SKALA (160 MPH Speedo, M Font) MPA_ANSICHT_330_SKALA (200 MPH Speedo, M Font) MPA_ANSICHT (160 MPH SPeedo, Non M Font, Able to add ///M Badge) LOGO 3001 KI_PARAMETER LOGO_SCHRIFTZUG MSP_LOGO CAR COLOR AND TRIM HU_MGU EXPERT MODE 3000 HMI_SPEECH TRIM_LINE MSPORTPAKET 3000 HMI_SPEECH VEHICLE_COLOUR
14
BimmerVinyl400.50 Silver.Solid116.00 mandomedic12240.50 Shawzy44158.00 babyghost94.50 Dr. Jekyll209.50 VetteZ0662.50 THATDONFC32.00 wall_nut63.50 Atlantis800012.00 mbernstein4.50 kristal980.00 Bottom1615.50 sac0249.50 |
02-15-2021, 02:44 PM | #2 |
1053
Rep 1,952
The TACH side of your cluster looks completely different than mine. Is that how your car came stock or did you change it via coding? My TACH goes zero to 7 and takes up the entire right portion of the cluster.
02-15-2021, 02:57 PM | #3 | |
Rep 158
02-15-2021, 06:08 PM | #5 |
Rep 5,450
This is great, I like the M gauge setup but miss that is doesn't show drive mode etc, but M font on standard gauges is a nice compromise!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
BimmerVinyl400.50 |
02-15-2021, 10:15 PM | #6 |
Rep 202
It came that way. Mostly all 2021 "40i" models come with a power gauge due to the fact it uses a 48v hybrid system. You can change it in the display settings to display a tachometer instead.
02-15-2021, 10:16 PM | #7 |
Rep 202
I completely agree
02-15-2021, 10:17 PM | #8 |
Rep 202
BimmerVinyl400.50 |
02-15-2021, 10:18 PM | #9 | ||
Rep 202
mrichione96.00 |
02-16-2021, 09:58 AM | #10 |
Rep 295
I assume there is no way to code in the wheels? I am picking up a set of 758i's that I'd love to have show up onscreen.
Shawzy44
2023 BMW X3 M40i 2019 BMW X5 40iX 2019 BMW 440iX M Performance Cabriolet |
02-16-2021, 09:59 AM | #11 |
1053
Rep 1,952
02-16-2021, 11:56 PM | #12 |
Rep 202
From what I see, no. It gives you a list of different versions. xline, sport line, luxury line, v12 excellence etc. The versions are preloaded to each picture.
02-19-2021, 04:44 AM | #15 |
Rep 109
Like the mix of fonts and original dash layouts.
How did you achieve this? Was it a Bimmercode level of change or do you need the more complex coding platforms to do this? Cheers
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
02-20-2021, 12:22 AM | #17 |
Rep 202
Absolutely. It literally took me two months to figure it out.
Silver.Solid116.00 |
02-20-2021, 12:23 AM | #18 |
Rep 202
I'd like to know that too. I'll try and figure it out also. Keep you posted
02-20-2021, 12:24 AM | #19 |
Rep 202
Hello, I made the changes with Bimmercode
02-22-2021, 11:57 PM | #20 |
Rep 451
Drives: 2017 X5 & 2020 X5
I have also being experimenting with the TRIM_LINE & VEHICLE_COLOUR in Esys since I got my G05 X5 late last year trying to get the rims to match what is actually on the car with no luck.
Note if you can access X_VIEW option in Bimmercode expert mode. You may want to activate this as on S Drive models it is turned off by default. May come in handy if you are ever towing a caravan or boat up a mountain pass
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
03-03-2021, 11:06 AM | #22 | |
Rep 242
Hi , sorry I don’t understand... i have the tachometer in the 1’ image.. if I want add only M badge under the camera (leaving 160mph) isn’t possibile? I need to change to 200 mph scale? I would leave the scale and the font.. (for me, is very horrible Msport font) Last edited by Fpgiuliano; 03-03-2021 at 11:15 AM.. |
