      07-27-2022, 06:39 PM   #23
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Originally Posted by Steveo View Post
Thanks Shaun.
Has anyone got 'Highway Exit Assistant' to come up on their Headunit/screen as an option?
Have done the coding but no joy, is the only one can't get to come up.
I don't have it either I think it only becomes active when navigation is active unfortunately I don't have any motorways near me to test it out all I have is Emergency Corridor Lane which doesn't work here in Australia
I did find a thread where IFR comments on it and it appears to only work when navigation is active
https://g05.bimmerpost.com/forums/sh....php?t=1740022
Read IFR's post 10 & 12
Hope that helps
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      07-29-2022, 05:02 PM   #24
Steveo
Steveo's Avatar
152
Drives: M4
Thanks, will have a try out here when I can and report back.
      07-30-2022, 11:23 AM   #25
mandomedic122
Drives: BMW 2019 X5M G05, Mini 2016 S
Originally Posted by Bambazonke View Post
Pm me your email address as I have a cheat sheet specifically for G05 that includes coding for the fourth ECU & more
Can I also get the cheat sheet as I am trying to do the same thing.
Thanks in advance.
Armando
      07-30-2022, 01:10 PM   #26
Silver.Solid
Silver.Solid's Avatar
116
Drives: '19 X5
I followed the cheat codes provided but sadly could not get the speed limit signs to display or the lane change assistant to work here in saudi. Going to try to update to the latest software 07/22 to see if i have any better luck.
      07-30-2022, 05:29 PM   #27
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Check with has128 he is also from KSA, his screen dump of his instrument panel at the start of the thread clearly shows speed limit signs up and working
What base maps do you have loaded? Is your X5 a Middle East spec model (822) with maps of the region? Lane Change Assist may not also work if you don't have the relevant maps as the car does not know what type of road it is on even though it has cameras. Speed Limit signs and location (Anticipation) will be part of your map database and will also require an FSC code which you should have from factory. Have you adjusted any settings in your KAFAS ECU? I am pretty sure an iLevel update will not solve your issue hopefully your dealer does not charge you for this.
      07-30-2022, 06:28 PM   #28
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Thanks in advance.
Armando
Armando
I have uploaded a copy of the file on the BimmerUtility Group file page on Facebook for users to download see link further up this thread
      07-31-2022, 05:20 AM   #29
Makaronai
Drives: X6 M50i
TLA not fully functioning in my country
Do you have copies of your old ncd files prior to update? If so use the NCD Compare option in BimmerUtility to check your coding.
It sounds like one of the land mask values might NOT be correct ie (FF,FF,FF,FF) or you have a syntax error in your FDL coding values. One minor syntax error is enough to prevent it from working
All *land* values is set to FFFFF, however I understand that some *country* values should be set to different digits to allow systems to function in certain countries?
Unfortunately no copies of old NCD.
Now my current situation follows:
- TLA works only in a warning mode: i.e. traffic light red is shown on the screens, car beeps but car does not stops when autopilot is enabled;
- Give Way assistant also works in a warning mode: give way and stops sign is shown on a HUD, but the car does not stop itself
      07-31-2022, 05:33 AM   #30
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Did you enable UCC (Urban Cruise Control) completely? Please look at my post above for the link to the BimmerUtility Group page on Facebook and download the cheat sheet & make sure you code both the SAS3 & DSC_VIP ECU,s
      07-31-2022, 07:26 AM   #31
Silver.Solid
116
Drives: '19 X5
thank you for your assistance on this and the cheat codes.
yes, i noticed has128 got it to work but i have tried a few times with no luck and again last night after the software update with no luck. I have not changed any settings under KAFAS ECU this time around... any hints to what triggered this?
I had 2021-1 map updates and last night updated to 2022-1 (i purchased the update online and loaded via USB.) I also have the relevant FSC as you mentioned because i can see it in ISTA. Sadly dealer here in KSA does not acknowledged the existence of software updates and will not touch it unless something is completely broken so all the updates are done at home via ISTA. Im now on software 07/22.
Update: went for an extensive drive today. Still no speed limit or traffic light sign recognition but lane change assist now works over 70kmh for the first time ever!
      07-31-2022, 02:54 PM   #32
Makaronai
Drives: X6 M50i
Finally I got your XML file - thanks a lot. Will try and report. BTW - sunroof automatic closing function is enabled but never worked. After the rain I got all car wet
      07-31-2022, 07:26 PM   #33
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Did you enable the sunnroof closing function in the FZD ECU as well?
It also a good idea to test it beforehand by spraying water on the windscreen sensor beforehand. The car should also be locked beforehand and wait about 10 mins to allow the car to go into 'sleep mode"
      07-31-2022, 07:30 PM   #34
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Sent you an email which hopefully will help identify why SLI is not displaying
      08-01-2022, 11:16 AM   #35
Makaronai
Drives: X6 M50i
Thanks! MGU was already coded from factory, but fzd2 3009 was not coded. Probably that's an issue.
Btw GREAT XML!
Unfortunately, after coding all TLA related settings - it's still not working. FUNCTION IS NOT AVAILABLE IN YOUR COUNTRY.
Don't you think KAFAS4 should be coded as well? CountrySLINPIMode?
      08-06-2022, 06:24 PM   #36
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Untick "Consider Traffic Lights" in your iDrive Menu and this will remove the error notification on your display the next time you start the car. Only enable the option in your iDrive menu when you are in a region/country where you know TLA location data is available
      08-22-2022, 03:31 PM   #37
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
Drives: Bmw 320d Touring xDrive Msport
I did successfully TLA in previous software version - map showed traffic light icons etc and TLA worked fine except automatic stop (it just showed the light in HUD and cluter). After an update from BMW- of course coding is gone. So I believe the mapping data already has all the traffic lights info - but my code sheet was not accurate now.
Hi friend,
I have g21 with firmware 07/2022.33
With previous version of firmware on my car (07/2021) TLA worked very well but now don't work.
Do you know if bmw change something?
I live in Italy and with various landmask set on FFFFFFFF I had no problems before
Some codes are not more available (like C_SLA_UCC_Land_aktiv on the dsc vip)
Can you help me?
Thanks
Ps all menu in HU_MGU are ok and I don't have any kind of error in the car, but the traffic lights are no longer seen by the car
      09-07-2022, 06:22 AM   #38
AndreiBes
Drives: BMW F20 120i 2019
Originally Posted by Fpgiuliano View Post
Hi friend,
Can you help me?
Thanks
having the same issue(
      09-07-2022, 07:03 AM   #39
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
Hi friend,
Can you help me?
Thanks
Hi,
There is a problem on mapping .
BimmerUtility support will fix the problem on the next release (I wrote them)
Stay tuned !
      09-07-2022, 08:22 AM   #40
PaoloV
Drives: BMW x5 Xdrive 40i
good morning , being a new user I can not do PM . I would also be interested in Assisted Driving view and Auto Speed Limit Assist (aSLA) and Traffic Light Assist (TLA). it is possible to make them with bimmercode or I have to buy Bimmer Utility. Thank you
      09-07-2022, 08:54 AM   #41
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
U need to buy BU
      09-07-2022, 09:05 AM   #42
PaoloV
U need to buy BU
Just purchased . What cable do you need to connect it to the car. are in possession of ODBDLink MX +. Thank you
      09-07-2022, 09:19 AM   #43
PaoloV
it also requires this . where can I find it . Thank you
      09-07-2022, 09:50 AM   #44
Fpgiuliano
Fpgiuliano's Avatar
Italy
43
U find esys setup it in bu installation folder
For cable, u need enet- odb2 cable
WARNING : But if have no experience in coding I reccomend that you first look for guides around forums because otherwise you risk doing serious damage to ur car
