08-07-2023, 11:42 AM | #1 |
5th BMW
Rep 23
Drives: 2024 X5 M60i
iPhone 14 Pro overheating on 2024 X5 charging pad
My phone 14 Pro hasn't once succeeded in reaching 100% from below 50% without overheating ever since I switched to the 2024 X5; with or without a case on. My same phone in the same case had absolutely no issues in my 2020 M550.
It could be the car in general, my car specifically, a recent iOS update, a new fault in my iPhone hardware, or something else entirely. Has anyone else experienced this with the X5 LCI?
2024 X5 M60i
driving assistance pro, parking assistance, executive, climate comfort, M sport, adaptive M suspension pro, trailer hitch, front massaging seatsPrevious: 2020 M550i xDrive, 2017 540i xDrive, 2014 535i xDrive, 2012 X5 xDrive35i Premium |
08-07-2023, 01:10 PM | #2 |
Rep 192
Drives: 2024 X5 50e
I've only had my 50e for a week, but the same thing happens to me. The phone gets really hot.
I got a USB C cable for the center armrest storage and plan to keep the phone in there to charge when needed. (I don't typically use the USB A outlet near the charging pad because I don't like the visible wires showing!)
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
08-08-2023, 05:45 AM | #4 | |
Rep 1,073
I have never used them in my BMWs. Always use the USB-C and you will get fast charging. I run a cable up from the arm rest and put the phone in that cubby or just leave in the armrest. If you don't use the 12v adapter for a radar detector you can use that for a fast charger as well. With iPhone 15 coming out soon, it will be USB-C as well with no more lightning port. Faster charging. |
08-08-2023, 03:14 PM | #5 |
Rep 100
Fun Fact: BMW's wireless charger is actually an induction heater.
2021 BMW G05 X5 xDrive40i - Tanzanite Blue/Coffee Merino - 11/2023.50
2018 Audi Q5 45 TFSI - Ibis White 2018 Tesla Model S P100D - Midnight Silver |
08-08-2023, 07:51 PM | #6 |
Rep 825
So, Can you keep a Taco Bell burrito warm for later?
Two is One and One is None
08-08-2023, 08:18 PM | #7 |
Rep 6,806
FWIW, the pro max exceeds the specs for the X5's charging pad in length, but the 14Pro does not.
Make sure that it is centered and the LED lights up and the LED turns blue (which means it is properly centered). |
08-08-2023, 11:44 PM | #8 |
Rep 100
Yeah! Just bring your phone along, put it on the charging pad and use the sceen as the surface on which you heat your burrito
08-09-2023, 12:56 AM | #9 |
26
Rep 36
[QUOTE=JDSX;30378241]My phone 14 Pro hasn't once succeeded in reaching 100% from below 50% without overheating ever since I switched to the 2024 X5; with or without a case on. My same phone in the same case had absolutely no issues in my 2020 M550.
It could be the car in general, my car specifically, a recent iOS update, a new fault in my iPhone hardware, or something else entirely. Has anyone else experienced this with the X5 LCI? Same problem here but I have also an Audi RS6 and I have the same problem…… iPhone 12 Pro Max…. |
08-09-2023, 09:18 AM | #10 |
981
Rep 1,560
Kwajtrader over on the Z4 forum built a fan for his charging pad.
https://g29.bimmerpost.com/forums/sh....php?t=1846723
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
08-09-2023, 10:31 AM | #12 |
Shitbox Express
19
Rep 29
You must have gotten the space heater variant- mine just won't charge fully, and immediately opens Apple Wallet, as if they just want more of my money.
08-09-2023, 09:25 PM | #13 |
Rep 6,806
The iPhone pro Max exceeds the maximum size the BMW user's manual says it supports. How that affects charging, can't say, but BMW essentially saying if it isn't within certain XYZ size, all bets are off.
08-18-2023, 09:19 AM | #15 |
5th BMW
Rep 23
I’m beginning to suspect this is the result of a recent iOS update. I’m seeing overheating on multiple iPhones when using a non-MFI wireless QI charger that has worked fine for years. No overheating on MFI MagSafe chargers. This is like how some charging wires suddenly stop working for Apple products.
2024 X5 M60i
08-18-2023, 10:52 AM | #16 |
Rep 68
First week with the '24 X5, and my iPhone 14 Pro Max gets HOT sitting on the charging pad. It doesn't get hot with/on any other charging device that I have. Fortunately I don't really need to charge it in the car, so for now I'm putting it in the adjacent empty spot to the right.
2024 BMW X5 M60i manhattan green
1998 Porsche Boxster arena red (race car since '11) --previous bmws-- 2008 BMW X5 xDrive48i mineral green 1972 BMW 2002 agave green |
08-18-2023, 06:47 PM | #18 |
Rep 82
My Wife's Mach-e is worse
My wife has a Mustang Mach-e and the wireless charger makes the phone so hot, the phone shuts down. This is on a 30 min. commute. I think its just an issue with the technology or should I say the quality of parts the car companies are using. I say that because I have other wireless chargers around the house and no other one makes the phone too hot. I am trying to figure out how to retrofit an apple magsafe charger into her car in the same slot.
I don't have the same issue in my X5 with my iPhone 14 Pro Max. I have taken it on a 3 hour road trip without issues but I don't think it charges the phone but keeps the same charge level with carplay running the whole time. |
08-18-2023, 07:08 PM | #19 |
Rep 192
Drives: 2024 X5 50e
Why not leave it in the center armrest plugged in to the USB C? Forget about maintaining the charge while using CarPlay. You’ll get to 100% while using CarPlay.
08-18-2023, 07:10 PM | #20 | ||
Rep 68
On the other hand, the iPhone 14 Pro (not Max) is within the stated max dimensions as I measure it. Adding a case might affect how it sits there. From the manual: Quote:
08-25-2023, 08:48 PM | #21 | |
Rep 83
Phone still warm, but wasn't overheating as before. https://www.amazon.com/dp/B08CMVKHDX...t_details&th=1 |
08-27-2023, 04:27 PM | #22 |
230
Rep 365
Doesn't the charging tray enhance cell reception through the roof fin? I think in years past that was the case.
