10-05-2023, 02:31 PM | #1 |
660
Rep 1,059
Review: Dinan F95 springs + bumpstops
Separate from the Dinan product thread, I wanted to post a brief review of the Dinan F95 lowering springs + bumpstop kit here.
Summary: - Uneventful install - No new noises, clunks, bangs, screeches etc - all as factory - Ride height lowered around 1.4" front and rear - Factory rake maintained - Ride is slightly sharper and more taut than factory; it's not uncomfortable or over-sprung at all - Increase tramlining due to increased negative camber at the front wheels (non-adjustable) Narrative: My post-install experience has been, in a word, unremarkable. And I say that in the best way possible. At the end of the day, these are just lowering springs with no moving parts, nothing to set, nothing to mess with and adjust - just simple, straightforward, and effective. Unremarkable is what you want, and that's what these are. They're simple and better than OEM - for me - in every way. Given that we're lowering the car on stock dampers, we're limiting remaining damper travel, so the mitigant to that is higher spring rates. Dinan has quoted the following - F95 X5M Front Stock - Linear Springs - 580 (lbs/in) rate Dinan - Dual Rate Springs - 696 (lbs/in) working rate (max hard rate) 20% increase (ish) in front spring rate for Dinan (max rate) over OEM F95 X5M Rear Stock - Progressive Springs - 724 (lbs/in) working rate (max hard rate) Dinan - Dual Rate Springs - 869 (lbs/in) working rate (max hard rate) 20% increase in spring rate for Dinan (max rate) over OEM (max rate) So 20% may seem like a big number, but it's barely perceptible in daily driving. Expansion joints and road cracks hit a bit sharper, but it's not jarring or crashy by any means. That said, I have a car that weighs half of the F95's pork with 900lb springs on each corner... I have very high tolerance for a sharp/stiff ride. Others more inclined to cushier, highly sprung rides may disagree with my perspective. So long story short, if you're okay with the feel of the OEM suspension, you will be 100% fine with the Dinan setup. If you're tolerant of the OEM suspension but wish it was a bit softer (and lower), you will still be fine with the Dinan setup as it doesn't feel 20% stiffer than stock in standard driving (due to the dual rate springs). I doubt many of us are tracking our boat F95/6's (and if you are, adjustable or non-adjustable springs are not the answer at all), so the main idea here is lowering. For that case use, these are a perfect set-and-forget and inexpensive solution. KISS. Last comment is that I like that these springs don't dump the front end and reverse the rake. You want higher in the front for a couple of reasons - better weight balance when diving into corners, and also, inner tire shoulder life. Toe kills tires, but a slammed front end will result in pretty aggressive negative camber up front which will eventually cause uneven wear on your inner tire shoulders (relative to the rest of the tire). Despite how well this thing moves around, it's still an SUV and people hauler, not a track car. Final thought: 10/10 would recommend. Pictures - - Same location to make before/after easy - 15mm spacers front/rear in all pictures - "Before" pics on OEM 809M's, "After" on OEM 818M's BEFORE AFTER BEFORE AFTER BEFORE AFTER And a bunch more 'Afters' - |
10-05-2023, 03:24 PM | #3 | |
Rep 891
10-05-2023, 06:15 PM | #4 | |
Rep 3,129
Our quoted labor time (11 hrs) is based off of dealership times (KSD) as that is the minimum time a dealership would bill regardless. Often going to an independent shop suspension oriented installs in particular will be quoted notably less. |
Sleeper659.50 |
10-05-2023, 06:23 PM | #5 | |
660
Rep 1,059
It's unlikely we'll be able to keep the camber to stock spec - I'm expecting 'out of spec' front camber (too cambered/negative), but toe and caster should be to spec. You'll end up with accelerated inner tire wear over time, but toe is what trashes tires in short order so as long as that's dialled in, I don't anticipate too many issues. DIY time is in the higher end of the spectrum. Experienced shop time is 6-8 hours including an hour for alignment. |
S68 X5MC270.00 |
10-05-2023, 06:27 PM | #6 |
660
Rep 1,059
Yes, indeed. Just trying to score positive review points to help convince you guys to make the E46 M3 air intake again haha.
10-05-2023, 09:35 PM | #8 |
660
Rep 1,059
Good question. If I’d had half a brain, I could have weighed both sets with same tires mounted. But sadly, just a quarter brain. And now with different tires mounted, it wouldn’t be an accurate comparison.
10-06-2023, 12:46 AM | #10 |
Forced Induction Connoisseur
962
Rep 740
Drives: 23 X5MC / 23 720s
Garage List 2024 G87 M2 [0.00]
2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2008 BMW M3 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
I have some 818's in boxes sitting unused... I have to move the boxes anyway so I'll try and remember to weigh them. Hell I might as well sell them...
Oy vey, look at all these shekels
10-06-2023, 09:59 AM | #11 | |
Rep 825
What did you replace them with?
Two is One and One is None
10-06-2023, 11:13 AM | #12 |
Self-Deprecating Narcissist
7266
Rep 6,561
Perhaps spraying the control arms matte black and adding spacers may help with the reverse rake appearance that is occurring otherwise it looks like Dinan did what they do best by providing an OEM+ style plug+play solution to a problem that should not have existed from the factory.
10-06-2023, 09:36 PM | #13 |
962
Rep 740
No they we're off my 21 actually. I kept them because the 23 came with some 809s I think that looked terrible, so I put those on the 21 when I swapped it for the 23.
P200SC's are what's on there Sleeper How do the harmonics feel over large transitions? Do you feel like you have a pogo stick effect where the car takes longer to settle due to the rebound not being matched to that springrate? That's how it felt to me on the MSS stuff which is why it only lasted 150 miles for me.
10-09-2023, 12:10 AM | #14 | ||
660
Rep 1,059
But totally agree. I’m sure there was a reason BMW jacked the car up so much from the factory, but that much wheel gap just looks weird especially with the skinny sidewall tires. Dinan did their thing with a super simple solution. No complaints as is but I do need more seat time to give a better review. Quote:
I know the bouncy, vague, floaty feeling you’re referring to and I have yet to replicate it on all sorts of driving scenarios and different roads. Will report back again once I have more seat time next week. |
10-09-2023, 12:51 AM | #15 | |
Rep 1,245
Drives: BMW
10-12-2023, 03:09 PM | #17 |
660
Rep 1,059
Just as follow up, I put a bunch of additional aggressive miles on these today. There is absolutely no bounce, pogo, float, or other unwanted feedback from this setup on the road. The OEM dampers are completely suited to these springs even in Comfort mode.
I was happy with them after first install, but now I’m a big fan after getting more seat time. The only downside is a bit more harshness and loudness over expansion joints in the rear of the car, but otherwise they behave like stock. |
iconoclast7265.50 |
10-12-2023, 04:33 PM | #18 | |
962
Rep 740
10-12-2023, 04:57 PM | #19 |
660
Rep 1,059
10-16-2023, 10:05 PM | #20 |
660
Rep 1,059
Alignment done. Toe was way out which wasn’t unexpected, and rear camber was a bit off pre-alignment but easily dialled in.
Front camber is also predictably not within spec, but the more modest drop of the Dinan springs has them not terribly off where inner tire shoulder wear will be that much worse than stock. Front right isn’t ideal, but I’m happy to be at -2* on that corner vs -2.5-3*. Anyway, reference only as this applies to my setup but again, I don’t see this setup as being all that harsh long-term on the tires. More so for sure than stock, but I’ll take the tire life penalty for the other positive trade offs. |
10-18-2023, 06:58 AM | #21 | |
DD214
270
Rep 283
10-19-2023, 03:33 AM | #22 |
248
Rep 326
I've been running the Dinan Springs for a while now and have no complaints. These guys that have dropped them way down using other kits and saying it rides better than stock are dreaming. Travel is travel period! Take away half your travel (or more) and it is going to bottom. There is no physical way around that.
I see possibilities for adding more drop without losing any travel though. I did something similar on my F85 and it worked great. https://f15.bimmerpost.com/forums/sh....php?t=1707385 You have to move the bottom of the shock down, in relation to the lower control arm. There is no other way. Well, I suppose you could move the top of the shock up, but that would require cutting the car up a bunch. I'm not going that way. I need to take the suspension apart again and have a good look to be sure. The front shock appears to be hollow where it seats in the control arm. If you cut 3/8" off the bottom, that should drop the vehicle about half an inch. It looks like you could cut 1/2"off and get around 3/4" drop. I'd have to measure from the fulcrum to the shock base and the hub face to get the actual ratio. The rear would use the same sort of theory, but it will require cutting and welding the control arm to lower the mounting bolt hole. I'll probably have to buy a new set to experiment with. Stuff like this interests me.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM Last edited by VETTEPRO; 10-19-2023 at 03:42 AM.. |
iconoclast7265.50 |
