01-22-2021, 09:31 AM | #23 | |
Rep 2,609
I suppose signal strength might be better with integrated module in marginal areas, but that has not been an issue on my urban and well-enough-covered-rural travel routes. The shark fin/telematics module area of X5 is prone to leaking through many reports, which is an additional risk of messing with that area. Just not worth it relative to alternatives.
01-22-2021, 11:10 AM | #24 |
13238
Rep 19,728
As mentioned, the $20 a month to ATT is for the HotSpot and not any features in iDrive. It is only to be able to provide an internet connection for the occupants of the vehicle.
01-22-2021, 01:59 PM | #25 |
Rep 108
Check out page 43 of https://g05.bimmerpost.com/forums/at...6&d=1544379664. Seems to be an integrated P-SIM.
01-22-2021, 02:21 PM | #26 |
Rep 6,799
I haven't looked (and I'm not sure you could see without removing), but this video shows at least one model BMW where the Connected Drive SIM card is...
There could be more than one...one for COnnected Drive, and another for the OTA updates and emergency use... |
01-22-2021, 03:22 PM | #27 |
2447
Rep 1,950
01-22-2021, 03:52 PM | #28 |
Rep 2,609
This thread revival reminded me, and for completeness, this is the device (ZTE MF275R) I ended up with and this is the power mod I did to make sure it powers on/off with the car. Just add 12V adapter/cable, search Amazon.
Original post: https://forums.redflagdeals.com/bell...893/#p31919630 If you want ZTE MF275R power on/off be managed without ever using the power switch and rather just the supplied external 12VDC power, you can remove the battery and then:
I chose the later (solder) and pictures are attached. It works great. Strictly speaking, if you want battery backup (I explicitly did not), you can leave the battery in and then you have a very nice battery-backed + external power-switched + power-switchless LTE router. Pics below. Basic procedure is:
01-22-2021, 04:23 PM | #29 | |
Rep 2,070
This is not a BMW part - this is an aftermarket COIKA Android 10 system that you get on Alibaba/eBay. Its for retrofitting into older models, the OS has been designed to look like iDrive, but there is nothing 'BMW' about this. |
