12-27-2020, 09:08 AM | #45 |
13174
Rep 19,661
There was no LCI for 2021, likely MY23.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 12-27-2020 at 10:45 AM.. Reason: Grammer |
12-27-2020, 10:37 AM | #47 |
13174
Rep 19,661
It is definitely necessary as it seems it is part of their trouble shooting procedure. Let them do whatever they want to do as they may hit upon the solution which will help others.
SmartSaves460.50 |
12-27-2020, 04:21 PM | #48 |
Rep 5,102
Check out this thread from the G20 forum. Looks like quite a few models affected although the G05 isn't listed. Can't be a coincidence...maybe more models affected than BMW realizes?
H/K Bass and Audio Failure '20 / '21? READ HERE: https://g20.bimmerpost.com/forums/sh....php?t=1786245 EDIT: RAM fix is mentioned in the PUMA report in the link
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
12-27-2020, 04:53 PM | #49 | |
Rep 192
BMWZ41908.00 |
12-27-2020, 09:47 PM | #50 |
Rep 266
So long story short
Bmw germany saying that is a failure in The RAM im the hk sysyem? Or bad batch? Am i correct And the fix is to change the ram and it works? Or does it mean they need to switch the whole amp? Werid the g05 isnt listed man... but it probably hasnt been reported alot i think cause its the same issue!!!! |
12-28-2020, 12:07 AM | #51 | |
Rep 25
12-28-2020, 09:11 AM | #53 |
Rep 266
Just showed this link to a tech he said it says its for cars with "fault readings" and mine doesnt have any faults.... fml.... now what
12-28-2020, 11:44 AM | #54 | |
Rep 5,102
"A diagnosis must be carried out in the event of a customer complaint." So, did they actually diagnose or just tell you it only applies to faults read w/o actually checking?
12-28-2020, 01:51 PM | #55 | |
ghey
483
Rep 2,041
It sucks the BMW TIS site is gone, because it perfectly laid out all of this in detail with schematics and booster types. But the end result is there isn't a 'whole amp' like we are accustomed to in previous BMW audio configurations. Now there's a base unit that does everything, and smaller addon units to handle additional components. There are definitely various boosters, and there may be different RAMs as well depending on the config, but it's something like this: RAM = AM/FM/Satellite + Power to the standard HiFi audio Booster variant 1 = Used to power additional speakers in HK setup Booster variant 2 = Used to power additional speakers in B&W setup
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
12-30-2020, 10:23 PM | #56 |
Rep 266
He had in shop one time when i first reported it and said there wasnt any fault codes.....
So is the ram goinf to fix the cut off or a whole new amp? I just want a soultion.... and i love truck i just want a soultion so it never cuts off again.... has anyone fixed the issue or found a soultion? Last edited by livinlife; 12-30-2020 at 10:32 PM.. |
12-31-2020, 09:32 AM | #57 |
Rep 598
this has happened to me a couple times. Resetting the iDrive system fixed it. In my case, the audio connection was being interpreted by the car like it was a phone call, so that only speaker that was working was the front speaker in the center of the dashboard. I had been using the talk to text feature, so I think that is where the confusion came from. One way to tell is when you try to turn up the volume, if the volume gauge comes up as "media" vs "phone"
Rparker8.00 |
12-31-2020, 09:40 AM | #58 | |
13174
Rep 19,661
SmartSaves460.50 |
01-04-2021, 04:09 PM | #60 | |
Rep 58
01-04-2021, 06:00 PM | #61 |
Rep 58
This happened to me about 4 times in the last 9 months of owning the car. I just turned it on the next morning and it was fine again. I'm hopping its just a software issue and not an electronics or hardware issue.
01-04-2021, 10:10 PM | #62 | |
Rep 4,551
BMW has a revision to the HK amp that has some sort of fix applied.
2023 840GC | 2021 740i | 2019 X3
01-05-2021, 02:39 PM | #63 |
Rep 1
Purchased my 21-440i on November 10 and it has been to the dealer now 4 times for the same issue. At first I couldn't get the car to replicate the issue, so they sent me home. After contacting Corporate, they took the vehicle back in and experienced for themselves what was going on. BMW told them it was the "Booster" in the vehicle, but there was no part number for this, since it was so new. They ultimately found and ordered the part, even installed it. Only for me to get the car back and the issue not be resolved. The dealership currently has the vehicle again and he emailed and said they started recoding the car, which takes several hours. They are then going to dial back into the car to see if there are any apparent error codes. Will keep you all posted. This is TERRIBLY frustrating on a brand new car. :-(
01-06-2021, 08:41 AM | #64 |
Rep 266
Well i feel you so the bmw revision hk amp is a new version of hk amp that bmw released? I will tell my foreman to look into it if so....
Also how u guys restart the idrive without shutting down the car? |
01-06-2021, 01:08 PM | #66 |
13174
Rep 19,661
