01-24-2021, 05:11 PM | #1 |
Rep 506
Drives: 2019 X5 xDrive40i
Is X5 really not capable of towing?
I keep hearing arguments saying cars like X5 are not true "SUV". I think their reason is because of the architecture not being as sturdy as real trucks (e.g Range Rover or Escalade). I personally believe they are capable since the spec in the manual tells me so (hopefully its not overstating).
Has anyone who had their X5 for a long time in the past had any problem towing stuff (trailers or even boats) had reliability issues? What would be your argument against those nay sayers? |
01-24-2021, 06:16 PM | #2 | |
13216
Rep 19,694
01-24-2021, 08:11 PM | #3 |
Rep 6,796
If the X5 couldn't tow anything, why is it available with a factory hitch?
The exact limits of what you can tow will vary based on which version you get. To some, the limit may be the max tongue weight of 551#, but some can handle over 7K pounds. Certainly not as much as some heavy duty pickups, but enough for many people. |
01-24-2021, 08:14 PM | #4 |
Rep 4,499
Drives: 2022 iX xDrive50, DGM
Some information on towing:
https://www.bmwblog.com/2020/07/18/c...tow-your-boat/ This is the first SUV/SAV I've purchased without a trailer hitch, but those I've owned in the past - X3, X5, GX460/470 and RX - have certainly been capable of towing, usually on the order of 3,000-7,000 pounds. The G05 is actually rated a little higher, so I have no doubt it's more than capable. If you tow regularly, routine maintenance and inspection is important both for trailer and car, including tires. |
01-24-2021, 08:35 PM | #5 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Most X5 owners here use them to tow boats, jet ski's small trailers etc. I rarely seen them towing big double axle caravans. These big caravans are usually towed by Landcruisers or Patrols and more recently Dodge RAMs that are imported from the USA converted from LHD to RHD and sold for much the same price as a Toyota Landcruiser 200 series
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
01-24-2021, 10:27 PM | #6 |
Rep 6,796
Given the seat of the pants recommendation of 10% of the trailer weight be on the tongue, and the 551# limit (at least in the USA), that puts a limit on the maximum towed weight...but, in many cases, the user's manual allows a bit more. With the factory interface for the trailer, when you plug in, that activates the factory stability control, so that should help out. So far, I haven't seen an aftermarket harness that provides that capability on the G05. Older versions, yes, there are some alternatives, but not on the G05 that I've seen.
Earlier X5's came with the internal plugs to install the factory harness, but they seem to have stopped that on the 2021 MY. |
01-25-2021, 02:46 AM | #7 |
23
Rep 30
The factory-fitted 'towing pack' includes things like uprated brakes as well as towing mode for the stability/ suspension systems, which is likely why the factory fitted towing option has a higher trailer weight allowance than after-market towing options, which won't include uprated brakes etc.
Bambazonke210.00 |
01-25-2021, 08:24 AM | #8 | |
Rep 773
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) |
01-25-2021, 10:10 AM | #9 | |
199
Rep 353
I have never seen any mention of upgraded brakes with the trailer hitch option in the US. Maybe that is country specific |
01-25-2021, 12:27 PM | #10 |
44
Rep 42
No problem,
8,6m/28,2ft long, 2,5m/8,2ft wide, 2500kg/5500lbs in the hills of Germany. Certified speed 100km/h / 62mph so 110km/h / 68mph on the speedometer. Up and down the hill, stable configuration. Factory fitted towing hitch.
BMW X5 45e X-line
10
MystroX56286.50 njapilot128.50 Paladin15549.50 Stoshu494.00 Bambazonke210.00 r33_RGSport12958.50 heeblet26.00 TSMC55126.50 Djrjn0.00 M40i4me1037.00 |
01-25-2021, 05:49 PM | #11 | |
1176
Rep 1,502
01-25-2021, 06:21 PM | #12 |
Rep 810
Absolutely no problems.
I have seen some huge motor-homes and caravans being towed by E53, E70 and F15s versions, and considering the G05 is larger and heavier - I really doubt there would be any issues. Here's mine, which is fitted with a BMW OEM after-factory tow hitch (which is removable/stealth when I dont need it), connected to my boat - 5-metres/16.5-feet long and 2-metres/6.5-feet long, weight all up with our travelling stuff we load her up with is around 1700Kgs/3750lbs. My car is a 30d Diesel, and it tows like a dream - these cars were made to tow. Sits on the highway at 100km/h at 1300rpm (barely humming), only needing to drop a gear to 1800 to get up steep inclines/hills. Seriously I forget the boat is actually behind me. Last edited by James_G0540i; 01-25-2021 at 06:29 PM.. |
01-25-2021, 06:44 PM | #13 | |
Rep 810
The X5's come off the production line with trailer pre-wiring, and you're all good as long as: 1. You get physical installation and the ECU coding done properly by a BMW dealer to enable towing-mode and proper integration with safety systems. This coding also enables specific transmission cooling when in towing mode. 2 . You have the M-Sport brakes - as a major factor in towing capacity are brakes. Standard brakes on the X5 are marginal for towing, but again depends on what you're towing. If you're towing a jet-ski or small 3x4 trailer, standard brakes would probably be OK. If I was going to tow anything over 3000kgs, I'd probably lean towards a more heavy-duty towing vehicle like a Prado/Landcruiser, RAM or Fx50. |
01-25-2021, 07:33 PM | #14 |
Rep 6,796
From what I've heard, for MY 2021, BMW no longer includes the towing prep in vehicles so it's not easy to incorporate it later. It's only there (obviously) on those that get the towing package at the factory. Earlier ones did come with the towing prep there that made it easier to install after.
There are aftermarket electrical interfaces that can make the lights work, but none (yet) can enable the stability control, monitor the bulbs' condition, or turn off the rear PDC sensors automatically when you plug in a trailer. |
James_G0540i446.00 |
01-25-2021, 08:35 PM | #15 | |
Rep 810
I just looked at my car's invoice, and the towing prep is OPTION 8SL - "Preparation for tow bar". Also, I notice I dont actually have to select "Towing mode" when preparing to tow. When I plug the trailer to the car, it senses the trailer plug and automatically goes into towing mode. |
01-26-2021, 02:59 AM | #16 | |
23
Rep 30
The towing option on my xLine included uprating the brakes to the M-Sport ones, although the dealer didn't seem aware of this and certainly never told me. I found out about this from another post on this forum, and when I had a good look at the shape of the brake callipers on my car they are the M-Sport ones. There is a third even more powerful brake type; I am not sure if M-Sport models get that with the towing package. |
01-26-2021, 05:06 PM | #17 | |
Rep 32
My understanding (another told by the dealer story) is that if you order the tow bar from the factory it is mounted to the chassis in a different way (I guess because of better access?) compared to after market OEM, hence the 2700/3500kg difference. |
01-26-2021, 07:03 PM | #18 |
Rep 6,796
Outside of NA, the OEM trailer hitch is a powered, retractable, gooseneck as far as I know. If you retrofit, it's a removeable gooseneck arm that is totally manual.
NOne of that may be useful for MY 2021, if they did the same thing for all models, everywhere...the new one is no longer prepped from the factory for towing, so adding the electrical interface would be quite costly. |
01-26-2021, 07:47 PM | #19 |
241
Rep 319
Drives: 2024 X5 M60i, 2020 RRS SE, 201
No issues pulling the 24 ft Yamaha Jet Boat at about 5000lbs
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black |
LexxM31698.50 |
01-26-2021, 09:05 PM | #20 | |
Rep 451
Please read the articles in the links below for more information https://www.carsales.com.au/editoria...w-test-126506/ https://www.carsales.com.au/editoria...towing-120076/
01-27-2021, 10:05 AM | #21 |
There's a storm coming
252
Rep 596
Drives: BMW Vader
Garage List 2020 BMW M135i xDrive [0.00]
2019 BMW G05 M Spor ... [0.00] 2018 540i M Sport X ... [0.00] 2018 BMW 540i M Spo ... [0.00] |
I’m still laughing about the words ‘sturdy’ and ‘range rover’ being used in the same sentence. Knowing people that work in the factory here in the UK, they all categorically state they would never own a RR. Read into that what you will.
Carry on. |
