10-18-2020, 05:45 PM | #133 | |
13275
Rep 19,803
Edit: I should note I'm referring to normal driving and not to some situations like pulling into a garage as some have described. When I first got mine and was getting used to parking it in my garage I had it shut off a few times. Now that I'm used to it I can park without it shutting off by naturally, actually learnt I guess, feathering the brakes. Last edited by TurtleBoy; 10-18-2020 at 05:55 PM.. |
10-18-2020, 06:46 PM | #134 | |
16
Rep 43
10-18-2020, 07:02 PM | #135 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
His profile mentions 2021. I think it was a typo.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
10-19-2020, 08:36 AM | #136 |
Rep 17
Drives: 2021 BMW X5 xDrive40i
Yeah it was a typo. Sorry for the confusion. Long week.
10-19-2020, 10:01 AM | #137 |
Rep 28
Do you think it is less noticeable when the engine starts/stops with the mild hybrid?
2021 X5 40i M Sport - Carbon Black/Black
2024 X5 50e M Sport - BG/Cognac |
10-19-2020, 10:18 AM | #138 |
Rep 549
Very smooth in my 2021. Car actually shuts off around 8mph and coasts on battery power. Sometimes doesn't even try to start after you lift off the brake until after you hit the accelerator.
SmartSaves462.00 |
10-19-2020, 04:02 PM | #140 |
Rep 6,805
It's my understanding that BMW modified the engine mounts, and that dampens most vibrations from starting the engine. On my 45e, other than noise, you do not feel any indication that the engine has started, but that is also getting the vehicle started to move via the electric motor, so not sure when you only have an ICE. The mild hybrids should be similar to the 45e in getting started off the line, though. I haven't driven one.
10-19-2020, 10:07 PM | #141 |
Rep 10
I cannot compare the 2021 mild hybrid performance to the older models. I can compare it to the Sport Mode. It is not noticeable to me. The start when in the comfort mode is instantaneous and smooth. Very quick. I was very pleasantly surprised after reading some earlier comments.
10-21-2020, 01:13 PM | #143 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Do you notice it a lot when it stops and re-starts?
10-21-2020, 02:11 PM | #144 |
Rep 4,504
Drives: 2022 iX xDrive50, DGM
I have a MY20 40i with the ASS button, but it's actually the least intrusive of any car I've driven, including a recent Q7, so I never turn it off except in the automatic turn-off in Sport. I don't think I'd miss it if there wasn't a button.
10-21-2020, 02:48 PM | #145 |
24
Rep 38
Have a X545e. I have driven several 2020mX5 40i loaners in the last couple of weeks. Auto,start,stop not bad but noticeable. Was at the dealership today a drove a 2021 X5 40i, and it was significantly smoother, not quick as smooth as the 45e but pretty close.
10-21-2020, 03:07 PM | #146 |
16
Rep 43
I picked up mine today. The auto start/stop does not seem to be as jerky or noticeable as other vehicles I have driven, I don't have another X5 to compare it to, but it is noticeable - but not irritatingly so. However, it does lower the fan speed on the A/C so while you don't really feel or hear the engine turning on or off - I hear it because the A/C fan changes speeds.
robby818265.00 |
11-27-2020, 08:49 AM | #147 |
258
Rep 319
The wife just picked up a loner from the dealer since our X6M is in the shop. On the 6 if you put it in manual shift position it automatically turns off the Auto stop function without having to go into sport mode. You don't have to manually shift your unless you touch the paddles. Going to try tgis when i head out after while.
11-27-2020, 06:12 PM | #148 |
556
Rep 1,746
Not really, it's much better system than before, and I haven't had any opportunity when I felt the need to turn it off.
11-28-2020, 01:16 PM | #149 |
37
Rep 45
Drives: 2021 X5
As I have said before I find the ASS much better on the mild hybrid than my previous MB E450 but there are still times when I don’t want it to operate (stop/start traffic)
I have the Sport Individual programmed to all Comfort settings and tap the Sport button when I want to eliminate the ASS it’s a one button press exactly the same as turning off the ASS. |
11-29-2020, 10:33 AM | #150 |
110
Rep 318
I find start/stop doesn't activate half the time. Are there a list of requirements that need to be met for it to become active? ie, engine up to temp, certain battery voltage, etc??
I notice mine used to work all the time but more recently it doesn't.......wondering if its an indication of my battery needing a top up? |
11-29-2020, 02:04 PM | #151 | |
1165
Rep 1,778
but sometimes you can 'force' it to go into ASS by depressing the brake pedal all the way to the floor while the car has been stopped. It'll either stop the engine or continue showing the prompt that ASS isn't available in the dash. |
IftiBashir110.00 |
12-31-2020, 10:19 PM | #152 | |
Rep 1,203
Drives: 2023 BMW i4 M50
Hopefully Sport Individual Driving Mode (all characteristics set to Comfort) equals Comfort Driving Mode. BMW will definitely hear from me when it comes to forcing the use of this feature. |
12-31-2020, 11:22 PM | #153 | |
13275
Rep 19,803
12-31-2020, 11:34 PM | #154 | ||
Rep 1,203
