11-27-2023, 07:49 AM | #23 | |
Rep 1,251
Physics / engineering typically allows you to think in black and white hence why it’s so confusing / concerning for some. |
11-27-2023, 08:38 AM | #24 |
Rep 8,700
Drives: eVeRyOnE mAD!
similar background for a bit (physics/biomedical engineering) but switched to nursing route (anesthesia) a couple years later. i still like to analyze and scrutinize the operational details of everything lol
11-27-2023, 09:49 AM | #26 | |
13276
Rep 19,807
11-27-2023, 09:50 PM | #27 |
Rep 6,806
The road is rarely perfectly flat and you won't be able to drive at a perfectly stable speed while the load remains identical...so, there will be opportunities for regeneration to occur in any mode of operation. IOW, while the ICE can cause the EV motor to turn into an alternator, it will occur without needing the ICE to provide that power, at least on occasion, allowing the batteries to recoup some energy. Some modes are more aggressive at it as are some much less likely to enable regeneration (Eco Pro mode primarily coasts when it can and doesn't engage regeneration except in certain situations like hitting the brakes or detecting a vehicle in front of it). While sport tries to maintain a larger buffer expecting you to be calling on full combined ICE plus EV power which obviously requires some battery capacity to be available.
While the guts of the 40i and 50e may be identical, at least with the 45e, they said that some of the hardware does differ. There's a sticky at the top of the forum that has some training details that make some interesting reading. SOme of it is related to starting the engine. THe PHEV has two modes, traditional starter motor and tow-start mode...each puts different loads on things, and the PHEV beefs up the related components. I haven't checked the LCI 40i and 50e's gear ratios, but the power peak and gear ratios did differ pre-LCI, and probably still do on the LCI. With the higher power available on the LCI, it can turn a little slower which helps with efficiency. |
11-27-2023, 09:58 PM | #28 | |
Rep 3,681
2022 G05 B58/PHEV
+ a few very old BMWs |
cobramite1227.50 |
11-28-2023, 12:19 AM | #29 |
2JZ-GTE
3045
Rep 3,997
Because it's true? The 50E internals have some differences. Gear ratios are different between 40i and 50e
50E Automatic Gear Ratios – I / II / III 5.5 / 3.52 / 2.2 Automatic Gear Ratios – IV / V / VI 1.72 / 1.3 / 1.0 Automatic Gear Ratios – VII / VIII / R 0.83 / 0.64 / 4.45 Automatic Gear Ratios - Final Drive Ratio 3.64 LCI 40i Automatic Gear Ratios - I / II / III 5.25 / 3.36 / 2.17 Automatic Gear Ratios - IV / V / VI 1.72 / 1.32 / 1.0 Automatic Gear Ratios - VII / VIII / R 0.82 / 0.64 / 3.71 Automatic Gear Ratios - Final Drive Ratio 3.39 |
11-28-2023, 01:18 AM | #30 | |
Rep 3,681
Second, gear ratio I posted many time. They are different, but it is NOT the point. He said 45e will rev low and more efficient. Please read the entire part I highlighted, comprehend it, then give a full context response. The fact is 45e has shorter gears at cruising speed by as much as 15%, it will rev higher and less efficient on highway. Your 50E gears numbers show the same thing, not as severely deficit as 45e, but still shorter than 40i. Tell me which car rev higher at cruising?
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 11-28-2023 at 01:30 AM.. |
11-28-2023, 04:40 PM | #31 |
Rep 6,806
From the training documents listed at the top of the forum...
G05 PHEV Complete Vehicle. 2. Powertrain. The most extensive changes compared to the conventional B58TU engine are: • Simplified belt drive • Vibration damper with rigid belt pulley • Mechanical vacuum pump (despite DSCi brake system) • Improved air intake system with resonator • Starter motor adapted to the more frequent starting operations • Wiring harness adapted to the engine peripherals. Note it says the most extensive changes, implying there are other changes as well. |
eluded3044.50 |
11-28-2023, 04:48 PM | #32 | |
Rep 3,681
So again, what is "beefed up"?
2022 G05 B58/PHEV
11-28-2023, 04:59 PM | #33 |
Rep 6,806
I look at the engine as all of the components inside the block and the stuff attached to it that make it able to function. With that in mind, it is beefed up. The starter motor and the dampener are designed to handle more frequent starts, and from being 'tow-started'. Essential for the operation of the vehicle as a PHEV. What that document does not show is what they also tweaked inside. Changes made to make the PHEV's engine more reliable. I doubt they made things weaker in the process.
porterM37.00 |
11-28-2023, 05:39 PM | #34 | |
Rep 3,681
Using your logic, turn it around, 40i has many components different than 45e in order for 40i to function as well, so 40i engine must also be more "beefed up", right? The only thing that says remotely improvement is "starter motor" to accommodate more frequency start. What else? And it is not part of the engine. Do you even know that dampener is? There is a technical name for it. It is not to counter start or the engine. It is to counter something else. You should go look that up. And BMW itself didn't claim it is beefed up. It just says it is rigid. If you can learn why this dampener is needed in any car, you should know why this change is needed. And let me also ask, they tweak in side according to who? you? And tell me what components they can possibly tweak inside to make it more beefed up yet BMW didn't create a new engine code for it. It is not like we don't have enough version of B58. But I am still not sure we are talking logic and technical here. You need to rationalize 45e is the best car existed, you just need to believe that. Please don't make up fake info. That is including 45e gear ratio. It is straight documentation by BMW and ZF. 45e has shorter cruising gears. Why lie and keep lying about it? Do you thin no one bother to spend 2 minutes to look it up?
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 11-28-2023 at 05:47 PM.. |
11-28-2023, 07:45 PM | #35 |
Rep 6,806
The shock load of tow-starting an engine up to what might be several thousand RPMs will be much higher than starting on to idle with the starter motor. At least to me, that implies the dampener would have to be able to absorb a larger shock...thus, heavier duty.
We may not ever know the full differences between the two implementations of the engines in the differing models, as BMW has no responsibility to expose all of their development decisions to the public. |
11-28-2023, 08:28 PM | #36 | |
Rep 3,681
2022 G05 B58/PHEV
cobramite1227.50 |
11-28-2023, 10:53 PM | #37 |
Rep 993
11-28-2023, 11:06 PM | #38 |
2JZ-GTE
3045
Rep 3,997
Agreed until we see the spec or technical documentation on the new TU2 motor we can only drive off of rumors that others have said, some on YouTube with tons of followers.
Once parts are available we can also look at them for differences. |
11-28-2023, 11:12 PM | #39 | |
Rep 993
Even the individuals torque values from ice/electric do not add up to the total quoted. Maybe the electric motor with xx torque by itself, throttles power when running both motors combined? |
eluded3044.50 |
11-28-2023, 11:24 PM | #40 |
Rep 6,806
EV and ICE motors develop torque at different RPMs...an EV motor typically develops maximum torque from stopped, and ICE at much higher levels. You'd need to put the thing on a dynamometer to measure total output and track the torque, but that still wouldn't tell you the individual motors' power. That would be harder to figure out without some other tools.
11-28-2023, 11:31 PM | #41 |
Rep 3,681
yeah, I got carried way. I just didn't like obvious fake information being pass around over and over again by the same guy. But it is free public forum, anyone can have their ways. I think most people knows. But yea, I am done.
2022 G05 B58/PHEV
crackerjack15841.50 |
11-29-2023, 12:16 AM | #42 | |
Rep 993
Sort of a conformation bias. |
11-29-2023, 01:39 PM | #43 |
1228
Rep 1,350
A "beefed up" B58 is an S58 and that is one bad ass engine for sure.
