08-29-2020, 04:01 AM | #23 | |||
Rep 1,304
A reset resolves the problem and for over a week I still don't have an issue with it. Last time 2 days in a row. I won't let BMW randomly replace parts because they don't have a clue and they hope that will fix it. |
08-29-2020, 02:45 PM | #24 |
Rep 159
I think I agree.
I can make the roof work again by fully closing the sunshade (keep button depressed, auto mode won't work at that point.) --> then the problem is usually back after one, max. 2 days. If I use the full reset (keep button pressed as if to tilt the roof, and press until it has gone through all its positions --> in that case I get 4-5 days of "working roof" |
08-30-2020, 02:53 AM | #25 |
There's a storm coming
253
Rep 596
Drives: BMW Vader
Garage List 2020 BMW M135i xDrive [0.00]
2019 BMW G05 M Spor ... [0.00] 2018 540i M Sport X ... [0.00] 2018 BMW 540i M Spo ... [0.00] |
My Sky lounge works flawlessly and as designed, also had one in the G30, which again was perfect. I actually wrote a post on how well designed the G30 one was especially at speed with it open.
Honestly, i do really like the G05, the tech is fantastic, but in terms of build quality the German Built G30 just seemed better bolted together. Cant put my finger on it, as i actually like the G05 more than my old G30's. I guess what I'm trying to say is the G30 felt more like a BMW if that makes sense? |
08-30-2020, 10:53 AM | #26 |
Rep 183
I kinda lost track of this thread, sorry.
By now they have replaced the entire sunroof system about 2 months ago. A couple of weeks later I got the same message. Back to the dealership, again... That time they have replaced some rubbers and again updated and reinitialised the system. So far it has been working correctly now, but I am not sure it will be a permanent fix, so I keep my fingers crossed! |
08-30-2020, 12:14 PM | #27 | |
Rep 1,304
When I joined this forum over a year ago I read about this issue. Now my new car had it also several times. That's a very long time if it would be a batch of faulty parts. BMW replacing a complete sunroof and you still have this issue. Now replacing rubbers. The only thing what this does is proving that BMW is completely clueless about what's causing this. What rubbers did they replace? What update did they did do, bring you to 07/2020.35? |
08-30-2020, 01:09 PM | #28 |
Rep 250
My skylounge has been perfect, not a single issue (late 2019 build).
I do drive a Mercedes S class from time to time and I must say that compared to that car my BMW sunroof seems rather thin and flimsy and the operation is a fair bit louder. The S class is a very thick glass and falls into the frame without a sound when closing while mine does this with a firm smack. But at least it is working. |
08-31-2020, 03:04 AM | #29 | |
Rep 183
I agree that the hardware does not seem to be the problem as it happened again a couple of days after the new roof was installed. After that they changed some rubbers but I have no idea which ones. I hope maybe the latest software update solved the issue? |
08-31-2020, 03:58 AM | #30 | |
Rep 1,304
08-31-2020, 04:40 PM | #32 |
Rep 159
I noticed something new today when I was sitting in the car at night. I have the skylounge, when the roof is not working the LEDs in the part that opens are also not working.
After a reset, those LEDs come on. When the roof operates as it should, those LEDs also go out if you tilt or open the roof. So, I deduce/speculate the problem is probably that the roof controller thinks the roof is not closed whilst it actually is. |
X5 45e1090.50 |
08-31-2020, 04:49 PM | #33 | |
Rep 5,330
09-26-2020, 02:36 AM | #35 | |
Rep 2,420
09-26-2020, 02:44 AM | #36 |
Rep 444
I have that smug git feeling reading this post .... mine doesn’t have a sunroof and if it had I would have stayed clear. In previous cars they never got used other than to open and close them in the hope that bloody irritating rattle would stop
volodp199.50 |
09-26-2020, 03:00 AM | #37 |
Rep 804
At least someone (or a team) on this forum should have a contact at BMW so that we could feed them some filtered, pre-processed problem reports and be heard. I think that would benefit both us and BMW.
10-01-2020, 05:20 AM | #38 |
Rep 183
Hi guys, after a summer without problems, today i got the same message again, my display key says the roof is open although it actually isn't.
I should check if the skylounge works in that part, it would make sense it doesn't like Sirksael said ealier, if the roof thinks it is open. I e-mailed the dealer yesterday but so far no response. I am actually quite fed up with it by now as they have no clue what the actual problem is... And from what I heard from a few friends and read on this forum, the X5 has some serious gremlins which kinda scares me for the post warranty period... |
10-01-2020, 04:34 PM | #39 |
Rep 54
Same issue here with SkyLounge roof on a month old X5 45e. Dealer was trying to fix it 3 times (updating, fixing some connectors), but the issue gets back after a couple of days.
now ordered as they call the complete head unit , will see, but after reading this post, I doubt that it will help... Strange indeed, that BMW can't fix relatively simple glitches (which our car has a few) |
10-08-2020, 03:55 AM | #40 |
Rep 183
Last tuesday my car was in the shop for the 4th or 5th time for this issue.
After changing the entire roof mechanism, some rubbers, some electronics, ... they now have received word from BMW that it is a communication issue between the electronic motor and the on board computer that leads to the issue. It should be resolved with the november/december release of a new software update. Let's hope this is the case. |
biterror521.50 |
10-08-2020, 04:18 AM | #41 | |
Rep 1,304
Also the 16A to 6A switch every day or so would be fixed with a software update. |
10-08-2020, 04:38 AM | #42 | |
Rep 183
Lets hope the update is as effective |
10-08-2020, 06:05 AM | #43 | ||
Rep 2,420
I have an appoint November 24th to upgrade to 11/2020 and to put on winter tires (didn't want to put them in beginning of November and wanted to make sure 11/2020 was available) They accepted the 6-16 and hybrid switch as a reason to upgrade the software. |
10-08-2020, 06:22 AM | #44 | |
Rep 1,304
The should just upgrade the car automatically or when the customer asks for it. |
