06-30-2020, 09:44 AM | #1 |
Rep 195
Compact Spare Tire Kit for X5 M50i
I made the mistake of not checking the box for the $150 compact spare tire kit for my new X5 M50i. A recommendation as to where I can purchase one online that is certain to fit would appreciated.
06-30-2020, 11:24 AM | #2 |
Rep 166
Lug Wrench Crank 71-12-6-788-617 1 $23.30
Lifting Jack 71-10-6-889-264 1 $127.12 Top Nut 71-10-9-909-543 1 $7.64 Rod 71-15-6-756-073 1 $10.46 Spare Retainer 71-15-1-180-625 1 $9.82 Chock 71-12-1-507-292 1 $19.06 Cover 71-15-6-756-072 1 $7.51 Ring 71-15-6-754-340 1 $3.82 Tray 51-47-7-943-979 1 $118.32 Shelf 71-10-6-877-210 1 $38.28 Crank Handle 71-12-6-886-420 1 $15.00 Spare Wheel 36-11-2-470-249 1 $278.96 www.getbmwparts.com *this is what I ordered, it has not come yet but after scouring all of the parts diagrams this was it IMHO. Last edited by matthewk; 06-30-2020 at 11:49 AM.. |
GlennC321.00 |
06-30-2020, 01:20 PM | #3 |
Rep 195
[QUOTE=matthewk;26378594]Lug Wrench Crank 71-12-6-788-617 1 $23.30
Lifting Jack 71-10-6-889-264 1 $127.12 Top Nut 71-10-9-909-543 1 $7.64 Rod 71-15-6-756-073 1 $10.46 Spare Retainer 71-15-1-180-625 1 $9.82 Chock 71-12-1-507-292 1 $19.06 Cover 71-15-6-756-072 1 $7.51 Ring 71-15-6-754-340 1 $3.82 Tray 51-47-7-943-979 1 $118.32 Shelf 71-10-6-877-210 1 $38.28 Crank Handle 71-12-6-886-420 1 $15.00 Spare Wheel 36-11-2-470-249 1 $278.96 www.getbmwparts.com Thanks. Expensive mistake on my part. By not ordering the compact spare, I actually thought I was receiving a full size spare and opting out of the compact spare, LOL. |
06-30-2020, 01:36 PM | #4 |
Rep 4,338
[QUOTE=GlennC;26379167]A full size spare will not fit under the cargo floor, the compact barely does.
06-30-2020, 02:25 PM | #5 |
Rep 195
Does anyone know if this is a viable option (just found it)?
https://modernspare.com/product/2019...e-kit-options/ |
07-02-2020, 08:19 PM | #7 |
Driver
163
Rep 447
I haven’t tried this kit but did see it. If you have the M Sport brakes I wouldn’t get it though. The wheel is 18”, which won’t fit around the brakes. The solution they sell is a massive spacer that pushes the spare wheel far enough out that it won’t touch the brakes. This will require really long bolts, and will mean that the contact patch of the wheel is really far away from the wheel hub. As a casual student of physics this worries me, because it increases the chances of failure - and I fear that it could allow the joint where the hub connects to the drive axel to bend beyond spec. I may be paranoid, but I don’t get a good feeling from it.
If you do get this kit for a car with the m sport brakes, I would recommend using it only as last resort, and only at very low speed to get you directly to the nearest garage or tire shop. Just my 2 cents. |
GlennC321.00 |
07-02-2020, 08:38 PM | #8 | |
13276
Rep 19,808
That standard compact spare fits over the MSport brakes with no problem. The spare mentioned in the "kit" appears to be the same so there would be no problem with MSport brakes. Edit: For clarity, I'm referring to the spare in the kit that matthewk put together not the third party one mentioned. Edit 2: The wheel in his package is not correct, it should be 36-11-6-880-744 Last edited by TurtleBoy; 07-04-2020 at 01:38 PM.. |
GlennC321.00 |
07-02-2020, 09:08 PM | #10 |
13276
Rep 19,808
07-02-2020, 09:36 PM | #11 |
Rep 4,246
The OEM spare is 19" and clears the M Sport brakes.
The spare which is stored under the cargo area under the cargo floor panel and doesn't impact G05 rear cargo space.
07-02-2020, 09:54 PM | #12 |
13276
Rep 19,808
Did you have a flat or were you just practicing? Or I guess they could be pictures of someone else's vehicle.
07-02-2020, 10:07 PM | #13 | |
Rep 4,246
Pirelli covered the replacement tire under warranty since it was 10K miles.
07-03-2020, 03:44 AM | #14 | |
Rep 195
07-03-2020, 12:57 PM | #15 | |
Rep 4,338
Here are the various heights from the cargo floor to the underside of the cargo cover when closed.. .. X3 without spare option: 18.5" X3 with spare option:15.5" X5 with or without spare option:15.25" Where you gain space in the X5 is its width and length. |
07-03-2020, 01:47 PM | #16 | |
23
Rep 44
Interesting. Thanks for information. Actually more interested in cargo floor to ceiling since need to fit a dog crate. |
07-04-2020, 12:36 PM | #17 | |
Rep 195
07-04-2020, 01:09 PM | #18 |
Driver
163
Rep 447
Try this wheel: https://www.getbmwparts.com/oem-part...-2-36116880744
You’ll need the 19” diameter. Any BMW salespersons our there who want to order a bunch of stock vehicles with the spare wheel option and then sell them at a dealership profit? |
07-04-2020, 03:18 PM | #19 |
The Dark Knight
422
Rep 1,262
I wish I had known this when ordering the car. My dumb sales person told me with a really sad and disappointed face that "yeah if you order that spare kit then it will cause a bump in your trunk" and I took him for his word and didn't order it and regret it ever since!
07-04-2020, 03:43 PM | #20 | |
13276
Rep 19,808
07-04-2020, 09:39 PM | #21 |
Rep 167
So after reading through this thread, can I safely assume that the OEM $150 "space-saver spare" option when ordering WILL fit over the M sport brakes, and will not cause any issues with the cargo space?
07-04-2020, 09:42 PM | #22 |
Driver
163
Rep 447
You are correct. It will fit over the M Sport Brakes and will not cause a bump in the trunk.
