      04-23-2008, 08:54 PM   #1
Das M
Das M's Avatar
Drives: YMB F80 ///M3
PC Problems, anyone help?
Is there any particular reason why my PC would just shut down and restart? I thought it might be running too hot, could this be the case? It has only happened when I was watching videos on the web and having multiple programs running at the same time (itunes, IE, windows media player). Any ideas?
2016 F80 ///M3 [YMB / Black Full Merino / Carbon Fiber Trim / DCT / Everything] I picked DCT because I want to be more involved in my un-involvement.
      04-28-2008, 05:26 PM   #2
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
If only when multiple apps running, maybe a bad RAM stick. You might not get to teh bad part until using lots of apps. Heat shutdown could also be a problem. Check the event log, under system, to see if it tells you why it shut down.
      05-19-2008, 04:22 PM   #3
darkphantom
595
Drives: E93 335i
any updates on this?
      05-19-2008, 04:45 PM   #4
adrock
adrock's Avatar
Drives: 2014 435i
2011 E92 335i  [9.58]
2007 E92 335i  [0.00]
Usually it is because your CPU overheated. If you get a memroy error you will usually get a BSoD. You can use MemTest86 to check just to be sure, but it sounds like a heat issue. What type of Mobo is it? Most will come with software that will record and log your CPU north and south bridge temps.
Once you have ruled that out, move on to unplugging pieces of hard ware one at at time and see if it changes the stability of it. Def. sounds like a hardware issue though. Could be totally wrong...
      05-19-2008, 05:04 PM   #5
g9sBMW
g9sBMW's Avatar
23
Drives: 2007 BMW 328i
2007 328i Sedan  [0.00]
VISTA ??
[2007 328i|Black Sapphire|Terra Leather|6 MT|Xenon headlights|BMW Alarm|Clear Bra|Stainless Steel Pedal Pads|Black Line Tails|MTEC V3.0 Angel Eyes|HUPER OPTIK 30 Ceramic TINT|GPThunder Fogs|LED License Plate mod|Sport Shocks/Springs upgrade|ZHP Shift Knob|//M Dead Pedal|Matte Black Grill|Aluminum Strut Bar|Cyba Air Scoops|Rear Fog Switch|Perforated Mtech Wheel|Miro 935s|Hankook v12 evo Tires|BMW SSK]| BMW PE
      05-20-2008, 12:11 AM   #6
its ray den
Drives: 2004 Mazda6s
power supply issues?
