11-10-2021, 06:58 PM | #67 | |
Rep 602
11-10-2021, 07:02 PM | #68 |
Rep 116
I don't disagree..I won't spend that for the knob. Aftermarket should be fine until things level out..By then I probably won't care.
03-17-2022, 08:52 PM | #69 |
18659
Rep 14,107
Drives: G82 M4C X-Drive
Has anyone successfully done this? I'm using a trim removal tool, but it feels like I'm breaking it.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
03-18-2022, 12:03 AM | #70 |
Rep 224
I drilled a small hole into the center. Put a wood screw into it. Then use pliers to grab on the screw to pull the button out. Just made sure I didn’t go too deep.
04-04-2022, 01:12 PM | #71 |
Rep 961
Drives: G87 M2, G20 330d, Brabus Smart
This is what I did. I tried other methods, marred the silver ring a bit, then bit the bullet and drilled. Should have done that in the first place.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
06-22-2022, 11:07 AM | #72 |
Rep 13
I went to Car Analysis site but?
Hi I went to Car Analysis site for the Vol button, but it sent me to Amazon and Brand: Mankalei Lab, I assume it's the same button?
Also after replacement it still lights up correct? Thx |
06-22-2022, 12:16 PM | #73 |
Rep 842
Yes and yes.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
10-29-2022, 12:40 PM | #74 |
Rep 153
Sorry if I missed it but can you buy the metal/plastic volume surround? I scraped mine when removing it (the actual volume button is fine).
10-29-2022, 01:04 PM | #75 |
Rep 8,661
Drives: eVeRyOnE mAD!
you talking about the silver ring? not sold separately AFAIK. I had to purchase a whole new radio face from overseas after damaging the ring when trying to remove it. (it wouldn't come off!) the new one came off easily, though. cost me $80 versus a few hundred in the U.S.
11-11-2022, 04:05 AM | #76 | |
Rep 153
11-11-2022, 05:24 AM | #77 |
Rep 8,661
Sorry, I paid $145. yes that's the part. The cheapest I could find on eBay was $200 but didn't confirm if it already had the crystal button
04-05-2023, 06:24 PM | #78 |
Rep 198
Wondering if anyone has the same situation I do. I drilled a hole and popped the radio button off. Unfortunately the notch that holds the upper right on, snapped off. Thinking about a small amount of super glue on that side instead of an entirely new unit. Anyone else have something similar?
