      07-22-2020, 11:18 AM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
IND | F95 X5M Wheel Spacer Fitment Guide
Tools Required:
  • Floor Jack and 17mm Socket
  • Future Classic Spacer Kit
  • Future Classic Wheel Hanger Pin Set (optional)
STEP 1: Jack up your X5M and place a jackstand underneath the car for safety purposes. Loosen the lug bolts and remove your front wheel for access to the hub area.
STEP 2: Remove the OEM hub bolt(s). The front wheels will require a 5mm Allen, whereas the rear uses a 6mm. Note that the Future Classic replacement hub bolts will both use a 5mm Allen.
STEP 3: Using the included brush and Copaslip anti-seize, apply a thin layer of the anti-seize to the OEM hub area before fitting the spacers.
STEP 4: Line up the Future Classic spacer with the vacant hub and lug bolt holes and press it into place until it is flush against the hub area. Apply anti-seize to the FC extended hub bolts and secure the spacer to the hub.
STEP 5: Re-install the OEM wheel using the Future Classic wheel hanger pin set. Thread the pins into two adjacent lug bolt holes and slide the wheel over them until seated. Fit the FC extended lug bolts into the vacant lug bolt holes and then remove the pins to finish the lug bolt installation.
STEP 6: Lower the car back to the ground and torque your wheels to OEM specification. Drive the car to verify properly seated lugs and re-torque once the car is cool. Repeat these steps for all four wheels.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
