04-26-2024, 08:10 AM | #1 |
///Mflight Member
948
Rep 410
Drives: 2021 BMW M5 F90 Comp
Hi, like everyone already know the stock exhaust note on the new X5M/X6M are not really the best.
In my case i went with Aulitzky Exhaust with the first Eisenmann Exhaust Mid-Pipe or Mid section. Also some pics of their cars 😍😬🔥🔥🔥🔥. https://youtube.com/shorts/mOOuveeQN...5nqQ8E-fUlW91y https://www.instagram.com/eisenmanne...UxOWdlYzV4dA== https://www.instagram.com/aulitzky_e...NlMHhuamtjMG1v |
04-26-2024, 09:28 AM | #3 |
///Mflight Member
948
Rep 410
I did, thats what the post is about. First Eisenmann Exhaust Mid-Pipe/X pipe. Some people called X pipe and some mid-pipe. For me they are the same. This is the very first one build by Eisenmann for the LCI.
04-26-2024, 09:41 AM | #4 |
///Mflight Member
948
Rep 410
[QUOTE=S68 X5MC;31104410]It's not the same and you don't have one installed... I think you need to research what an X-pipe is.
Well educate those that are not as knowledgeable as you are my friend. Last time i check an xpipe is two single pipes just welded in the middle. Older design both pipes would connect at the welding area making it a combine system within the two. Thats one of the main purpose of the forum to share knowledge or learn from others. 🤜🏽🤛🏽 |
04-26-2024, 09:50 AM | #5 | |
DD214
272
Rep 283
[QUOTE=GAMA;31104432]
https://eisenmann-exhaust-systems.de...er=B5500.20000 Last edited by S68 X5MC; 04-26-2024 at 09:57 AM.. |
04-26-2024, 10:13 AM | #7 |
///Mflight Member
948
Rep 410
Thanks for explaining brother 🤜🏽🤛🏽very much apreciated.
04-26-2024, 11:11 AM | #8 |
Rep 951
No worries man. I should have said some people call the crossover a balance tube. Either name works, but describes something that is not an X-pipe. Where the gasses meet is called the merge, it's easy to see that an X-pipe is going to have a better merge than a dual exhaust with a crossover or balance tube.
GAMA948.00 |
04-27-2024, 11:13 AM | #10 |
///Mflight Member
948
Rep 410
04-27-2024, 11:29 AM | #11 |
Rep 25
04-28-2024, 07:32 AM | #12 | |
Rep 57
