04-05-2022, 10:32 PM | #133 | ||
Rep 627
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill | Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive |
04-07-2022, 10:10 PM | #134 |
Rep 608
hey everyone,
curious to know if anyone is aware.... I currently have HK system in the X5, but wanting to swap out the speakers for something even better. I read mixed reviews of Focal and Bav, but at the end of the day, I'd give either of them a shot but the price is a bit out there... so with that being said, what would be a good direct swap from HK to something else that would be compatible with the stock amp wiring? I saw some posted pics of kicker/alpine speaker/tweeter setup and had good success, but at the same time, that was a HiFi user I think, not an HK, and he ended up putting in a new amp as well, which I want to avoid doing to keep the cost down but speaker sound to improve... Let me know what you guys can share |
04-18-2022, 09:04 PM | #136 |
Rep 30
No, the rear tweeter grills don't light up. They don't either on the cars that come with B&W system. I did this install recently and have a few videos about drilling the rivets, if anyone wants I can upload them to YouTube if it's helpful.
Greg87611.00 |
04-19-2022, 07:24 AM | #137 |
Rep 143
I would love to see the rivet video if you would consider posting on YouTube. I know this has been a hot topic in the past for so many-including myself and would find it very helpful. THank you
04-19-2022, 08:00 AM | #138 |
Rep 608
I think posting a video WOULD be helpful, but at the same time, there really is nothing to it.
You take a drillbit which fits snug into the center of the rivet and you just drill down with a little force and you let the bit do the eating of the plastic rivet. You put enough pressure to get through the rivet but not go through the plastic. A little force is all that is needed, once you see the plastic has been eaten through, you stop and check to see if that part of the grill can be lifted from the door (with your finger or fingernail). If yes, then you've succeeded, if not, you drill a little more for the bit to eat a little more of the plastic around, but rule of thumb is....once you see the grill screw hole, you can stop drilling and assess. The bit size that I used was a 3/8, just make sure its a wood / general bit and not a concrete one. |
silverstar335503.00 |
04-19-2022, 08:20 AM | #139 |
Rep 88
Please do. We would appreciate it
05-11-2022, 04:15 AM | #140 | |
140
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
Do they clip into the back of the new door handle bracket like the front door tweeters do in there corner housing or are they a different design than the front tweeters? do I need to buy different tweeter or is there a separate bracket involved?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
05-11-2022, 09:33 AM | #141 | |
Rep 608
I can try to take a vid of how the grill covers come off amd back on, but cannot guarantee since I never really took videos of things I do lol |
05-31-2022, 07:30 PM | #146 | |
Rep 88
05-31-2022, 07:39 PM | #147 |
Rep 88
I did some more research and it seem you are right..... Well. The center speaker cover and the speaker cover for the tweeters are the same part number... However for the door covers the X6 part number only goes with the X6 g06 2019 to 2022
06-17-2022, 12:43 PM | #149 |
Rep 88
[QUOTE=magas;29020410]Just got my kit for the G06!
Took about 3 weeks. Hopefully will install tomorrow. Also upgraded the amp (Matchup) and speakers. Let's see know how the installation process went. Did you get it from AliExpress? |
06-19-2022, 12:58 AM | #150 | ||
Rep 452
Drives: 2017 X5, 2020 X5 & 2021 X5
I then bought the rear door handles and tweeter covers off AliExpress (China Car Audio Store) for USD200 and used my old 2 10w front door tweeters which fitted perfectly. I plan to replace them with some higher quality ones in the future. About the installation 1.Follow the BAV video at the beginning of this thread play it a few times until you are familiar with it then it becomes easy. 2.The B&W covers came fitted on the door handles and are very high quality and the name is spelt correctly. I would not be surprised if they come from the same factory as the OEM ones. 3. The door handles on the AliExpress web page shows they come fitted with the handle levers. This was not the case on my consignment which was not a problem as I used my original ones. The pin holding the lever/spring must be punched out using a small hammer and centre punch from the bottom of the old handle piece. I took a photograph of the spring location before I removed the pin so I could put it back correctly. 4. When you remove the lever there are 2 small rectangular rubber grommets you also need to remove carefully from the old handle. A dab of Vaseline on the rubber pin will assist in pulling them through from the other side of the new handle to seat them correctly. Do this before inserting the door lever/pin/spring. 5. There are 6 plastic spot welds plus 4 clip points and a screw that hold the door handle section in place against the main door panel. To remove the 6 plastic welds, I used a 4mm drill bit to loosen/ break the welds some were still intact so I increased the drill bit up to 6mm. I then used wire cutters to cut off the remaining excess plastic. 6. Carefully remove the ambient light tube before unclipping the old door handle from the door panel. 8. Remove the original trim from the back of the handle and clip it into the new one. 9. MOST IMPORTANT is now take the OEM clip cover that hides the T20 handle screw and test to see if it fits flush with the new non OEM handle. In both cases the clips on the OEM covers would not clip on to the back edge lip of both my new handles. I only found this out as after I screwed the one door panel back in place and ended up taking it off again. 10. To fix the above problem I sanded down the edge lips until I was satisfied the OEM clips were working as expected. 11. Mount speaker into the newly provided slot. I downloaded a photo from eBay of someone selling a rear door panel as a guide for the correct alignment of the speaker/wires. (https://www.ebay.com.au/itm/12510001...temCondition=4) 12.Place the new door handle in place using the 4 existing clip points. I did not use any additional screws in place of the 6 recently removed welds as the 4 clips plus screw at the end were in my opinion sufficient to hold it firmly against the door and surrounding panel trim. 13.Reinstall the ambient light wire/tube with care and clip in the speaker resistor into the allocated slot on the door panel below the newly installed handle section. 14.From previous experience removing door panels I have found it easier to apply a dab of Vaseline to the plastic clips before pressing the panel firmly to the metal door frame so if you ever have to take it off again they don't break as they become brittle with age. 15.Re fit door panel as per BAV video
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 06-29-2022 at 06:36 AM.. |
Greg87611.00 |
06-20-2022, 08:46 AM | #151 |
Rep 880
Can anyone speak to the spelling of B&W on the aliexpress kit that folks have linked in this thread? I see some pics where it's spelled correctly and some where Wilkins is spelled Wlikins.
Is it confirmed that all those kits have the incorrect spelling? I wish it had no logo on them, but looks like that's not an option. |
06-20-2022, 02:08 PM | #152 | |
Noice
125
Rep 217
Drives: 2023 BMW iX 50drive
06-20-2022, 02:12 PM | #153 |
Noice
125
Rep 217
My tweeter and speaker lights don't shine nowhere near as bright as your image. Am a little disappointed in their lack of brightness compared to the rest of the vehicle
06-20-2022, 02:56 PM | #154 |
Rep 608
I second this, but i think it may be the camera settings that boneca and whoever elses posted pictures of. Plus, depends on the speaker color inside the grills too. But mine are DULL lol
