      08-03-2022, 01:01 PM   #155
Abune
Drives: 2022 X6
      08-22-2022, 07:53 PM   #156
chefwong
Drives: X5
I've posted my thoughts/concerns about the issues with the honeycomb/plastic fatigue and entailment to repair should it break...
Installed my Sly Bracket with the leveling bracket. The leveling bracket is not fixed tight but simply just held in place with tension. The bottom is 1/8" level - away from the bottom of the bumper.
I can easily see if driving in snow, park, etc - it can easily move the level so that it tilts inward and may scratch anything behind it.
The top of the plate is just flush right below the front plastic trim. This is without a license plate frame
Mulling but I think I might just double sticky the plate .....to the center
      09-12-2022, 11:48 AM   #157
skyliner10004
Drives: 2020 x5
i've used outdoor rated velcro tape and its been good through snow, heat, high speeds for 15k miles... and clean too.
      09-12-2022, 12:46 PM   #158
chefwong
Drives: X5
VHB works just fine dead center...
I have been thinking about this.....kinda used to seeing the crappy tow mounts on all cars , half of them lopsided vertical...
We go through the trouble of offsetting it for what *reason* vs. being center.
Kinda one of those philosophical moments maybe - in which I've been thinking about it.
Right now, mine is aft rightsize, with the sly bracket. Haven't gotten around to it but may just take the stock holder, VHB it and then put the plate in stock center location.
The way the SLY bracket holder is, it's actually tensioned/supporting on the *L* covering 3 honeycombs, so it's not that bad on how the tension is spread I suppose
      09-15-2022, 12:57 PM   #159
Stallion0511
Drives: BMW 430 GC
The post of the zip ties on the mesh honeycomb seems like a good solution
      09-16-2022, 01:50 PM   #160
chefwong
Drives: X5
It looks so -zip tied- from far away as you can see it's slanted...
I'd rather have the OEM mount where it's at least it's straight and vert
P111572.00
      09-16-2022, 09:28 PM   #161
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Agree. It's either no plate at all or plate in the spot where the designers intended it to be.
Drill that bumper, baby!
      12-06-2022, 10:56 AM   #162
23X5_Wizard
Drives: 2023 X5
I have 2023 X5 40i M Sports
Could someone please let me know how much clearance should the plate be from sensors before plate starts interfering the sensors' functionality?
Thanks!
      12-06-2022, 11:56 AM   #163
1Mors
1Mors's Avatar
Drives: 2022 X5 xdrive40i msport
Thanks!
My plate does not interfere at all with the sensors.. parking or otherwise including the Assisted Drive Pro. It's about a 1/2 from the frame and 3/4 inch from center sensor.
      12-06-2022, 12:26 PM   #164
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
mine is even a bit more left towards the center ACC sensor than above. no issues almost 2 years after installation
Shllshck217.00
      12-06-2022, 05:11 PM   #165
23X5_Wizard
Drives: 2023 X5
Has anyone tried this?
iJDMTOY No Drill Front Grille Mesh Mount License Plate Relocator Kit Compatible With Challenger Charger Durango Grand Cherokee w/Diamond Shape Lower Bumper Grill Mesh/Insert https://a.co/d/455AeI6
      12-13-2022, 07:34 AM   #166
sparrky
sparrky's Avatar
55
Drives: BMW - 2023 X5 40i
2023 BMW X5  [0.00]
I just tried it this weekend. It is a good concept but I would describe it as flimsy.
The brackets are easy to bend and will most likely flex a lot when driving, causing the plate to rub against the bumper, if you mount it in an upward position - which is exactly what you are trying to avoid. Sure you could attach rubber bumpers to the back of the plate. But if you live in the north with ice and snow, I can see it bending downward if snow or ice slide off the front of your hood.
      01-13-2023, 03:56 PM   #167
sparrky
sparrky's Avatar
55
2023 BMW X5  [0.00]
So I got the Carbonio No-Drill license plate mount.
I don't have adaptive cruise, but I ordered that version, as I would like it to be generally in the position the OEM BMW mount would be, on the bumper.
I'm generally happy with it, appears to be good quality and adjustable with regard to the position it attaches to the lower grill (below the bumper), as well as the bracket itself.
I did have one issue, probably operator error (me). Don't slam me, I broke down and went through a touchless car wash - it messy winter in the northeast and handwashing isn't an option on most days, and I can't get appointments at the detailer when I really want a wash. In the touchless wash, the plate mount actually bent forward, with the license plate sticking straight out from the bumper. I'm not sure if the blast of water or the air dryer caused it to bend forward. I was able to remove it and bend it back, by hand, to the normal position and reattach it.
      01-13-2023, 05:10 PM   #168
nZtiZia
nZtiZia's Avatar
while one could say that shows the ‘low quality’ of that metal, it could actually be purposeful. it the metal were harder/firmer, what would end up giving in? the grille, which is a much more expensive piece to replace!
      01-27-2023, 07:10 PM   #169
sparrky
sparrky's Avatar
55
2023 BMW X5  [0.00]
So I had my first “snow” experience with carbonio and the same issue. Apparently snow slid off the hood, down the grill and bent the carbonio 90-degrees, sticking out straight. It was mounted, angled slightly towards the bumper with the rubber bumper feet touching the bumper.
So I’m done with these screw on, no show, no drill contraptions. Sto n sho, Carbonio and a no-name item from an Amazon retailer.
Next time I’m at the dealer for service I’ll just have them put on the standard oem bmw plate holder.
      01-28-2023, 06:59 AM   #170
E91toG05
E91toG05's Avatar
344
Drives: 2022 X5 45e
So I had my first “snow” experience with carbonio and the same issue. Apparently snow slid off the hood, down the grill and bent the carbonio 90-degrees, sticking out straight. It was mounted, angles slightly towards the bumper with the rubber bumper feet touching the bumper.
I went same path for same reasons.
