      01-17-2024, 01:44 PM   #353
sickmommobile
sickmommobile's Avatar
Drives: BMW X5
Love this as a tow vehicle after replacing the F150 with the '21 xdrive40i. Only complaint, even though it's small, is that my locking hitch pin interferes with the safety chain eyelet. I have to perfectly position the lock to get the key in to unlock it. Not a huge deal, but I have to make sure the lock is on the right way to access through the eyelet, or I'd be screwed.
      01-17-2024, 05:52 PM   #354
bono
Drives: BMW X5d
No way, I thought that trucks are ultimate towing machines.
      02-06-2024, 04:46 PM   #355
qtx5
Drives: BWM X5
impressed by the variety of things ppl are towing
      02-07-2024, 12:18 AM   #356
Baz84
Drives: BMW X5 G05 LCI 50e
Twin Axle Swift Caravan weighing 1800kg / 3968lbs. Tows very nicely. Stable and plenty of power from the 50e.
Also tow a small 750kg / 1653lbs unbraked box trailer most weekends with my sons motorbike in it which it makes very light work of
Dandle213.50
      03-23-2024, 10:20 PM   #357
djohn
Drives: X5 40i
The Casita weighs a bit over 3k lbs loaded. I carry some gear in the back of the X5, too. My passenger (pictured) weighs 15 lbs, pretty manageable. I do need to measure the axles sometime, now that I've got all the weight distributed how I like, but I doubt I'm that close to the tongue weight limit.
I've gone on some terrible roads by now. Didn't get stuck in the turnaround for my dispersed-site cove on the Colorado River (loose rock, and sandy). I'm really impressed with this vehicle!
      03-24-2024, 02:47 AM   #358
Bill9999
Drives: X5 50e
2024 bmw x5 50e  [10.00]
I'm buying an x5 50e and will be towing a 4000 pound dual axel travel trailer. I've always used weight distribution anti sway bars when towing with my Jeep grand cherokee. I read somewhere that bmw does not recommend the use of sway bars. What's everyone using (or not using)? any issues traveling 70 mph with a 4000 pound trailer?
      03-24-2024, 11:34 AM   #359
djohn
Drives: X5 40i
I use an anti-sway bar, only. You're a little heavier than my rig, so you could choose to be one of those who disregards the prohibition. But I figure there has to be a reason they allow WDH with the X7 but not the X5, right?
edited to add: I used to have a limit of about 68mph, but then I upped the speed rating on my trailer tires, and I'll go as high as about 72 or 73 now.
      03-24-2024, 11:34 AM   #360
jad03060
Drives: X5 45e
This gets beat around a lot.. BMW says do not use WDH on a current X5. Keep the tongue weight within limits. If you do that, the OEM trailer stability logic should work fine.
      03-24-2024, 01:36 PM   #361
Bill9999
Drives: X5 50e
"OEM trailer stability logic ", on the X5? Never heard of that. How does that work?
      03-24-2024, 03:16 PM   #362
djohn
Drives: X5 40i
It applies the brakes as soon as oscillating yaw motion is detected. I haven't experienced it yet. In my previous vehicle, the one and only time the anti-sway bar saved me from a bad gust was getting across Wyoming. Wyoming takes windy to a whole other level.
      03-24-2024, 04:45 PM   #363
Di3s3l_Power
Drives: X5
I use BlueOx WDH hitch with antii-sway build in.
I personally will not tow without WDH
single axle @4300 lbs airstream 22 feet
I keep the speed around 68mph and works good.
      03-24-2024, 05:35 PM   #364
jad03060
Drives: X5 45e
The vehicle has accelerometers, tilt sensor, and the computer also knows which way and how much you turn the steering wheel. Add all of that together, and the computer can help with the stability. To transfer weight to the front axle, a WDH applies torque to the chassis. BMW says their chassis is not designed for that, so if you were to have any long-term issues, they would not be responsible. One big reason to use a WDH is to get the vehicle to ride at the proper height, but with the 50e and the air suspension, it will ride evenly as long as it is loaded within specs. When a trailer causes the chassis to sag in the rear, unloading the front, it becomes unstable. I would not use a WDH on a vehicle that says not to…your choice to ignore that, but should you have an issue, it could bring up all sorts of legal issues.
      03-25-2024, 01:23 PM   #365
Bill9999
Drives: X5 50e
I'll be getting my ordered x5 50e by the end of April( I hope). I ordered the OEM trailer hitch with it and will be pulling my trailer without using a weight distribution hitch. I hope you're right and it works fine. I'll report back on my experience.
      03-25-2024, 01:34 PM   #366
TurtleBoy
TurtleBoy's Avatar
13275
Drives: 2019 X5 40i,2021 M340i
What is your production week?
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      03-25-2024, 09:49 PM   #367
Bill9999
Drives: X5 50e
Been told Week 18, but it's been pushed back so much I don't trust it.
      03-26-2024, 08:21 AM   #368
TurtleBoy
TurtleBoy's Avatar
13275
Okay, thanks. I think that os the first scheduled week for the 50e so that should give us an idea of how production will go.
      03-26-2024, 05:51 PM   #369
bloom
bloom's Avatar
15
Drives: none
Does towing require the heavy rated tires? I replace my rears with “107” ratings.
      04-04-2024, 03:40 AM   #370
bono
Drives: BMW X5d
Where "BMW says their chassis is not designed for that", i.e. chassis not transferring weight to front axle? Please do not share incorrect information.
      04-05-2024, 03:04 PM   #371
tdott
Drives: M3
saw this brave man at the track, sDrive 40i, no air suspension.
      04-05-2024, 09:36 PM   #372
bono
Drives: BMW X5d
His X5 tows this trailer better than any half ton truck.
      04-06-2024, 11:15 AM   #373
tooloud10
Drives: '08 M3 convertible
Nah, still doesn’t no matter how many times you repeat it.
M3 - X5 - 911 - Miata - Raptor - Edge
      04-06-2024, 11:23 AM   #374
bono
Drives: BMW X5d
Nah, still you can't change the reality
