01-31-2021, 02:46 AM | #25 | |
Rep 3,479
Mystro, sorry to see you got a defective part there, that they put a W instead of the M. |
02-05-2021, 11:02 AM | #26 | |
Rep 5,324
Every one will need to be custom adjusted to the door they are going into so the text or logo lines up with the line of the open door. When popping them in the door, I like to put one side in all the way in so it catches first then rock the other side up and in till it is flush. Use the palm of your hand push firmly. These have always been a tight fit. Notice how the logo is even with the line of the open door. A askew logo to the door line looks bush-league. Last edited by MystroX5; 02-05-2021 at 11:09 AM.. |
02-05-2021, 11:11 AM | #27 |
Generalissimo
643
Rep 1,393
So, I got the new LED projectors (part #63312468386). If they indeed supposed to fit G05 then it's a horrible product. I got 2021 X5 45e M Sport and these lights simply don't fit in the hole from the original door lights as the body of the projector light is slightly longer then the original lights. I had to make the holes on both front doors slightly larger by cutting the corners next to the notch in front of the hole. After doing that I was able to pop the projectors in. However, the projected image is partially blocked by the bottom of the door. It looks like the painted metal part of the door below the plastic trim (where the light is installed) is in the way of the projection so part of the image is shining on the bottom part of the door. It's almost unnoticeable with the "M" logo lenses but totally unacceptable with the "BMW" circle logo ones as the part of the circle has a shadow from the door. Did anyone have the same issues? Is the problem with the new part #63312468386 and the old one (63312414105) fits and projects properly? Thank you.
02-05-2021, 11:13 AM | #28 | |
Rep 5,324
02-05-2021, 11:16 AM | #29 |
Generalissimo
643
Rep 1,393
I can but later. What about the fact that they partially shine on the bottom painted metal part of the door? I see part of the projection reflecting off the metal. You didn't have the same problem?
02-05-2021, 11:26 AM | #30 |
Rep 5,324
02-05-2021, 11:36 AM | #31 |
Generalissimo
643
Rep 1,393
02-05-2021, 11:48 AM | #32 |
326
Rep 303
Cutting Corners....
"I had to make the holes on both front doors slightly larger by cutting the corners next to the notch in front of the hole."
I just did the same thing and it worked quite well. I cut away the two small plastic corners next to the notch on the bottom of the door. I used a box cutter.
Current: 2020 X5 M50i
Previous: 2019 M550i, 2018 X5 xDrive35i, 2015 750i, 2015 X5 sDrive35i |
02-05-2021, 11:52 AM | #33 | |
Generalissimo
643
Rep 1,393
02-05-2021, 12:28 PM | #34 |
Rep 1,203
Drives: 2023 BMW i4 M50
I went OEM, and I love these. They are good quality. The frame of the projectors is metal. I was hoping for the "X" insert but the BMW sign works for me as well.
02-05-2021, 01:49 PM | #35 |
326
Rep 303
No issues. I am using the M image and it seems to be projecting 100% down to the ground, and not hitting the bottom of the door.
02-05-2021, 02:24 PM | #36 |
Generalissimo
643
Rep 1,393
So, you don’t see even a small part of the projected image reflecting off the inside bottom painted metal part of the door almost right under where the light is installed? Are you using new or old part number? You have a 2020 M50i, right?
02-05-2021, 03:55 PM | #37 | |
Rep 913
2020 bmw xHippo, v8tt edition
02-05-2021, 04:19 PM | #38 |
326
Rep 303
Yes, 2020 X5 M50i and I used new (I think) part # 63-31-2-468-386, 'BMW Led Projectors 68MM.' Don't see anything reflecting off the door.
cruzer6661237.00 |
02-05-2021, 04:19 PM | #39 | |
Generalissimo
643
Rep 1,393
02-05-2021, 07:10 PM | #40 |
805
Rep 1,790
Looks to me like this is a "Jury-Rig" fit and not the same as the original projectors that come with the vehicle. You shouldn't have to cut anything out of the housing where you insert the projector lens.
I'm definitely not interested if this is what it takes to make them work. |
02-05-2021, 10:50 PM | #41 | |
Rep 1,203
Instructions on the OEM part do say you need to use a box cutter to shave two small lips off the housing. It's really no big deal to do, these lips are tiny. Doing so does not affect esthetics or the fitting of the original lights. |
02-06-2021, 07:40 AM | #42 | ||
Generalissimo
643
Rep 1,393
Also, can someone who has the projectors installed see if they do get some of the projector light shining on the door (see second picture below). I get this large sort of semi-circle of the projector light shining on both driver and passenger door which I guess is normal since the light is close to the door and it doesn’t seem to be causing any issues on my driver side door. However, as you can see from the second picture of the passenger door there is a bright spot of the projector right inside the semi-circle which I think is the actual projected image getting obstructed by the painted door trim. Thank you. |
02-06-2021, 07:56 AM | #43 |
Rep 5,324
They are not the OEM projectors I used in my 3 BMW vehicles. My part #63312414105.
https://www.amazon.com/BMW-Genuine-R...2619837&sr=8-1 Last edited by MystroX5; 02-06-2021 at 08:02 AM.. |
02-06-2021, 08:31 AM | #44 | |
Generalissimo
643
Rep 1,393
