09-12-2022, 10:52 PM | #1 |
... space for rent ..
118
Rep 560
Show us your subwoofer
Like the title says, show me your aftermarket trunk subwoofer setup. I have a Bimmertech amp and Focal speakers on the way but I'm looking to add an additional sub to the trunk. I'm not looking to go too drastic as far as a JL audio W7 but I would like to feel my music a bit.
I'm looking at sub, box, amp all in one but I've never heard one of those setups in person. |
09-13-2022, 04:56 PM | #2 |
Rep 14
RF300-12 bought + Technic harness to install on top of the B&W system.
Taking delivery in a few days, will post pics of the install in a few weeks when I get around to it! Excited. |
09-14-2022, 03:18 PM | #3 |
Rep 62
I'm considering a 2020 X5 that doesn't have the HK sound system after having several BMWs that have had it. I know this is a very difficult question to answer but to upgrade to a similar sounding system to HK what kind of price are we talking? Thanks in advance
Current - 2016 X5 40d
Previous - 2020 X5 30d > 2019 X3 > 2014 420d |
09-14-2022, 03:46 PM | #4 |
Rep 112
Doing the Focal/Bavaudio route with the amp upgrade that is all plug and play would probably get you pretty close. The factory HK is very disappointing to the point I will probably be doing the Focal upgrade and adding a sub as well.
09-16-2022, 04:14 PM | #5 |
118
Rep 560
My Focals arrived from Germany. It took about 2 weeks to arrive but the cost savings were significant. I paid about $500 for this whole set.
All I need is my Bimmer-tech amp to finally show up. Once I have the amp and speakers installed I will see what kind of subwoofer setup I need. |
09-17-2022, 03:53 PM | #7 |
118
Rep 560
Sure thing. They have a store on eBay as well but I went though them directly.
Just use google translate or the translate option on your PC. https://www.extremeaudio.de/ Their email is: kontakt@extremeaudio.de Good luck and be patient. It may take 2 weeks to arrive. |
09-18-2022, 10:00 PM | #9 |
118
Rep 560
I was actually watching YouTube reviews on that one. They have two versions, a 300watt and a 500 watt. Does the bass from yours really fill the cabin? Even if there’s a little rattle I don’t mind.
09-19-2022, 07:31 PM | #11 |
Rep 599
09-20-2022, 12:35 PM | #12 |
Rep 14
I got the Rockford Fosgate P300-12 Punch 12" 300-Watt Powered Subwoofer.
Yep - installed it myself. Didn't take very long, as the harness and easy access to the B&W booster amp was super easy. The longest time it took was tapping into the battery, ground, and routing the cables in an organized way to the back, taping everything up so its clean, etc. |
09-21-2022, 08:20 AM | #13 | |
Ex Moddy
119
Rep 145
Have you installed a "quick release" mechanism so that the sub can be removed easily and safely?
X5 45e in Arctic Grey with Merino Leather, Technology Plus Pack, Comfort Pack, M Sport Pro Pack, Shadow Line Pack, Sky Lounge, Acoustic Glass, Tow Bar, Sun Protection Glass, Sky Lounge, Carbon Mirror Caps and Laser Lights.
09-21-2022, 05:34 PM | #14 |
Rep 14
Well, the sub already has a sort of quick release mechanism because the plug where remote/power/ground goes in is a sort of harness. You unplug that and the RCA plug and the sub is free to go!
09-21-2022, 09:44 PM | #15 |
118
Rep 560
Thank you. I may end up going with the 500 watt version and installing a volume control knob for that one sub. Id rather have too much power with a controller than too little.
09-22-2022, 12:19 AM | #16 | ||
Rep 436
Hats off to you guys and everyone who has gone through with these sound upgrades. I just haven’t been brave enough to do these upgrades with these new, integrated systems. |
09-22-2022, 12:34 AM | #17 | |
118
Rep 560
My past few cars had garbage audio! This time around I purchased my X5 which I really like A LOT. So I figured lemme add some OEM+ touches. I’m in my 40s now so I’m not looking to shake the block but I do like to pump up some old school hip hop and r&b once in a while. The Bimmertech amp, focal replacement speakers, and an additional sub will definitely fit the bill while maintaining the OEM look and feel of the vehicle. |
09-23-2022, 08:24 AM | #18 |
Rep 14
Dude - reading this gave me mega flashbacks. I actually had an E36 318i where you could actually swap out head units. Had a sweet Alpine head unit with the same exact orange LEDs as BMW interior + matching graphical Alpine EQ unit (forget the model number) mounted on the bottom cubby. It looked so sweet.
RF 4 channel amp powering (first) Boston Acoustic and then swapped for MB Quarts. THen added a mono RF amp to power 2x 12" sealed subs on the trunk. I had to actually cut out the metal piece separating the trunk from the main cabin through the middle armrest. Added some felt to cover, but that way the bass could get in the main cabin. As you said - best sound system I've ever had. |
09-23-2022, 11:34 AM | #19 |
Rep 496
Very nice. I noticed the bass completely drops off once you go behind the driver's seat, which seems odd given B&W cost. I like the minimalistic look off your setup, although I'm searching for something to reside in the spare tire area kind of like the Bose system on m you old Q7. Those spare tire subwoofers used to be a thing.
09-24-2022, 04:34 PM | #20 |
Rep 14
I think Kicker makes some sub boxes that fit inside the spare tire well - and I think they are powered too! I didn't want to sacrifice the spare.
If I need the trunk space I'll have to unplug the sub and put it away, bit of a hassle but hasn't happened yet! I'll just tell the fam to pack less. You're right about the B&W bass - I noticed it immediately. It's only got 2 underseat subs and they aren't all that large or sufficiently powered which is why the extra 12" does wonders. Good luck! |
09-24-2022, 08:44 PM | #21 | |
118
Rep 560
I'm a bit skeptical about leaving a sub under the trunk carpet. I think the mat would really filter out a lot of bass. |
09-25-2022, 09:15 AM | #22 | ||
Rep 14
Good luck! |
